Question about Envision L32W761 32 in. LCD TV
My envision 32 inch LCD does not turn on all of a sudden. No power at all. I unlugged and plugged back in, but nothing.
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 25, 2011
Testimonial: "thank you"
I have a 32" AOC Envision L32w761 LCD hdtv with no
There are only two things that can cause this problem -inverter and T-con. Since you have already replaced the inverter, it can be nothing other than the T-CON or LCD controller. Replacing the same should resolve the problem. On a side note the inverter/T-Con problem can be isolated easily. The purpose of the inverter is only to light up the backlight of the panel. So when it fails you will still have a faint picture that can be seen if you flash a flashlight on the screen. If you would like me to find you the replacement T-con let me know the part number and I will get you the link to the part.
Sep 07, 2011 | Envision L32W761 32 in. LCD TV
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
I have a Sharp 32 inch 720p tv, power works, no other buttons do
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
Nov 05, 2009 | Sharp LC-32SB23U 32 in. LCD TV
My Vizio 32 inch has a black screen. The Vizio emblem doesn't turn white when powered on. I have already replaced the power module and the inverter with no success.
I have had the same problem. I called vizio they told me how to reset my tv. It did not help me, However, maybe it will help you. They said turn the power off, Unplug it hold in power button for 30 seconds then plug it back in and power it back up. My white light flickered and then nothing. So I am going to end up buying a new tv all together.
Oct 11, 2009 | Vizio VW32L 32 in. LCD HDTV
Chimei CMV 938D 'Out of range' error message only when using DVI Connector on specific resolution and color depth
I know this sounds obvious but- I had the same problem, and turns out the cord want plugged in quite properly at the back of the monitor. This may not fix every problem, but, I suggest you check the cord pligged in at the back of the monitor is firmly in there and restart, then if you still get the problem, contact the company.
Jul 21, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Envision LCD
That mean your logic board of the LCD need repaired or replaced.
Apr 06, 2008 | Envision EN-7100e 17" Flat Panel LCD...
AKAI 32" LCD TV/DVD
that is the code of a microchip have a tech replace the microchip on your tv.good luck
Jun 03, 2007 | Akai CTS2550 25" TV
Envision L32W761 32 in. LCD TV Logo
799 people viewed this question
Top Envision Televison & Video Experts
matt martin
matt martin
Are you an Envision Televison and Video Expert? Answer questions, earn points and help others
