Question about Samsung HP-T4254 42 in. Plasma Television
Sp-R4212 Plasma no picture keeps changing channels when you go to the menu the menu keeps rolling won't stop if I unplug the set for a few days you can go to setup and get it to work I had Sears out to fix it and they disconnected the side buttons. That did not work. they said it would not work. I have had it working for over a year now. But it keeps doing the same thing about every three months.
  • 1,591 Answers
When the menu starts rolling, take the remote out of the room to see if it's the remote causing the problem.
if it's not, check for bad capacitors on the boards.
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you are handy with a soldering iron and can identify the bulging or leaking capacitors, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 25, 2011
Top half of screen has lines in it
Try to change sources...if its happening in different sources or input.tv needs to be fix
Apr 26, 2015 | Samsung SP-R4212 42 in. Plasma EDTV
Samsung sp-r4212
visual test is not conclusive,they need testing ,and is difficult unless you have practice with a soldering iron,best solution is to buy identicle board from tv that had broken screen,of ebay,make sure you get the same rev number etc,hope this helps
Feb 17, 2014 | Samsung SP-R4212 42 in. Plasma EDTV
Tv stuck on av
Look first on the on screen menu to see if the HDMI is there or grayed out (locked out) and try with HDMI connected to select it manually.
HDMI does not like being connected with the unit on sometimes.
Aug 29, 2012 | Samsung SP-R4212 42 in. Plasma EDTV
Dear Sir, I wish to purchase a powr suplly for a Samsung SP-R4212 42-Inch Plasma TV. Part number BN96-02213A
Encompass Parts Distribution has 2 in stock Price is 191.72 Core ($50.00) Part is then 141.72
1-800-638-3328
Dec 12, 2010 | Samsung SP-R4212 42 in. Plasma EDTV
My plasma samsung model sp r4212 the screen goes black you can still hear and when picture comes back on there is also a buzzing sound
press the center power button for about 30 secs verify that the video cables are plugged in and try a different set of cables. If not unplug tv for 2 mins.
GOOD LUCK.
CNBY
Jun 03, 2010 | Samsung LN-S2651D 26 in. LCD Television
No picture has sound samsung 42" plasma ed
check all your connection going to the tv,if good you probably have a power supply problem and need to replace defective capacitors in the power supply or the entire power pcb itself. you have to be a technicain to do this. make sure all power is off to the tv when removing the back of the set.
Apr 21, 2010 | Samsung SP-R4212 42 in. Plasma EDTV
Tv won't turn on
Samsung SP-R4212 42 in. EDTV Plasma Television Flat Panel tv won't turn on Answer the tv tries to turn on then there's a pop and it tries do it all over again Close expert_editor_close.png
Feb 28, 2009 | Samsung SP-R4212 42 in. Plasma EDTV
My Vizio plasma TV won't change channels with the remote or side buttons, but if I input a channel number, it will change that way.
Try unplugging the TV for a few minutes and then doing an auto channel search through the menu button. That has solved my problem, at least for the time being.
Aug 11, 2008 | Televison & Video
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Samsung HP-T4254 42 in. Plasma Television Logo
234 people viewed this question
Jerry Greenberg
Jerry Greenberg
