Question about Gateway Computers & Internet
Window could not start because following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM on my notebook
  • 591 Answers
First try to boot with a bootable Windows CD, log in a terminal session (command prompt) than perform a CHKDSK /R command, if it does not work try a WINDOWS REPAIR from the same bootable Windows CD... if you finally get it going you should scan the computer with a GOOD UP TO DATE anti-virus... (just in case)
Cheers!
Posted on Mar 25, 2011
I have an evo n610c and it started up with a message that says, "Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair thi
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
Feb 15, 2013 | HP Compaq Evo n610c Notebook
Following files missing or corrupt: \windows\system32\config\system
Well this means one of important files needed to start Windows is corrupted (it's a registry file).
I'd recommend repairing Windows installation. If you have Windows XP and also the Original Windows CD follow: this guide.
Dec 31, 2011 | Dell OptiPlex 740 (BPCW6TT) PC Desktop
I can't open windows xp i got this message:\r\n"unable to read file C:\windows\system32\config\software " I tried to fix it thru recovery console copying the i386 file but nothing happenned Help me please
hi You need to get a Windows XP from someone and follow these instructions: Windows could not start because the following files is missing or corrupt \WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
1. Insert and boot from your Windows XP CD. 2. At the first R=Repair option, press the R key 3. Press the number that corresponds to the correct location for the installation of Windows you want to repair. Typically this will be #1 4. Enter in the administrator password when requested 5. cd \windows\system32\config 6. Depending on which section was corrupted: ren software software.bad or ren system system.bad 7. Depending on which section was corrupted copy \windows\repair\system copy \windows\repair\software 8. Take out the CD ROM and type exit
Aug 28, 2010 | Microsoft Windows XP Home Edition
I have a asus eeepc 900 netbook.suddenly it stop booting & everytime showing"windows could not start because the following file is missing or corrupt:Windows/system32/config/system.You can attempt to...
/WINDOWS/SYSTEM32/CONFIG/SYSTEM
You can attempt to repair this file by starting Windows Setup using the original Setup CD-ROM
Select “r” at the first screen to repair
So then i click r at the first screen and nothing happens...It keeps on repeating to repair on and on with the same message after i clicked r. I can't even access to the window...what can i do???
Jun 15, 2010 | ASUS m6n Notebook
I have toshiba L300 pc laptop, i tried to formati
kindly follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 20, 2010 | Toshiba Satellite Pro L300 Notebook
Windows/system32/config/system is corrupt
One of following will work:
http://www.help2go.com/Tutorials/Windows/C:%5Cwindows%5Csystem32%5Cconfig%5Csystem_missing_or_corrupt.html
http://www.techsupportforum.com/microsoft-support/windows-xp-support/312090-windows-system32-config-system-missing-corrupt-files.html
http://en.kioskea.net/forum/affich-22815-windows-system32-config-system-is-corrupt
http://support.microsoft.com/kb/307545
Mar 20, 2009 | Microsoft Windows 2000 Professional for PC
Compaq Presario 1700 PC Notebook Problem gives me a screen windows will not strat because file is corrupted or missing file is \windows\system32\config\system
Is this XP?
Do you have the XP cd or the recovery cd's. This needs to be fixed by performing a Windows repair.
missing or corrupt: \windows\system32\config\system"means that the OS,XP, is missing an essential file to run.
Or it could mean that your hard drive is failing. Is the hard drive noisey?
Leave me a comment,here
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 12, 2008 | Compaq Presario 1700 Notebook
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
