Had a lightning storm,now brand new aircon wont restart,remote is ok
    Brigadier General:
  • 4,736 Answers
The electrical storm may have caused a power surge and burned out the circuit board. Especially, if the power went out briefly and then came right back on. Most manufacturers recommend turning the unit OFF during a power outage/electrical storm.
Hope this helps you.
Posted on Mar 25, 2011
Replacement remote for Mitsubushi aircon MSH-24TV, how do we get them talking?
If you wish to buy a genuine remote control, you have to contact the authorized service centre for Mitsubishi. If you wan to buy a universal remote control, you should first check, which brand remote control have setup codes to Mitsubishi brand TVs. If you wish to get this detail, try the links given here. It has setup code list, and setup procedure to many popular brand remote controls. Check and find out which brand remote control have the codes to Mitsubishi, and buy that one according to availability.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Dec 24, 2013 | Televison & Video
Lightning storm
More than likely the module/chip got fried by a voltage/lightning spike.
It's cheaper to replace small appliances than to repair them.
Suggest buy a new one.
Nov 02, 2017 | Coffee Makers & Espresso Machines
Samsung hdtv how to know if lightning fried it
If the tv will not turn on it is safe to assume that the electrical storm did damage something in your television.
Jul 11, 2012 | Samsung 46 UN46D6000 LCD TV
I have an split-type aircon (brand: General) remote control AR-DL2. it has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix...
i have general electronic ac brand i cant found universal remote can u find one for me what are the universal remote that compatible for my ac tq
Nov 29, 2010 | Heating & Cooling
Sanyo DSs31820 dead after lightning storm. Is there a master reset?
A lightning storm will destroy a TV in many cases. I have repaired very few, with this problem. I would certainly find a new TV, if this is the case for sure. Thanks for asking!
Jul 11, 2010 | Sanyo DS31820 31" TV
We had a storm and now the wii will not even turn on.
Was the Wii running while the storm was going on? Was it a lightning storm? If the answer is yes to eaither one of these then most likely there was a power surge and the power supply and / or motherboard has been damaged
Sep 02, 2009 | Nintendo Wii Console
Printer will not print after lightning storm
Hi chk u r parllport working /not?
if u have drivers cd ,delete the printr &restart u r computr,see u r computr is detected the prntr /not ?if detect install drvs &chk
tell me ple.
Aug 12, 2008 | Epson LX-300 Matrix Printer
Wont turn on...
You have to Call 1-800-4my-xbox.
Then tell them what happened, you will have to mail it out with the Console, and the plugs.
Dont mail out the hardrive or disc.
They will send u a brand new console.
Hope this Helped.
Jul 12, 2008 | Microsoft Xbox 360 Console
Air conditioning
no,
most thermostat wiring is 4 core, because installers use phone cable -its cheap- but there is no accepted color code, and some systems use 2, or 3, or 4 of the wires.
there should be a standard.
terminals on thermostats and furnace, aircons are labelled, but the labelling is often contradictory. some thermostats have function to control the fan separately, some for the same aircon dont.
the manufacturers web site for your aircon,
should give a detailed explanation in install instructions which terminals are open on rise close on rise, heat/cool and how they are connected
the new thermostat should detail which of its terminals match those of the aircon.
test the cable before installing anything at the aircon or thermostat, a lightning strike can have shorted things normally impossible, and the lowV thermostat line could be at lineV and trash anything or anyone connected to it,
  • Lightning strikes are very unforgiving, please be careful, even if the lightning touched down yards away the voltage at large distances from the strike can be 10KV
  • paranoia impels me to recommend an electrician with test equipment for the lines, outside unit, cables and inside units, its better to check and be wrong, than not check and be wrong.
Jun 22, 2008 | Heating & Cooling
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
104 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
