What is the wolsey wps100/1? Im trying to move the position of my television, brought an extention cable but it just doesnt work.
Tv speaker problem
OK try to check the sound board or sound IC
Jun 25, 2012 | Polaroid 4241-TLXB 42 in. LCD Television
Hitachi 50v500 lcd rear projection just trying to get the setup so cable works on ant a can't make the channel move when im on ant a set up.
be aware this model has almost a 100% failure rate on the light engine which while not related to this issue should be kept in mind.
If you have cable get a box with a/v jacks on the back and hook to a rear input on the set--bypass the whole issue and get a better picture.
PS: I don't think it is the set itself causing this ........
Apr 03, 2012 | Hitachi Televison & Video
I just bought a PS3 from someone who doesnt have the user manuals. Im not sure how to connect it to my tv. I connected the HDMI cable. Is there something else I have to do?
you have to tell the tv to expect a hd signal just like changing extentions with scart leads. you will have options for hdmi 1-2-3 etc.
once you get a picture go through ps3 settings carefully.
Aug 01, 2009 | Sony PlayStation® 3 (80GB) Console
When my car is in Drive it just revs and doesnt move...
Get your transmission position sensor checked. With it being an automatic it doesnt have a clutch
Feb 02, 2009 | Hyundai Motor 2002 Elantra
Xbox 360: how to move screen image?
are u using a lcd or a crt television
Sep 29, 2008 | Microsoft Xbox 360 Console
1993 ford ranger starter turns won't crank
Youll have to take it out and check the condition of the ring gear through the starter hole use mirror and torch if you have to.Before taking the starter out turn engine over by hand to a different position then try to start with key.Try this several times if it doesnt work first time Why was the original starter replaced.Im assuming the starter you brought was reconditioned or new Did you check that the battery is still ok?
Jul 20, 2008 | 1993 Ford Escort 4 Door
Ipod connection
The stereo is not designed to interface with ipods through the usb. It will play by connecting your ipod's headphone output to the aux in jack on the face.A cable is supplied for this but i found mine to be noisy. A different cable worked fine.
Jun 22, 2008 | Virtual Reality VRCD500-SDU CD Player
Ok got a laptop problem, for my acer aspire 3000, im sure its the lcd, i turn it on, sometimes it works fine, other times it doesnt,...
Unfortunately, you will probably have to open up the laptop, and check the seating of the cables inside both the base and the LCD. It sounds like a loose connection, or a broken wire. I had similar issues with a Dell laptop, and it turned out to be a wire going to the ccfl tube (The backlight) that was shorting out against the case of the laptop when moved. Also, just try to re-seat the connections, it sounds like you have already had it apart. The cables should come off easily, and go back on with ease too, but do not attempt if you are not experienced, or at least comfortable with this type of thing.
Apr 23, 2008 | Computers & Internet
Televison & Video Logo
293 people viewed this question
Top Televison & Video Experts
