Question about Denon Audio Players & Recorders
I have a denon avr 791 and sometimes when I switch from a high definition source to a standard definition source or vice versa on my cable box the output of the receiver starts to flicker to static, then to the source and then back again repeatedly. It won't stop until I bounce the receiver. Thoughts? Could it be a setting somewhere or is the unit defective?
    Problem Solver:
  • 11 Answers
Are you using HDMI for the Hi-Def?
Sounds like you may be having an issue with the HDMI switching.
It could possibly be related to your cable box.
Here is Denon's website:
http://www.denon.com/Pages/home.aspx
I suggest contacting them and seeing if your unit needs service.
Posted on Mar 25, 2011
How should I connect my denon avr 1906 to my 32" ES6300 Series 6 SMART 3D Full HD LED TV Model numberUE32ES6300U in order to get dolby digital from the tv's tuner please?
Use an optical cable.
Be aware though. Your TV has a DVB-T tuner. It picks up the Freeview standard definition (SD) channels, but not the Freeview HD ones. Dolby Digital sound only comes from the Freeview HD channels.
Your TV will pass Dolby Digital from any source connected to a HDMI port to the Optical Out. It will also pass DTS. But the internal Freeview DVB-T tuner doesn't generate Dolby Digital, just stereo and stereo with Dolby Surround encoding where you use ProLogic II for decoding.
Sep 08, 2014 | Denon AVR-1906 Receiver
Denon avr-2113ci hdmi can't change source
Can you update the firmware on the amp as this could also affect the connection between the players.
Jan 15, 2013 | Denon AVR-2113CI
I'm using receiver AVR 2309 and now I would like to connect my cable TV set top box which has HDMI port with this receiver. Which HDMI port (DVD/HDP/VCR or V.AUX) on this receiver should I connect
The DVD/HDP/VCR port will give you the high definition sound properties. If not then connect the set top to your receiver via RCA cables... red/white/yellow
Jan 12, 2012 | Denon Audio Players & Recorders
I con not get the surround sound to work. It only goes into stero mode with the same sound from all the speakers
The AVR-1911 is an A/V receiver with HDMI version 1.4a that can be connected to TVs and other devices that support 3D video such as Blu-ray disc players, game consoles, and set-top boxes. This receiver supports not only Dolby TrueHD, DTS-HD Master Audio and other HD Audio formats but also Dolby Pro Logic IIz for enhanced vertical and horizontal spatial performance at the front, the essence of 3D acoustics complementing the excitement of 3D video. The AVR-1911 comes with numerous other features such as 1080p up-conversion to give you a sharp, high-definition picture from DVD and other standard video sources, and a Glow-key remote control unit that is easy to use in the dark, to maximise your home theatre experience. Check if the RCA connector is properly connected.. Sometimes the problem is in the CD or DVD itself. Try to go to www.denon.com. ty
Jun 23, 2011 | Denon AVR-1911 Receiver
I bought a Denon AVR 791 receiver two months ago, work great, sound great with my Definitive Technology Speakers but 3 days ago while I was watching a movie on my PS3 the receiver turned off on the higher...
Clearly, it thinks you're overdriving it.
Blinking Power Indicator every 2 seconds means the internal temperature is high. (Page 76 of the manual)
Every half-second - speaker impedance too low.
Consider the load presented by the speakers and what their minimum impedance might be.
Check for loose speaker wires.
Feb 07, 2011 | Denon Audio Players & Recorders
I have denon avr 987 receiver i messed up settings somehow. when i have receiver set to dolby digital tv i get sound, but no picture. if i switch the setting to DBS i get picture buy no sound. what did...
Are your DD TV and DBS referring to the same source device or are they separate, say, cable Box and Sat Box?
Start over with the digital audio assignments for wherever you plugged in the digital audio cable from (guessing) your Cable TV box (recommended as "TV" is not usually a great source for audio).
The manual:
http://www.retrevo.com/support/Denon-AVR-987-Receivers-manual/id/696dj079/t/2/
You might also want to define the specific cabling of things if more is required. Exact point-to-point paths and cable styles for audio and video.
Dec 31, 2010 | Denon AVR-987 Receiver
Can't record out from a digital input
It only passes the signal it see's. Digital for Digital and Analog for Analog. Try running a Standard analog RCA from your Cable box to the receiver then try and record. Hope this helps. If you still have an issue, post a comment and I can help you further.
Sep 18, 2009 | Denon AVR-3803 Receiver
Sound cuts out
This sounds to me as an issue not with your AVR but with your cable unit. I have seen this where there is a sample rate issue with the cable boxes. I would try to get another cable box, and see if the issue persists.
Gary
Aug 28, 2008 | Denon AVR-2803 Receiver
154 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
