Question about Nikon COOLPIX S200 Digital Camera
Using Nikon S200 getting white lines on pictures. Adjusted exposure and brightness and still getting.
    Champion:
  • 226 Answers
Hi aaron_golf20, possible sensor trouble.
Contact Nikon service
Posted on Mar 25, 2011
Too much brightness when using s6800
I do not know the S6800 model specifically however, nikon cameras all generally work in the same way. Somewhere on your camera, probably a button or in the menus, there is an exposure compensation setting. The symbol Nikon uses for the button is a "+/-" enclosed in a circle (often half black on white/white on black printing). Press the button and you will either see a zero, a positive or negative number or a a scale with zero in the center with positive numbers to the right and negative numbers to the left.
If the exposure compensation is not at zero, set it to zero. Your exposures should now be correct. If it is already at zero, set it to a negative number to reduce exposure and darken the picture and to a positive number to increase exposure and lighten the picture. Let me know if this solved your problem.
Jul 31, 2014 | Nikon COOLPIX S6800 Digital Camera Black
What would cause auto mode to start producing dark pictures?
This has been showing up in the autofocus mode of Nikon DSLRs of all flavors for years. There's some indication it may be due to an underlubricated gear causing the shutter to fire at a faster speed than indicated, but most of the evidence seems to point to a random glitch in the firmware.
Jul 17, 2014 | Nikon D60 Digital Camera
When i took a picture with my nikon d70 the the outcome is quite bright where to adjust. i'm a beginner
1. You could lower the ISO setting. 2. You could lower the "exposure compensation" setting. It's the button that's half-black/half-white with a plus and minus. There are many other ways but you really should carefully read your instruction manual and experiment.
Oct 29, 2010 | Nikon D70 Body Only Digital Camera
When taking pictures outside the view screen after picture taken appears as a bright burst of white light. Inside picture appear fine. Any ideas?
let me see if i understand. if you llok at the screen it looks ok, but after you take the picture it will record only a white bright image.....
in some cases you can easily fix this by goining into your camera option and restoring default settings. it is the exposure setting .
if you camera still giving you just black white images the light sensor in the machine ahs gone bad, it needs to be replace.
Oct 04, 2009 | Nikon COOLPIX L4 Digital Camera
Over Exposure
Go to the exif file for that photo. You can review the file info in camera using the jog button. It will tell you what the settings were when you snapped the shutter. You failed to mention if any pictures were consequently taken without errors.
Oct 23, 2008 | Nikon D70s Digital Camera
Casio exilim ex-z700
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
Can't repair by yourself.
It's need repair camera machine shutter.
more detail CASIO Exilim EX-Z700 overexposure
Aug 06, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
I think my flash is too bright?
Make sure that the exposure compensation is at zero. If that does not work, make sure that the flash is on automatic brightness. Check the manual if you do not know how to do either one of these.
Apr 11, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Picture taken is so bright and with trasparent horizontal line
more detail casio ex-s600 overexpourse
Feb 24, 2008 | Casio Exilim EX-S600 Digital Camera
Nikon d70 photo results
You might want to change the white balance or bracket your exposures
Here is a link to the photonet site that may give you some things to try: Photonet
Feb 23, 2008 | Nikon D70s Digital Camera
"overexposure"
CCD failure. Known issue apparently based on other posts on other forums and web sites: http://www.nikon.co.nz/pagearticle.php?pageid=2-bdc691bf61
Jan 31, 2007 | Nikon Coolpix 5700 Digital Camera
Nikon COOLPIX S200 Digital Camera Logo
43 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
