Tv is kicking off and on - Televison & Video
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
If pix is small i know repair procedure.
Posted on Aug 03, 2008
Lambretta kickstart problems
There can be several reasons for this. If there is a lot of chattering noise from the kick start then there is a mechanical interference between the kick start teeth on first gear and the kick start plunger. If there is no noise but the kick start does not return check if there is enough pre-load on the kick start return spring or that the kick start arm is not catching on an external part of the engine such as the exhaust tail pipe. Either way, you'll end up taking the side case off so tip the scooter on it's L/H side so you don't have to change the gearbox oil but remember to put it all back together before standing the bike upright, else the oil will pour onto the floor.
Jul 27, 2014 | Lambretta GP 125/150/200 LI 125/150 SX...
Philips TV keeps kicking off(lose of power)
moses1,
What you have there is a PTV915 chassis that has an Ssb board failing in it... To be more precise the smt (Surface Mount Technology) caps on the Ssb are failing. The board is mounted on the Lsb (Large Signal Board) vertically, just behind the tuner.
The module itself is Philips original p/n# 313912725871 and has been subbed to Philips p/n# PH3912725871 they're about $275.00 dollars.
Or you could take a risk and order one. But I'd still have the technician come out and install it for you... There are some star screws, which Philips has some infinity for, that are kinda difficult to get to and they need to be removed to access the module and extract it...
Hope this helps!
Bill
Nov 10, 2007 | Philips 50P8341 50" Rear Projection...
Passing gear is not working
aka> passing, kickdown and TV cable failure.
which transmission?
30 or
32RH?
Kick down happens on all transmissions this way.
1:kick cable. (and or vacuum modulator, Hill)
2: TCM brain does all that magic. (PCM data (load, rpm,etc)
and some early years, are 1/2 and 1/2 , yes.
ill look up yours now to see which.
i look at FSM page 75+
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
shows it has a Governor, so if it fibs about trail speed, sure no passing gear.
ok page 87 shows TV cable.
page 90 lists the causes. read that?
transmission must not slip, does it, flogged up hills?
TV cable dead, or adjusted wrong. end to end, and detent valve at trans case. must move full range.
gov, failure (or line pressures excessive)
coke bottle under throttle, nah
valve body issues aplenty.
this car has no TCM
only a signal, TCC lockup wire from PCM to clutch lock sol.
so , its a 100% Hydramatic trans, with NO BRAIN box.
my guess, is the KICK cable is DEAD> or set wrong.
aka, kick down cable.
Jul 11, 2014 | 1998 Jeep Wrangler
When i hook my television up to my computer after a minute the tv goes blank and I just have computer again
Might be resolution. Don't go higher than 1360 x 768. Even though you saw an image, it might be set too high. And the tv will just, as you say, "kick it off".
Feb 12, 2014 | Televison & Video
My tv doesnt show any images and the panel has the light of fopc on
Common problems on Sharp LCD tvs as tv it is agings,tv Power LED and OPC LED,LEDS lights flashes happen to mine Sharp tv many times and i had it two years,do this many times,tries to turn on the tv.By trying pushes the power button the remote again if OPC LED and power LED,LEDS lights flashes together.Everytimes the OPC LED and power LED lights flashes,just push the power switch on the tv remote and wait for the tv main Tuner signal board to kick in the backlight to light up tv to work.Have to do this like three or four times before the power supply board to kick it in to make Tuner signal to work.If u require to this more than 5 or 6 times the main tv Tuner signal board it is shorting out and beyond trying to kick in by the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
May 31, 2011 | Sharp LC-32SB24U 32 in. LCD TV
Tv comes on and then goes off in seconds like breaker is kicking
Yes,Ur tv still have sound after the video dies in a few sec.?Yes,there are sound than ur LCD inverter board is dead.No,there are no sound than ur T-con board is dead.U have a little machanical skills take ur tv aparts.The LCD inverter board is a long board in shape and it sit sides of the tv right or left.The T-con board sit at the botton center of the LCD screen.Tries websites like Shopjimmy.com,Ebay.com to buy refurbish boards either the LCD inverter board or the T-con board for the replacement.
May 11, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Broke tv
From what I have read - its a faulty Y SUS board. There seems to be replacements around at USD35 but I have yet to lay my hands on one
Jan 16, 2008 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
Open Questions:
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
