I want to change my sound settings on my computer so i can here sounds but it will not let me make the changes.
    Sergeant:
  • 395 Answers
Your login is probably a limited user login. Log off and log back in as the first person who set up the computer or Administrator.
Posted on Aug 03, 2008
Key clicks is ON , but NO sound
Is it possible that you also changed the function of the lock switch?
Try going into settings and change the settings of the lock switch to mute/unmute then place the switch itself into the unmute position.
If that brings back the sound of the keys, then it's safe to change the lock settings back to lock rotation.
If that doesn't solve the issue then I would recommend you do a backup and then restore to factory settings using your computer and iTunes.
Hope that helps!
Aug 21, 2012 | Apple iPad 32 GB 3G Tablet PC
After trying to plug in headphones (in the headphone socket) I have lost all sound on my Toshiba satallite 2040 (Idid have sounds from built in speakers before hand) can you help
Hi
You have not mentioned which operating system you are using.
You might have changed the defaul audio settings.
Vista/Windows 7: Start > Cxontrol Panel > Sounds & Audio Devices > Hardware & Sound > Manage Audio Devices > highlight the external speakers from the list of devices > Set Default > Apply > OK > Restart computer.
Win XP: Start > Cxontrol Panel > Sounds Speech & Audio Devices > Hardware & Sound > Change the Speaker Settings > Advanced > Speaker Setup - select Internal Stereo Speakers > Apply > OK > Restart computer.
I hope this helps.
Aug 27, 2011 | Toshiba Satellite 2450-401 Notebook
Ringer is marked as off on my blackberry bold 9700 and i have no sound
Hi,Sound profiles define how your BlackBerry device alerts you of phone calls, messages, reminders, and browser content.
Your device has a Normal sound profile and six other preloaded sound profiles: Loud, Medium, Vibrate Only, Silent, Phone Calls Only, and All Alerts Off.
By default, some of the settings in the preloaded sound profiles are based on the settings in the Normal sound profile. For example, when you change the ring tone in the Normal sound profile, the ring tone in the Loud, Medium, and Phone Calls Only sound profiles is automatically updated. If you do not want specific settings for a preloaded sound profile to update automatically when you change the corresponding setting in the Normal profile, you can manually change the settings in that preloaded sound profile.
You can create custom sound profiles. When you assign a custom ring tone to a contact, the ring tone is always active and does not change when you switch sound profiles unless you switch to the All Alerts Off sound profile. Call and message notifications for your contacts might be audible even if you switch your sound profile to Silent or Vibrate Only.
You can change, rename, and delete most preloaded sound profiles. You cannot delete the Vibrate Only sound profile and you cannot change, rename or delete the All Alerts Off sound profiles. You can change the Normal sound profile, but you cannot rename or delete it because some of the settings in the other preloaded sound profiles are based on the settings in the Normal sound profile.
Sound profiles define how your BlackBerry® device alerts you of phone calls, messages, reminders, and browser content.
Change a sound profile
If you change a setting in a preloaded sound profile that is based on the Normal sound profile, that change will override the corresponding Normal sound profile setting in the preloaded sound profile.
1. On the Home screen, click the Sounds icon.
2. Perform one of the following actions:
* To change the active sound profile, click Set Ring Tones/Alerts.
* To change a custom or preloaded sound profile, click Edit Profiles. Click a profile.
3. Click the application or item that you want to change.
4. Change the notification information.
5. Press the Menu key.
6. Click Save.
7. Press the Menu key.
8. Click Save.
Hope that helped...
Feb 08, 2011 | RIM BlackBerry Bold 9700 Smartphone
Part of my speakers are just not working. Hooked up, and unhooked and re hooked, but not all speakers working. Right now just 2 of seven are working.
If u have a surround sound card that supports up to the amount of speakers u have (5.1 or 7.1) try change the speaker settings in control pannel as follows.
Start>control pannel>sound>
and see if u have the setting on stereo, if so change it to the 5.1 or 7.1 setting.
If u have software on the otherhand for your sound card you can configure the settings there to change from stereo to surround sound.
Hope this helped :)
Dec 14, 2009 | Logitech X-540 Computer Speakers
Only 2 speakers working
on your computer if you go to
  • start
  • control panel
  • sound and audio devices
  • click on change the speaker settings
  • click advance in speaker settings
  • and change it to 5.1 suround sound
Apr 11, 2009 | Audio Players & Recorders
No sound when phone disconnected
Hello!
in sound settings (in control panel) you shold find the computers sound card and set that as default soundcard.
And in the settings (preferences) menu in the software you use to perform calls you just specify your computer phone as sound device.
Feb 04, 2009 | U.S. Robotics USR9600 IP Phone
Speakers wont turn down
its the audio quality in windows settings. go to the cpanel and change the sound volume in windows sound settings
then change volume. it should work otherwise. there old speakers. try buying a new bose speaker or something.
Jun 01, 2008 | Audio Players & Recorders
Hannspree Monitor- sound is gone
try changing the cable. or may be speaker setting is muted.
Apr 06, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
