Question about Blue Flame Charmglow 30K BTU Propane Vent Free Space Heater
Charmglow 30kBTU NG blue flame heater with the digital thermostat. Has worked fine for a couple of years. Now pilot is fine, but when main flame lights up, it's very unstable. Goes back & forth from big to small and then goes off within 30-40 seconds. Gas pressure to the unit is fine. No dirt, it's been vacuumed a few moths ago. Any suggestions to troubleshoot it?
    Top Expert:
  • Blue Flame Master
  • 6,889 Answers
Possible clog in pilot tube and bad pilot generator flame sensor
Posted on Sep 11, 2017
2 Suggested Answers
johnrodgers1
  • 80 Answers
SOURCE: Charmglow ventless gas fireplace burners won't ignite
is pilot flame on the thermopile good, pilot flame should cover the thermocouple and thermopile if unit has both
Posted on Feb 06, 2010
Pilot wont stay lit an when it does runs for awhile then shut off
Most likely this is cuased by one of two problems. 1) your pilot light is dirty and or obstructed by some bit of dust. 2) the thermocouple is not being hit by the flame properly or is defective.
To tell the differance light your pilot and pay close attention to it until it goes out. If your pilot flame is small, yellowish, or fuming badly it most likely needs cleaned. If your pilot is crisp and blue but goes out with seemingly no warning it may be your thermocouple. It should be one of these two problems which are easy to fix. Now if by some chance everything shuts off while the heater is burning it is a bit trickier. You will have to listen for a pop and try and find the snap disk that is shutting off flow. Remember automatic shutoffs serve a purpose and should never be bi-passed. If you cannot fix it with a good cleaning call a repair man.
Dec 14, 2013 | Blue Flame Charmglow 30K BTU NG Vent Free ...
I can"t keep my pilot light going.
I am assuming this is a patio heater. I have extensive experience with gas appliances. The most common problem with pilot light issues is the thermocouple it is a probe that is directly over the flame , it senses the flame and allows gas to flow, if it senses no flame the gas valve closes. Patio heaters are also quite finicky, sometimes a simple adjustment of the thermocouple will do the trick. Also thorough cleaning of the orifice is necessary at least 1 x a year.
Dec 12, 2011 | Pool & Spa
Polit will not stay lit
the thermal coupler is bad that is the part right beside the pilot lite with the tube that goes to the gas valve.
Dec 16, 2010 | Blue Flame Charmglow 30K BTU NG Vent Free ...
Jan 07, 2010 | Blue Flame Charmglow 30K BTU Propane Vent...
Pilot light flame is mostly yellow. LP gas
Thr thing you need to do is take the pilot assembly all apart and blow the dust and dirt out of it.
After burning for many, many hours the air that is move up through the pilot assembly leaves dust and dirt which plugs off a bit of the air and makes the flame run rich. Meaning that it does not get enough air mixed in for complete combustion.
When you clean it you will see the dirt and dust com out of it.
Reassemble carefully just as you took it apart and it will be back to working great again!!
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 23, 2009 | Blue Flame Charmglow 30K BTU NG Vent Free ...
Fireplace will not start. I have not had it lite since last winter. I turn to pilot and wait then hit ignite. I get a spark but the pilot light does not light.
your line mite be stopt up get a mach and turn on you gas and see if i lights up if it dont your eather out of gas or your gas holes whare the flame cums out is stopt up
Dec 16, 2009 | Blue Flame Charmglow 30K BTU NG Vent Free ...
The flame keeps intermittently going out on my gas heater
The air intake hole on the pilot is probably clogged with a small bit of dust or hair. Look to see if your flame is yellowish instead of a nice blue on the pilot. Your pilot should always be blue, also look to see if the pilot is touching the thermal couple. This is a easy fix if your flame has a yellow tip to it and is barily missing the thermal couple. Turn off your heater for 30 minutes to allow it to cool. Next locate the small air intake hole on the pilot it should be roughly a 1/16 diamiter hole. Get a bendy straw and use it to blow through the hole (gently) any pressure over 30 psi will damage the unit. Reassemble and test light your pilot. A low or yellow flame on your pilot cuasing it to miss the thermal couple activates your heaters safety shut off system. These systems are there for a reason, NEVER attempt to adjust your gas controls, If it does not work and cannot be fixed with a good cleaning, call a repair man.
Nov 24, 2009 | Blue Flame Charmglow 30K BTU NG Vent Free ...
Blue Flame Charmglow 30K BTU Propane Vent Free  Space Heater Logo
76 people viewed this question
Top Blue Flame Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Blue Flame Pool and Spa Expert? Answer questions, earn points and help others
