Question about Honeywell Heating & Cooling
Vaillant boiler has a strange odor when firing up
    Problem Solver:
  • 16 Answers
A, If it is your boiler, check as best you can that there is nothing obstructing the flue on the exterior of the building,if it looks ok, call the gasboard, it's a free call, they can advise best, on next step.
B, If you rent, contact your landlord asap, and have them deal with it as a matter of importance, if they don't , call the gasboard.
If you are not a Corgi registered engineer, (and I presume you arn't as you are posting this), it's illegal to even remove the cover from a boiler, so there isn't much the average person can do.
Peace of mind cost very little, just a phone call.
Posted on Mar 25, 2011
It could be the heat exchanger overheating or a problem with the chimney. Both require that a qualified service tech evaluate the problem because both can cause carbon monoxide to be released into the living area. THIS NEEDS IMMEDIATE ATTENTION!!!!!!!!!!!!
Vaillant Gas boiler/furnace not firing up
There is a thermocouple heat detecter in the pilot flame clean it 240 sand paper is ok. replace if not working.
Oct 22, 2014 | Water Heaters
Manual for Vaillant turbo Max combination boiler
No model listed, but this manual covers 8 of the most popular models.
Boiler Instruction Manual
May 04, 2014 | Computers & Internet
A have a vaillant ecotec boiler and when it fires up the fan is very noisy is this right
most likely no. there might be a obstruction in the blades, dirty filter, the motor might have a bad berring , the fan blades might have bent and now are touching the housing prob should call a trained tech boilers aint no joke
Aug 06, 2011 | Heating & Cooling
Boiler won't fire even though the pilot is lit
Check if the ignition plug works. Upon putting your boiler on, a spark will normally trigger the
the firing. Then, check the ignition transformer if it works. Check the secondary voltage which is between 15000 to 20000 volts to trigger the ignition plug and the boiler to fire. If no spark,
have your ignition transformer replaced to make it work.
Sep 21, 2009 | Heating & Cooling
Vaillant 831 combi boiler timer help
check to see the time clock is set with the clock symbol. there are three settings on analog clocks I , O and clock the I setting is constant running, the O setting is off and the clock setting is timer.
also try setting the thermostat up higher to see if the boiler fires.
Mar 25, 2009 | Water Heaters
Clock on comi boiler
it may be the preheat setting on the boiler for the hot water circuit. do the radiators get hot when the boiler fires up with the time clock off ? if not then there is nothing to worry about if it is only on for a short time.
Jan 04, 2009 | Heating & Cooling
Central heating boiler problem
this is probably a faulty diverter valve. more info needed
Jan 02, 2009 | Heating & Cooling
Vaillant combi boiler problem
when the tap is turned on and the water light on the boiler doesn't this means the diverter valve is not operating it could be down to low water pressure in the house this can be checked at the cold tap in the kitchen. if there is plenty of pressure then it could be the diagphram in the diverter valve is worn or split. the diagphram is only a few pounds but it depends on the engineer you get as to how much money he wants to fit it.
the egg timer symbol (or two pyramids together) is an ignition indicator turn off and on again to see if it will fire with the tap running. reset the boiler with the lower right hand control knob.
Dec 31, 2008 | Heating & Cooling
Vaillant Boiler time switch no user manual
http://www.vaillant.co.uk/stepone2/data/downloads/9a/42/00/timeSWITCH_120.pdf
Nov 04, 2007 | KDS Valiant 6380iPTD-01 Notebook
Heating & Cooling Logo
89 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
