Question about Kitchen Ranges
I have a 3 bulb flourescent light that had two magnetic ballasts and I want to replace it with a T-8. What is baffling me is that from one set of sockets on one side there are 6 wires, 4 blue and 2 red and on the opposite side there are only 4 wires, 2 red and 2 yellow. How do I hook up this new type of ballast with the wire arrangement that I have? Thank you very much for your assistance. dave
  • 436 Answers
  • 1 Turn off the circuit breaker that's delivering the power to the light fixture.
  • 2 Test the feed wires with a touch-type voltage tester before you touch them. Press the button on the tester and touch the tip of it to each wire to make sure the circuit is dead. If the tester beeps or lights up then the circuit is still live. Try additional breakers until you find the correct one.
  • 3 Strip about 3/4 inch of insulation from the ends of each wire coming from the ballast if they aren't already prepped for wiring. Use the smallest setting on the wire stripper to prevent snapping the wires when you strip them.
  • 4 Take the single red wire from the ballast and insert its tip into one of the two pressure-slots on top of one of the sockets on the same side of the fixture that the red wire is facing.
  • 5 Take a 6-inch length of similar red wire and strip 3/4 inch of insulation at each end, then insert one end into the second slot on the socket that already has the red ballast wire attached and insert the other end into the other socket on that side.
  • 6 Insert the tip of one of the blue wires into the slot on one of the sockets on the other side of the fixture.
  • 7 Insert the tip of the second blue wire into the slot on the other socket on that side of the fixture.
  • 8 Connect the white wire from the feed circuit to the white wire on the ballast and connect the black wire from the feed circuit to the black wire on the ballast. Make sure the wire connectors are on tight and wrap electrical tape around the connections.
  • 9 Put the fixture back together and install the fluorescent tubes as per the manufacturer's instructions. Turn the circuit breaker back on.
  • Posted on Mar 25, 2011
    • belost564 Mar 25, 2011
      I have a 3 light fixture with ten wires not counting the two power leads. You answered for a four wire solution?????? Or at least the answer sent me was for only four leads in the fixture.
    • charles urban Mar 25, 2011
      I apologize. Do you any manufacturer or model info?
    How to fix flourescent light fixture
    then I would suggest you invest in new units not just bulbs . new ballast cost more than complete lights do .
    Feb 08, 2016 | Home
    How to replace a ballast in a fluorescent light
    Open the light remove ballast go to hardware store get a new replacement. Take pictures so you know how to rewrite it.
    Sep 08, 2014 | Philips Ceramalux 1000 W C1000s52...
    We have fluorescent cove lights in the living room. We think the "starter" is bad, but we can't locate the "starter". Can you help? We have tried switching the working light bulbs...
    Very few flourescent lights have "starters" these days. If it does have a starter, it will be a visible cylindrical object usually located at either end of the fixture. More likely it's the ballast that is bad. Turn off the power and remove the cover to the fixture. The ballast will have a lot of wires coming out ot it. Take note as to where all the wires are attached, remove it, and take it to a hardware store or Lowes or Home Depot to get a replacement. Make sure it is an _exact_ replacement. Sometimes it's easier and cheaper just to replace the entire fixture as some of the older ballasts are expensive due to there being replaced by newer technology.
    Dec 10, 2010 | Sli Lighting 48" Fluorescent Bulbs 34...
    I installed the PR180 switch in my garage with a 4ft dual t-8 flourescents bulbs. When the motion sensor timer turns the light off the flourescent bulbs stay slightly lit, as if it were on a dimmer...
    There is nothing wrong with the switch or your wiring. The Leviton R01-PR180-1LI is not designed to work with flourescent lights. A lot of electronic controls will bleed through a small voltage when in the "OFF" state. It's just enough voltage to make the ballast in the flourescent light try to fire but not enough to let it fire the way it is supposed too.
    What you need is a motion switch that is rated for flourescent lights, such as this :-( :
    http://www.smarthome.com/2520W/Leviton-ODS10-IDW-Commercial-Grade-Wall-Mounted-Occupancy-Sensor-White/p.aspx
    Nov 28, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
    Top light does not work. Florescent bulb &
    even if its a new slim-line unit(T-8 or T-5) and covered from stove smoke,grease,etc. the electronic ballast can go bad, or the contacts on the lamps socket can get dirty from the stoves use
    Oct 21, 2009 | Kitchen Ranges
    Wire connection from lighting ballast
    What you do is cut the wires from the old ballast that feed to the fixture end connectors then 'wire nut' the new ballast wires to the old wires.
    Oct 02, 2009 | Electrical Supplies
    Flourescant lights flickering
    is there a ballast or a starter? if there is a starter (little silver metal or white plastic can), then replace the transformer inside the lamp housing. if there is a ballast (long black rectangle with many wires) and you replaced that and the lamp, then there must be a power drain in the unit somewhere.
    Aug 25, 2009 | True GDM-12 Refrigerator Commercial
    Ballast / dimmer compatability
    i believe thats a magnetic ballast couldn't find it on the net... but anyway use a magnetic type dimmer for a magnetic ballast and an electronic flourescent ballast dimmer for the same..
    Jul 01, 2009 | Lightolier Ivory Galaxy Slide Dimmer...
    Under cabinet light not working
    probably not defective bulbs. Flourescents use either a starter and transformer or a ballast. When lights are weak, could be either. Very simple to change too. One other thing, could be connections that go into the lamp holders. If not good connections, light will be dim. On a stretch, if unit is located in an area that us lower than about 50 degrees, this could cause them to be dim. Check ratings on ballast/ starter and transformer. Finally, if voltage is either too high or too low, this could be a dimming problem too. If it has worked in the past, and this is a current problem, then chances are it's not the voltage but may want to check it anyway to eliminate that possibility.
    Feb 05, 2009 | Jenn-Air Attrezzi JSM900 Stand Mixer
    Fluorescent dimmir
    The dimmer you purchase needs to be compatable with the ballasts of the C.F. light. A compact flourescent potlight has a ballast, if your replacing incandescent bulbs with compact flourecent lamps
    you still need a flourescent dimmer. Remember a ballast is like a transformer! If you compact flourecent fixture has a ballast by Lutron. then you need a lutron dimmer as there ballasts are not officially compatable with other dimmers, allthough I've seen them work. My advise is buy Pass & Seymour (Legrand) or Leviton.
    Jan 21, 2009 | Pass & Seymour / Legrand DFB600-M 600VA...
    Kitchen Ranges Logo
    129 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
