Question about Kingston Brass Home
Hot water wont go above 113 deg sing 3 ft away has 132 deg water on same line fausit is new just installed tried adjusting the 2 valves behind face plate
SOURCE: Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Posted on Nov 29, 2008
  • 148 Answers
SOURCE: Hot water heater leaking at the top valvue
I believe the problem you had with the pop off valve is a one time thing since you said you just installed the water h eater
The pop off valve is a pressure relief valve that is activated by build up in the tank from excessive pressure either through too much heat or pressure which works by pressing aginst a spring loaded valve
If you go to the whater heater and look at the valve ther is a handle on it take your hand (stand clear of valve opening) and slowly pull it you will see water start to come out
More than likely a new valve could have had a piece of debris in it or was partially open
re
If the heater was overheating the valve would stay open and you would see extremly hot water rushing out
I do not recommend that you replace the valve unless it continues
Good luck to you
Posted on Jan 09, 2009
  • 82 Answers
SOURCE: New Avalon faucet...after correct installation,
Easy fix, no need to call anyone or take it all apart. The aerator is clogged. It is located at the tip of the spout (where the water comes out). Unscrew it and run your water, if it runs freely the aerator is clogged. Either clean it out, or buy a new one for about 6 bucks. good luck
Posted on Nov 27, 2009
co7196
  • 3433 Answers
SOURCE: water pump keeps on running my mastercraft jet
yOU NEED A FLOAT SWItch to have the pump work unattended. I have two new switches and no use for them, Where are you?
Posted on May 26, 2010
SOURCE: 2 5 3=132 3 6 4=380 4 2 7=63 6 3 6=228 8 5 2=?
((2*5)+1)((5*3)-3)=132 (3*6+1)(6*4-4)=380 (4*2+1)(2*7-7)=63 (4*2+1)(2*7-7)=228 and so....8+5+2=(8*5+1)(5*2-2)
Posted on Dec 18, 2010
I have a reliance 501 propane gas water heater how do i change a thermostate
To change a gas hot water heater thermostat you will need to first buy a new gas valve for your hot water heater. The gas vaive and the thermostat are integrated into one unit.
To replace the thermostat on a gas hot water heater you must follow these procedures....
1. Turn off the incoming water and drain the water heater.
2. remove the pilot tube, the burner gas tube and the thermocouple from the gas valve. Turn off the gas line and remove from the gas valve.
3. get a pump pliers or a wrench in behind the gas valve and turn the whole assembly CCW to remove it from the tank.
4. After appliying pipe dope or tape to the new gas valve threads, turn the new gas valve into the tank by turning in a CW direction. Be careful not to damage the small wires to the ECO. They are the little red wires on the back. If you break them the assembly is irreparably damaged.
5. reinstall the gas line, thermocouple, burner tube, and the pilot tube to the gas valve.
6. Fill tank with water. Make sure to open a hot water faucet and purge all air from the tank.
7. Check for leaks where the gas line hooks up with soapy water.
8. Relight pilot light and check operation.
9. Set the new temperature setting to a medium setting and then adjust the temperature to your likeing from there and adequate time for heating completely.
heatman101
Feb 23, 2011 | RELIANCE ELECTRIC WATER HEATER
We have a brand new rheem 40 gal elec water heater, after installation we have water leaking from the base of the relief valve, pooling up in the plastic fitting and making it way over the side all over...
Water heater should be set in a drip pan.
Otherwise, put 1 gallon bucket under TP release pipe to catch water.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#drip-pan
When you say relief valve, I assum you are talking about brass valve located on top of tank or near top of tank. This is TP valve and a pipe connects to this valve and runs down to within 6" of bottom of tank. TP valve has a small lever on it.
If you are talking about tank drain valve located at bottom of tank, then add a comment.
Following information is for TP valve.
