Question about Refrigerators
My fridge freezes please could you guide me to solving the problem
  • Refrigerators Master
  • 43,501 Answers
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Posted on Mar 25, 2011
My fridge is not making any noise (dead silent), also the controls in the fridge are all flashing.
you need to consult the instruction booklet. if you do not have one please add the details of make and model so that somebody can assist. We might be able to trach a user guide down
Jun 03, 2015 | Refrigerators
Hi there we have this fridge but few days ago it started freezing food inside. we cleaned all pipes and dust behind but didn't help. can you guide us please. thanks
It looks like somebody inattentively turned full way on the freeze control. Check it. If ti sits in a proper position then the problem is with a control block itself.
Apr 24, 2015 | Refrigerators
Fridge is freezing sverything
the temp is set at 45 but the fridge is at 30 or lower. from time to time the fridge temp will come up to 33 and stay for a day or so then will go back down past freezing. I replaced the damper door because it broke part of the guide that the door travails on when opening and closing.
Jun 25, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
My refrigators freezer getting ice? what causes this and pls tell a solution to solve it
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for. I hope this will help to solve the problem.....
Aug 14, 2011 | Refrigerators
The Whirlpool fridge part of the fridge /freezer is freezing up it should be an auto defrost and the only solution at moment is to switch it on and off.please help Allan
Hoping that this will help to solve the problem of the refrigerator...
Aug 08, 2011 | Whirlpool Refrigerators
My amerian fridge freeze the fridge is frezzing everything
Good luck in solving the problem as you read the above information to get your fridge freezer back again...
Jun 23, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My gsh25jsxjss fridge is too cold. the electronic settings do not change the temp in the fridge.... even if I put it on the warmest setting... food is freezing in the fridge area
HELLO,
As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, please do check that to confirm the deflector is okay or not....
Hope this will help in solving the problem......
Jan 12, 2011 | General Electric GSH25JSXSS Stainless...
Hi i am having samsung fridge cooltsech plus silver nano i have a prob;em in my fridge that in winter the cooling in the refrigerator is very sytrong i have increased the temperatire to 7 degress which is...
If your veg is freezing you need to RAISE the temp in the fridge,if #7 is coldest,then #1 is warmest.SET IT TO #3.You should keep a fridge at +5C for best storage of CHILLED food.you should also adjust your fridge for summer and winter ambient temperatures.a fridge/FREEZER thermometer is ESSENTIAL.OTHERWISE YOUR WASTING MONEY/ENERGY.
Nov 12, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
I have lost my instuctions for this Bosch
Problem solved went to Currys and looked at the instruction book in there!!!!!!!
Jan 09, 2010 | Bosch KGU32124 Bottom Freezer Refrigerator
Hotpoint fridge
what is the model number of this unit
May 17, 2008 | Refrigerators
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
