Put new batteries in my remote and it doesnt work still is there anything else i can do to get my remote working again
  • 718 Answers
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls.
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to
each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote.
If you do then the problem might not be the remote but the sensor on the set.
If you need a new remote then;
In the USA look at; www.remotes.com
In the UK look at; http://www.espares.co.uk
Posted on Mar 25, 2011
My rmt-05 remote is not working after i put in new batteries
have you checked the polarity one the new batteries you installed? (flip the batttery updside down)
Aug 29, 2014 | Westinghouse RMT-05 TV Remote Control for...
Rpn 479v p x
Here is something you can try to see if it is transmitting out from the handset
Put your new battery in and push and hold down the button and look at the transmitter LED through a digital camera, a phone camera works fine. you don't need to take a picture, just look at the LED trough the camera.
If its transmitting you will see the LED light up.
Test this on your TV remote as you know this one is working so you know what to look out for.
If its not transmitting you know its the handset at fault, if it is transmitting its probably the recever.
Hope this helps a bit.
Feb 09, 2014 | Vehicle Parts & Accessories
I put new batteries in my camera-but doesnt do anything. I left camera on,I think and then thought batteries died so then replaced with new ones.now nothing works.
This happened to me as well. I took the batteries out and put new ones in three times (same batteries). The third time the camera started working again as soon as I closed the battery compartment and tried on "on" button.
Mar 20, 2011 | Kodak EasyShare C533 Digital Camera
Skytech model no. sky-3001 changed batteries in remote and the transciever now i get nothing you can manually get fireplace to turn on using the transciever but when you switch it to remote and try to use...
You have to get the remote and transceiver to talk to each other. Remove all the batteries and wait a couple of minutes
before replaceing them. Place the transceiver in the REMOTE
position, press and hold down the LEARN button, and then
press the MODE button on the remote control. A change in the
beep tone will be heard and you have MARRIED the two devices. Should solve the problem.
Dec 18, 2010 | Skytech 3301 Thermostatic Gas Fireplace &...
My remote show it is supposed to work but when i try to turn on my cable with my dish remote it doesn't do anything
  1. open the door on the right side of your receiver and press 'Sys Info
  2. press record multiple times on your dish remote
  3. press select
  4. if this doesnt work change the batteries and try again
  5. if this doesnt work call Dish for a new remote
Jan 26, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Harmony 550 remote - buttons not working
Hey!
Unfortunately most things you need to do would require access to the Harmony Remote Software. However, the only advise I would have is for you to remove the batteries and try putting them back in.
Sorry I couldnt be more helpful...
-Kennedy
Dec 25, 2009 | Logitech Harmony 550 Remote Control
My remote control doesnt work
if remote is ok then problem is in remote receiver in the set
Sep 03, 2009 | Astar LTV2001 Television
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
