Question about Epson Stylus Pro 10000CF InkJet Printer
Service required error code 00010006 . This is on an Epson Stylus Pro 10000 largge format printer. I also get a nozzle check error sometimes, but if the printer is cycled, it usually goes away.
  • 33 Answers
SOURCE: epson stylus pro 4800 print head problem
Are you getting a nozzle check at least?
Posted on May 14, 2008
  • 300 Answers
SOURCE: EPSON STYLUS PRO 10000
00010014 Pressurization error
Ink supply pressure incorrect
Explanation
The pressure system is determined to be leaking then this message appears and printer is stopped when detection of pressure origin sensor is incorrect at power on initialization or ink supply.
Solution
1. Replace supply pump assembly (including pressure origin sensor solenoid).
2. Check for disconnected air tube.
Posted on Aug 30, 2008
  • 33 Answers
SOURCE: Epson Stylus pro 4800 field repair manual
Epson is pretty cautious with their proprietary materials.
Posted on Nov 12, 2008
  • 700 Answers
SOURCE: my r230 photo printer epson stylus was sevice required unable to print and see your printer documents
Reset your printer. Look for printer resetter , its a utility third party program. Or in search of web browser just key in " epson reset software"
Posted on Apr 17, 2009
  • 47 Answers
SOURCE: epson error code 0104
00000104 Auto print head optimization system is all the manual says. No solution given.
Posted on May 15, 2009
Communication error error code :2100012c
Communication error error code :2100012c how to fix
Mar 15, 2013 | Epson Stylus Pro 10000 InkJet Printer
Tip
Epson Stylus pro 10000 Vista x64 Compatible? YES
Use the driver for the next model up: Epson stylus pro 16000.  A 64 bit driver is available for XPx64 on Epson site:  http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=19156&prodoid=22966689&infoType=Downloads&platform=All Install Printer Driver v5.50 in Vista x64.  The 10000 will print 100%, just like in XP with its own drivers.  Any problems?  I would happy to help you save the time I spent before finding that out.
on Apr 05, 2009 | Epson Stylus Pro 10000 InkJet Printer
Maintenance request error code 4000 for Epson stylist pro 4900
HI,
MAINTENANCE REQ - 4000 - It detects twice in a row that all the nozzles are clogging.
Check the video to know how to clean the nozzle to get ride of error 4000
How to clear nozzle clog on your Epson wide format printer from PRO...
www.electro-medical.blogspot.com
Mar 04, 2013 | Epson Office Equipment & Supplies
Epson stylus pro 10000 service request 10015
The error code = Sub Tank Overfill (K) k= Black
Sorrry I do not know how to fix it
Nov 01, 2011 | Epson Stylus Pro 10000 InkJet Printer
Epson stylus pro 10000, Service Req. 000100006 what this means? When I turn on the printer, it stop in 2,30 second and show this message.
Check inkcartridges.
You can snap off the cover plate carefully, under it you will see a plastic film that is heat welded to the housing. look for damages.
If it seems okay, take a small rubbertube that fits the small nozzle next to the ink outlet. blow into it gently.
if theres air coming out somewhere or the plastic film is broken:
Fix it with some strong tape or replace the cartridge.
Sep 05, 2011 | Epson Stylus Pro 10000CF InkJet Printer
Epson 10000 service required?
Hopefully you already have this solved. I had this happen on mine just this last week. The error itself is that the ink level sensor (not the cartridge, but the head) does not detect the correct level of ink. 00030017 is for Magenta specifically. The first step would to make certain there is actually ink in the Magenta cartridge. Physically remove it from the printer and give it a little shake to be sure there is ink in it. Mine had stuck on a nozzle check error and completely exhausted the cartridge.
Dec 01, 2009 | Epson Stylus Pro 10000 InkJet Printer
Does it work with mac OS X 10.5.6
Check this page on the Epson website:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14366&prodoid=4742585&infoType=Downloads&platform=Macintosh Good luck!
Apr 25, 2009 | Epson Stylus Pro 10000 InkJet Printer
Epson stylus pro10000 problem service reg
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
Feb 18, 2009 | Epson Stylus Pro 10000 InkJet Printer
Explanation
Solution
Aug 30, 2008 | Epson Stylus Pro 10600 InkJet Printer
Epson error code 0104
Apr 01, 2008 | Epson Stylus Pro 10000 InkJet Printer
Epson Stylus Pro 10000CF InkJet Printer Logo
306 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
