Question about Makita 14" Die Grinder
Plug in makita die grinder, turn on, runs for 2 to 3 seconds and pops breaker. It is a variable speed grinder
  • jamespg Mar 25, 2011
    idiot
    It is not the circuit. The switch seems fine. The motor is not seized, but, could the motor windings have broken down.
    President:
  • 2,468 Answers
Does it run freely?as in not seem to be lugging from bad bearings in the motor shaft,then check the speed control board for a shorted triac/scr transistor
Posted on Mar 25, 2011
  • 10,865 Answers
Hello jam.... If there are other motors or several lights on this circuit, it will pop the breaker again.
Find an outlet near your electrical panel which does not have other motors plugged in to that circuit and try it there.
At least then you will know if it is the circuit or the actual die grinder. Joe
GD0800C speed control not working
I would check the armature, specifically the magnet on the end, or check the armature commutator for partial shorts
Apr 11, 2013 | Makita 1/4" Variable Speed Die Grinder...
How do you reset a makita gd0600 die grinder?
How much wear has it had. The carbon brushes could have worn out and need replacing.
Jan 28, 2012 | Makita Gd0600 Die Grinder
Unit has hard time starting, need to turn wheel, only runs at slow speed
you have a problem with the bearings or the motor/brushes are burnt. Does this tool arc when running. If so I would check the brushes first, unplug the tool and remove them and while they are out rotate the motor slowly and look at the commutator bars for excessive discoloration or unusual wear.
May 08, 2011 | Makita 9565CV 5" Variable Speed Angle...
Gr450 grinder variable speed has stopped woking, grinder goes to full speed when turned on with no affect from variable speed
i woulkd take switch off and rewire it. It is not a very difficult thing to do. As you take it apart just pay atention to where the speed control wires are running from and go from there. If it still dosent work than the switch is burnt out
Apr 17, 2011 | Delta GR450 ShopMaster 8'' Variable Speed...
I want to learn how to repair or rebuild makita grinders
i worked for makita factory service center as a senior technician and never heard of a video...
Apr 09, 2009 | Makita 9565CV 5" Variable Speed Angle...
My makita angle grinder is making a crackling sound I replaced the brushes, but it is still making the same sound
OK one of a couple things the brushes night need seated with a stone for this purpose or the armature or field is bad. Remove the brushes and look at the commutator thru the tube and see if there is a bar or 2 that has discoloration or is raised. Let me know if I can help further.
Mar 06, 2009 | Makita 9565CV 5" Variable Speed Angle...
Makita 14" Die Grinder Logo
389 people viewed this question
Top Makita Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
bob walter
bob walter
Level 1 Expert
Are you a Makita Grinder Expert? Answer questions, earn points and help others
