Question about Maytag MSD2651 HE Side by Side Refrigerator
I have water leaking under freezer side of door. I turned the ice maker off, turned off the water to the fridge, cleaned out the ice behind the panels, and put it all back together. Every couple of days I chip the ice off of the bottom of freezer; if I forget I get a puddle of water on my hard wood floor. The plug is in the drain hole. Is the heat element suppose to evaporate everthing when it goes through the defrost cycle? How do I quit having water run all over my floor?
  • kellergoose Mar 25, 2011
    Sorry, it's actually a Maytag 3; the Model is MSD2454GRW.
  • Maytag Master
  • 43,501 Answers
Hi, The drain hole is plugged with debris or ice...
Just had to thaw my own out tonight, it was doing the same thing... Take the bottom draw out and maybe the bottom shelf and then you will see the ice buidup in the back and on the floor... Thaw it out and make sure the drain hole is open... then you will be okay again...
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 25, 2011
My GE fridge is leaking water on the freezer side
This would be due to the defrost drain being clogged. The automatic defrost cycle melts the frost on the evaporator every few hours and the water from that is suppose to flow down a drain tube, if the drain becomes restricted the water will leak out the freezer door. Here is a link to some instructions I put together on how to clean it out.
Defrost Drain Cleaning
Jul 18, 2010 | GE Refrigerators
Water line for ice maker/cold water leaking underneath
Check your connection at the bottom of the freezer door, behind the kick plate. Also pull out your crisper drawers and check the cold water reservior. If this only leaks when the water dispenser is pressed I would try to track the line from the bottom of the freezer door back to where it goes into the refrigerator (behind the crispers) to the cold water reservior.
If you absolutely have to lay this fridge down lay it on it's BACK only. Also be sure to let it stand upright for at least a half an hour before you start it back up.
Good luck with this!!
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
How do i turn my ice maker off? i have a viking side by side and the ice maker is just pouring water in my freezer...its a mess!
Turn the water off under the sink where the small line starts that goes to the fridge or there may be a cut off directly behind the fridge in the supply line.
Your water inlet valve may be stuck open. It's where the water supply connects to the fridge.
Dec 11, 2009 | Viking VCSB423 Side by Side Refrigerator
Frigidaire fridge leaks where ice maker is on
Your leaking problem gives two possibilities. The water control valve for the ice maker side is defective and while shut off the water will continue to slowly flow and leak into the freezer compartment. The other possibility id the condensate defrost drain is blocked and frozen over behind the rear panel of the freezer and at the bottom of th coils. I believe your defrost condensate drain has a blockage of ice and will need to be defrosted and clean the condensate line from the freezer to the condensate collection plate below your refrigerator. Most times the blockage begins slowly until the opening of the drain hole under the evaporator freezes itself shut. Below is a link to some solutions I have collected over a period of time. Also has a short movie that makes the repair look simpler. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
Sep 23, 2009 | Frigidaire FRS26R4A Side by Side...
Water is leaking into fridge, ice maker making hollow ice
Make sure when the icemaker fills its not causing the leak ...... other than that you have a clogged drain in the freezer section .... easiest way remove everything unplug for 24 hrs with door open .... manual defrost ....hehehe ..... plug back in u should be ok if reoccurs call for service
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Leaking water from freezer side-by-side GE refrigerator
Hi, It sounds like the defrost drain is plugged. You will need to remove the rear inside panel in the freezer and unp,ug the drain. Once you remove the rear panel, you should see a collestion of ice under the evaporator coil. Locate the drain hole and clear the ice. Flush the drain hole out with hot water to make sure it will drain. You might have to run a wire through the drain or you can flush water through it with a baesting serienge.
I hope this helsp you. Please let me know if I can assist you further.
Vic
Jul 01, 2009 | Refrigerators
Water leaking into the fridge. I think it is coming from the ice maker. If I turn the ice maker off inside the freezer, then the water problem is worst. So, is there a way to cut of the supplier of...
There should be a cutoff valve on the line going to the fridge. This will cutoff water dispenser, as well, if it has one. It may be behind the fridge or under the sink, or???
More help?, let me know.
May 09, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice build up in bottom of freezer
Check the ice maker. sometimes they get cracked a will leak water into the freezer compartment. Also check the ice maker fill tube for leaks or someone could have spilled something. Although this is tipical of a clogged drain. What happens is when the fridge go into derfost, it will melt all the frost that is on the evaporator, turning it into water. The water drains down to a trough under the evaporator and down a drain hole in the trough ( this trough is behind the evaporator cover ) Removing the melted frost from the freezer. If that drain is clogged, the water cannot leave the freezer. Then when the fridge starts back up ,it will freez the water that was not drained. After repeated defrosting the water will fill this trough and run off into the bottom of the freezer to be frozzen when the fridge starts to cool again.
Nov 16, 2008 | Refrigerators
No water to door
Did you change any settings resently or move the fridge? Water line could be kinked. Could be a frozen water line. If the ice maker is set on rapid ice, turn it off. You could turn the temp setting down for a day to see if that helps. Do you have any leaks behind or under the fridge? Check the filter again, make sure you pulled the shipping tag off and that it is seated properly. Freezer temp could be set too cold. Make sure the freezer door closes properly and that there isn't anything hendering it.
Jul 07, 2007 | Kenmore 56722 / 56724 / 56726 / 56729
Water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Jun 05, 2007 | Hotpoint HSS25GFP Side by Side...
Maytag MSD2651 HE Side by Side Refrigerator Logo
362 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