Dripping TP valve can be caused by 3 different thing:
1) Obstruction inside TP valve. Open TP valve for a moment to flush away particles and slowly lower lever back down. See if water stops dripping, if not, then replace TP valve
2) Defective TP valve: replace TP valve. Turn off electricity to water heater. Let heater cool for several hours so you do not get scalded. Close shut off valve located above tank on cold side. Open tub spout to relieve pressure, open tank drain or open TP valve and empty water below TP valve level. If TP is located on top of tank, not much water has to be drained. Tank is under press when hot, so be careful. Put teflon tape on new valve and install with big pipe wrench by turning clockwise until TP valve is very tight.
3) Overheating tank. TP valve is temperature-pressure valve. If tank water is over 150 degrees, the TP valve starts drizzling hot water to relieve tank pressure.
Lower tank pressure two different ways:
a) turn down thermostat
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
b) install expansion tank on incoming cold water line
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#expansion-tank
Dec 19, 2010 | Rheem Water Heater Pressure Relief Valve
We have two new faucets in tub, They are both 144910 the question is how do we turn the force of the water down? The plumber that installed them could'nt help. Please advice what to do. I turned the hot...
if the water pressure is high all thru the house then turn down the valve on water main or or if well adjust cut in -cut out or valve down a bit if just high at tubs can adjust valves on water line can install a water saver behind shower head or if u have access to the valve body in wall there are adjustments on both sides where the water lines come into -----if this is about temp in ur paperwork advises how to adjust the anti-scold --remove handle and trim will see a blue and red plastic clip on valve stem adjust till temp is comfortable
Aug 22, 2010 | Delta Faucet Home
My 2007 Fleetwod ##0 FKDS TT has no hot water delivery, (cold is Fine) No water comes from any faucet (3), or shower(2). When hot water is tried a short squirt of water (Les than 1/2 sec ond) comes out and...
Check for faulty (broken/apart inside) and replace check valve on hot side of tank (top line) between line connection and tank. Stem, spring etc, of new one goes in facing into tank.
Jul 18, 2010 | RTO Atwood Water Heater - 6 Gal LP
My trans fluid gets really hot after about 2 miles from 70 deg far to 132 deg f
try changing the trans fluid and filter, if the filter is plugged up it will make the trans work harder to pump the fluid and making it get very hot
Mar 21, 2010 | 2004 Pontiac Grand Prix
Water suddenly stopped coming out of front water dispenser. Put in new filter, no change. What next?
Three different causes. Your water reservoir in the refer section is behind your crispers, this can freeze up if you have adjusted your temperatures in your refrigerator or if you have a thermostat or damper problem. Adjust your refer thermostat to a warmer setting and wait a couple of days to see if it works. 2: Bad water valve, easy to test with an electrical tester. Remove your backing plate behind the refer. Loosen your water line to the valve to make sure you have water pressure. Tighten water line. Remove screw holding valve to cabinent. Test for 120 volts at the two wires that go to your water valve solenoid,(if there are two solenoids then trace the water line to your reservoir, the solenoid above this connection is the one to test). Someone had to press the water dispenser while you are testing voltage. I usually disconnect the water line going to the reservoir to see if water comes out when the switch is pressed. If no water but you have 120 volts then replace the valve. 3: Bad dispenser switch or wiring. This is a lot more complicated to test. Some dispenser assemblies are incredibly complicated and difficult to get into to test. I usually recommend you call a technician if you have reached this point. Good Luckd, Appliance Specialists
Dec 10, 2009 | Amana 22.6 cu. ft. Side-By-Side...
3 year old kenmore top freezer, won t defrost ''no ice'' buildup behind the freezer panel I removed. no clicks on the defrost test, same result for method #2. The ice maker works ok when freezer is at...
your freezer had a heater and a bi metal behind its pannel. if they won't work properly than you would face problem like this.......contact your service authority. it cannot be solved by your own
May 14, 2009 | Kenmore Refrigerators
Home Logo
Top Kingston Brass Home Experts
john h
Tom Chichester
Are you a Kingston Brass Home Expert? Answer questions, earn points and help others
