Question about Mustang Mouse
My mustang makes a loud squeaky noise when I start it. Sounds like it's coming from or near the serpentine belt
  • 3,083 Answers
In the old days, with smooth belts, is was a loose belt, or an adjustment on the alternator that had loosened up. It can also be a water pump, alternator, a/c, or other pulley's bearing going bad.
Run it by an auto shop- they usually can tell by listening. First, check the tension of the belt, and adjust, if necessary.
If you're a mechanically inclined person, you might be able to change out a bad component yourself, excepting the A/C unit, which takes a certified mechanic to recharge the system.
If you elect to have a part changed out, get a couple estimates, since dealers come at a premium. However, if the car's still under warranty, by all means have an authorized dealer service it.
Good luck, and hope this helps.
Posted on Mar 25, 2011
WHAT IS THE LIKELY CAUSED OF A LOUD SQUEALING NOISE COMING FROM THE ALTERNATOR SERPENTINE DRIVE BELT SYSTEM ? IS IT THE ALTERNATOR OR SERPENTINE BELT?
serpentine belt is getting old and hard and the cold weather was causing it to slip
check belt condition ( small cracks across the grooves = scrap and get a new one) and check tension
Jan 22, 2016 | Cars & Trucks
Much will cost replace power steering
the hard power steering is given away by the loud squeaky noise . It is the drive bely slipping from worn out or needs adjustment.. If the key problem is in the switch the replace the switch of if it is not engaging the starter motor have a look at the battery connections (shiny clean and tight) or the solenoid or starter relay.
Jan 09, 2014 | Mercury Cars & Trucks
Bad oil pump ?
Turn your A/C off, the compressor can make noise if bearings are dry or system is low on compressor oil.
Remove your serpentine belt. Turn pulleys by hand to check for roughness. Bearings in those pulleys routinely go bad.
You may get computer warnings with the following test, but with serpentine belt removed, run engine for 2 or 3 minutes. Do this on a warm engine after serpentine belt is removed. The warm oil will not mask the problem like cold thick oil can. Noise generated means problem is internal.
If this is a stick shift transmission sometimes the clutch bearing can make noise and is a sign that bearing is bad.
May 13, 2013 | Ford Focus Cars & Trucks
What's the CHEAPEST fix for my loud ac compressor?
I have a2004 mustang with a 3.9 making the same noise,and the shop replaced the AC compressor and all belt tensioners. I found that the noise is the timing chain tensionors .
Oct 28, 2012 | 2002 Ford Mustang
Growling engine noise only at idle. Cam area
Take all of the belts off for a short run at idle. If the sound goes away it is pulley related, spin each pulley and listen for bearing noise, also check for play at this time.
If the noise does not go away when the motor is driving no accessories you have a more serious problem.
Jan 13, 2010 | 1991 Oldsmobile 88
Engine makes a loud humming noise-Ford Mustang GT 2000
Need to check for any loose belts first .
Jun 22, 2009 | 2000 Ford Mustang
Fisher & Paykel top load electric dyer makes loud squeaky sound
to be honest i doubt that a bad belt would make a squicky noise and for a high class dryer like that i would suggest just call repairman  they are very complex
Jun 08, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Squeaky noise from serpentine belt
Replace the serpentine belt tensioner. Expect to pay approx $150.00 if installed by a mechanic.
Dec 28, 2008 | 2003 Toyota Corolla
Mustang  Mouse  Logo
94 people viewed this question
Top Mustang Computers & Internet Experts
David Payne
David Payne
Are you a Mustang Computer and Internet Expert? Answer questions, earn points and help others
