Question about Oral B ??? Oral b Professional Care Toothbrush Smartseries 5000
My 5000 series tooth brush will not charge i tried it with a few adapters and still no result could it be the base or plug that is malfuntioning , i am an electrician and there is power in the socket so thats as far as i can go . it only had one charge since i bought it
Thanks for your advice Steve. I think your right. Back to the manual toothbrush...
Posted on Nov 13, 2011
  • 5,568 Answers
I have bought many rechargeable devices and about 4-5% of them have bad Chinese batteries in them. I also have converted nearly all battery operated items to rechargeables and these often have spotty performance with several out of a couple of dozen not worth keeping. You might try running the batteries down as far as possible and then trying to recharge. If they are NiCads, they may have developed 'memory,' a known weakness of that type and NiMh batteries in particular seem to need several charge/discharge cycles before they will come somewhat up to their rated capacities.
Posted on Mar 25, 2011
  • Lee Lehman Nov 13, 2011
    I have the same toothbrush and i have changed mine 3 times at Boots and still have the same problem! Where is the battery on the toothbrush? Sorry to sound like a wally
  • Steve Allison
    Steve Allison Nov 13, 2011
    The batteries are located in the handle and aren't intended to be user-replaceable. If you have exchanged it so many times, it may be telling you not to bother with it. It's entirely possible that each time you have gotten a replacement, you are getting units with batteries from the same defective batch.
    The unit seems to have a 2-year warranty so you might schedule the return of the defective one you now have for a year away to try getting better battery performance from a different batch and just toil away manually brushing for a while. :-(
HOW TO GET THE BACK OFF
Break it off..........
In order to take the Base Enclosure (Bottom Cover) off, you would have to break it off.
The Acer Aspire 5000 series of Notebook PC's, disassembles from the Top down. When you are done you are looking at an empty Base Enclosure,
http://www.ebay.com/itm/ACER-ASPIRE-3000-3004-ZL5-5000-LAPTOP-BOTTOM-CASE-COVER-LOWER-BASE-3AZL5BATN05-/181127078788
You have to;
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Remove the Harddrive Compartment Cover, Harddrive, Memory Compartment Cover, Ram Memory, Wireless Module, Wireless Antenna wires out of laptop body, Optical Disk Drive, (DVD drive), Display Assembly, (LCD Module), Keyboard Cover, Keyboard, Palm Rest Cover, Motherboard, and so on..........
Then you have the Base Enclosure. (Bottom Cover)
WEAR an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Acer Aspire 5000 series of Notebook PC > Service Manual (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to the paragraph that starts with Aspire 1200. (1200 in Blue)
Drop down to the 6th line (4920G), scroll across; and click on the blue -> 5000
For additional questions please post in a Comment.
Regards,
joecoolvette
May 02, 2013 | Acer Aspire 5000 Notebook
My compaq presario c795tu battery is not charging
Unplug the power supply, take a stiff tooth brush and clean the battery terminals in the laptop plus the battery, re-install the battery and plug the charger in, If that fails you need to find out if the charging circuits are putting out the proper voltage before you replace the battery.
Mar 04, 2012 | HP Compaq Presario CQ40-330TU
Hi there. when i plug in my hp charger it starts beeping and does not charge, it started this thing a few days ago.
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Oct 06, 2010 | Computers & Internet
Hey hi this is nammy........my acer 4736z battery is not charging.....actually whn i plug in, the orange light comes for a while and it shows tht battery is charging but after a few seconds it loses...
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
Sep 15, 2010 | Acer Aspire 4730-4947 Notebook
Hi Have brought a second hand Acer aspire 5000 laptop for a $100.00 dollars for my sons birthday was told battary light was flashing amber and it needed new battary as wouldn't run of power they said it...
Aug 29, 2010 | Acer Aspire 5000 Notebook
How to clean a rodio and the 2 pin unit it has green on it
Purchase some spray on contact cleaner, spray some on a tooth brush and scrub the plug. Then spray some into the socket and work the plug in and out a few times.
Dec 06, 2009 | Motorola 2 Pin Adapter 2-Way Radio
Need guide/manual for Plantronics 222 Blue Tooth
first question,i have anplantronics explorer 242 when i plug it iun to charge it the light ired then after a few min. it turns blue,how do i know when its fully charged? will the lights go off?
Dec 16, 2008 | Plantronics - Bluetooth Headset Plus Base...
Screen goes checkered after a few minutes
right well the problem is your av adapter u need to purchase a new one or a trick is to get a tooth brush and dissconnect the av plug and clean the av adapter with the tooth brush and the xbox 360s av adapter clean that to plug it back in leave it for a min and turn it back on and u should be on for hours if problem persist email me at mid.nightclub@hotmail.com good luck
Dec 31, 2007 | Microsoft Xbox 360 Console
Oral B ??? Oral b Professional Care Toothbrush Smartseries 5000 Logo
1,155 people viewed this question
Top Oral B Health & Beauty Experts
bayou sam
 Russ Hill
Russ Hill
Ceth Seamans
Ceth Seamans
Level 1 Expert
Are you an Oral B Health and Beauty Expert? Answer questions, earn points and help others
