Question about Canon PIXMA iP3000 InkJet Photo Printer
How do I find the maintenance screen - Canon PIXMA iP3000 InkJet Photo Printer
  • 436 Answers
How to remove on screen preventive maintenance time m5
there is no M5 preventive maintenance only M2 and M3 please conform
May 10, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
How to enter maintenance mode KM 3050
Press the STATUS KEY
With the numeric key pad key in 10871087 (if done correctly the display will change and say ENTER MAINTENANCE ITEM)
Enter 201 with the numeric key pad (follow the steps below):
1. Press the start key. 2. Select the [INITIALIZE].
3. Press the start key.
4. Press the center of the + keys. Be sure to press three + keys displayed in order. The touch panel is adjusted automatically.
5. Press the indicated three + keys, and then check the display.
6. Press the stop key. The screen for selecting a maintenance item No. is displayed.
Completion Press the stop key. The screen for selecting a maintenance item No. is displayed.
Now to exit maintenance mode key in 001 with the numeric key pad
Press the Start Key ( you should be back to the status screen, press copy key to go back to the copy mode)
Remember do not go to any other maintenance mode or make any other changes.
Dec 03, 2013 | Kyocera Mita KM-3035 All-In-One Laser...
Hi, Have a Kyocera KM4050 copier/scanner/printer with a touch screen. The touch screen is out of alignment (i.e. where you point does not align with what is sensed by the touch screen) and needs...
First you have to get into the maintenance mode. It is important once in there you don't make any changes other than the one I tell you or you could damage the machine.
To get into maintenance mode do the following:
Completion
Feb 09, 2011 | Kyocera CS-2050 Black and White Copier
How do I reset the maintence kit counter for an Infoprint 1532?
This is a lexmark based machine with IBM logo's
1 of the 2 options should get you squared away
---- Option 1 ----
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
This counter is reset by the servicer after a "80 Scheduled
Maintenance" message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
1. Select Reset Maintenance Count. Pressing Select causes the
maintenance page counter to reset to zero.
- Reset Maintenance Count Saved displays momentarily.
When the reset operation is complete, the menu returns to
the Printer Setup Reset Maintenance Count screen.
---- Option 2 ----
Maintenance page count
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count from the Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count screen.
Oct 19, 2010 | IBM Infoprint 1532 Laser Printer
How do I reset my maintenance required light on my 2009 Avalon?
SWITCH IGNITION ON WITH ENGINE OFF.PRESS SMALL ROUND BUTTON ON LOWER RIGHT OF THE SPEEDOMETER UNTIL IT DISPLAY ODOMETER.THEN TURN OFF IGNITION SWITCH OFF.PRESS AND HOLD SAME ROUND BUTTON LOWER RIGHT SPEEDOMETER TURN IGNITION TO ON WITH ENGINE OFF.CONTINUE TO HOLD BUTTON FOR AT LEAST 5 SECONDS UNTIL IT DISPLAY INDICATES 000000 AND MAINT REQUIRED LAMP WILL EXTINGUISH.RESETTING IS COMPLETE.
Oct 19, 2010 | 2008 Toyota Avalon
How to do a print test on canon mp460 printer after replacing cartridge?
Print the nozzle check pattern to determine whether the ink is being ejected properly from the FINE Cartridge Nozzles. Use this function when the printed results are blurred or the color is incorrect. sikaku.gif Performing Maintenance 1 Press [ON/OFF] to turn ON the machine.
2 Press [Menu].
3 Display the Maintenance screen.
(1) Use [l_mark_s17.jpg] or [r_mark_s18.jpg] to select <Maintenance/settings>, then press [OK].
The Maintenance/settings screen is displayed.
(2) Use [l_mark_s20.jpg] or [r_mark_s21.jpg] to select <Maintenance>, then press [OK].
The Maintenance screen is displayed.
(3) Use [t_mark_s23.jpg] or [d_mark_s24.jpg] to select the setting item, then press [OK].
The setting screen for the selected item is displayed.
sikaku.gif Printing The Nozzle Check Pattern 1 With the machine ON, load a sheet of A4- or Letter-sized plain paper in the Auto Sheet Feeder.
2 Print the Nozzle Check Pattern.
(1) Display the Maintenance screen.
(2) Use [t_mark_sas25.jpg] or [d_mark_s26.jpg] to select <Nozzle check>, then press [OK].
The pattern print confirmation screen is displayed.
(3) Use [t_mark_s28.jpg] or [d_mark_s29.jpg] to select <Yes>, then press [OK].
The nozzle check pattern is printed.
Mar 31, 2010 | Canon PIXMA MP460 All-In-One InkJet...
How do i reset the maintenance count?
1. Select Reset Maintenance Count Configuration menu.
Mar 30, 2010 | IBM Infoprint 1532 Laser Printer
2007 Lexus ES350. Mater Warning Light is activated for oil maintenence. How do I shut it off?
if you do not have navigation system.
  1. Turn the engine switch OFF..
  2. While pressing the trip meter reset button, set the engine switch to IG-ON mode. Continue to press and hold the knob until the trip meter displays 000000.
if you have navigation.
  1. Push the "INFO" button
  2. Touch "Maintenance".
  3. Touch the desired button Delete All : To cancel all conditions which have been input. Reset All : To reset the item which has satisfied a condition. If "ON" is selected, the system gives maintenance information with the "Information" screen when the system is turned on. If "OFF" is selected, the "Information" screen is disabled.
  4. Input the conditions. Notice of Date : The next maintenance date can be input. Notice of Distance : The driving distance until the next maintenance check can be input. "Delete" : To cancel the date and distance conditions. "Reset" : To reset the date and distance conditions.
  5. Touch "OK" The screen returns to the "Maintenance screen.
Mar 05, 2010 | 2007 Lexus ES 350
The printer is showing ready maintenance on the screen
The printer keeps track of how many pages you have printer and will notify you when you need to install a maintenance kit and perform a maintenance reset. You can order a kit here and there is a video on how to install and perform the reset.
http://www.fastprinters.com/dell-fusers-maintenance-kits.asp#W5300
Mar 17, 2009 | Dell W5300N Laser Printer
We have a Phaser 8560 Printer and we are getting the message "maintenance kit low" message. What does this mean and how do we fix it?
This will require servicing:
The maintenance kit contains a maintenance roller that keeps the surface of the Imaging Drum clean and oiled.
NOTE: Order a new maintenance kit when the Display Screen displays a message that the maintenance kit is low. Replace the kit when the Display Screen prompts you to replace the maintenance kit. Both a Standard Maintenance Kit and an Extended Maintenance Kit are available for the Phaser 8550 and 8560; however, only a Standard Maintenance Kit is available for the Phaser 8500. An Extended Maintenance Kit will not be functional with the Phaser 8500.
WARNING: The printer's interior may be hot! Do not touch the hot surfaces.
Once you have the part: instructions:
  1. Open the door on the right side of the printer.
  2. Grasp the maintenance kit (labeled A) from the maintenance kit slot and pull the kit completely out of the printer.
  3. Insert a new maintenance kit and push the kit completely into the maintenance kit slot. Follow the illustrated instructions included with the maintenance kit for full installation and disposal information.
  4. Close the door.
This will be on the right side of the printer.
This will need to be replace every 10,000 sheets of paper.
  1. Close the door.
Apr 03, 2008 | Office Equipment & Supplies
Canon PIXMA iP3000 InkJet Photo Printer Logo
old marine
old marine
