Question about Microwave Ovens
My washing machine is frozen - Microwave Ovens
  • 591 Answers
Try unplugging it from the power outlet for an hour, than plug it back in, if it is not working than your control board is probably defective... did this happened after a power failure??? or a storm???
Good Luck!
Posted on Mar 25, 2011
  • 3,083 Answers
If it's belt driven, you could have a belt that's slipped off the pulley, and jammed the tub. If it's a mechanical gear driven type, it could be a broken or jammed gear. Either way, you will have to turn it on it's side, to inspect to see what you have, and if you can fix it.
Also, check under the tub to make sure an article of clothing hasn't jammed the tub.
Other than that, a repairman may have to be called.
Good luck, and hope this helps.
Symbol ol a key will not allow a wash cycle
This indicates that the DOOR SWITCH is faulty and is not contacting without which the machine will not start off as it encounters an error for safety.
You can remove the door switch clean and reset it or else replacement is the best option.
Check this link:
http://www.espares.co.uk/advice/washing-machines/a/7/1294/how-to-open-a-washing-machine-door-thats-stuc.html
Sep 23, 2011 | Microwave Ovens
My washing machine do not spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 31, 2011 | Microwave Ovens
My bosch washing machine is leaving a grimey residue in the drum after the wash. I have tried to run the machine without any clothes to see whether it was simply not emptying properly but that's fine -...
This bosch washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2011 | Bosch Microwave Ovens
Not filling up
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 16, 2011 | Microwave Ovens
Machine goes thru all the wash cycle but gets to last min and keeps spinning then comes up with f11
Not knowing what sort of machine you have, one of these should help.
F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
F11 - Pump cannot be activated - Book a washing machine repair.
F11 - Heater timed out. The heater has not reached the required level. Book a dishwasher repair.
F11 - No pump connection - Book a tumble dryer repair.
Mar 17, 2011 | Microwave Ovens
Washing machine keeps stopping and showing F05 on display. Washing is now still in machine with water!!
I would say that the pump has storred working. Either it is jammed, (sock/nanky) or the motor has possibly failed.
Jan 04, 2011 | Microwave Ovens
Washing machine not spinning
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 08, 2010 | Siemens Microwave Ovens
Hotpoint washing machine smells
Here is a tip that I wrote about front load washers and the smells that seem to go along with them....
Stop Washing Machine Smell, Mold, and Mildew
http://www.fixya.com/support/r3993813-stop_washing_machine_smell_mold_mildew
heatman101
Aug 13, 2010 | Microwave Ovens
Microwave Ovens Logo
126 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
