I want to change inputs from AV1 to AV2 using menu controls on top of the tv. I'm able to get there but the input is not changing.
    Problem Solver:
  • 16 Answers
If you are using scart cables, try unplugging the input cable that isnt working, then unplug it from whatever its plugged into at the other end, and reversing it, (example: the end that was in your tv is now in the item, the end that was in the item, is now plugged into your tv).
Some scart leads are not reversible, despite being identical at both ends, so its easy to get them the wrong way round, hope it helps
Posted on Mar 25, 2011
How do i get my nintendo wii console to appear on the tv screen ive tried every channel and hdmi and such and nothing i know its on and working cause i feel the wii remote vibrate just nothing shows o
Kate what did you plug the cables into I suspect it was a grey cable with a red , white and yellow plugs. If I am correct this cable should be plugged into the AV1 or AV2 input port of your television. Try changing the input source to AV1 or AV2 Check it is plugged to AV1 on the Television and not into Conponent input !
Jan 02, 2015 | Sceptre X32BV-Naga 32 in. LCD TV
Sanyo tv change to av1 av2
Whenever your change from one video source to another, your tv automatically switches input modes (i.e. av1 to av2) to faciliate the source coming into your tv.
Aug 10, 2014 | Sanyo DS32920 32" TV
How do i change the input
The 27" TV uses the same instructions as the 20", and I found the manual for you at the link below. Answering your question directly, here is the section of the instructions about changing input:
Changing the TV's Input Normally, your TV displays the signal coming through the antenna terminal. However, if you've connected another component to your TV(such as a VCR & DVD) using the Video/Audio input,you will want to be able to view the signal from the component.To do this, you will need to switch from the ' TV ' input to the 'AV1-AV3, CVI' Input, as follows. 1 With the TV on, press the MENU button twice, then " Set-Up " menu will appear. 2 Use the WCHV buttons to select " Input ". 3 Press the CVOLB buttons to change the input source from ' TV ' to 'AV1, AV2, AV3, CVI'. 4 Wait 20 seconds, or press DISPLAY button or MENU button to return to normal TV viewing. * CVI means the Component Video Input (Y/ PB/ PR) from the DVD player etc.* Users can also select these input modes with the TV/AV button or the INPUT button on theremote controller. * On the AV1 mode , if you connect the S-VHS jack to your TV, "AV1" is changed to "S-VIDEO".
The link to the manual is below.
Jun 01, 2014 | Daewoo DTQ-27U4SC 27" TV
Can get tv to change to av1
The Input button on the original remote is needed to switch to the AV1 or AV2 connections. Unfortunately, I do not believe that the Sanyo DS27930 has an equivalent Input button on the TV. A replacement remote is available here: http://www.emtcompany.com/sanyo-ds27930-remote/rc64.html . Other universal remotes may be able to transmit the Input signal. You will need a remote that was programmed over 6 months after the TV was released with an Input or Source button. Then try all Sanyo codes until you find one that controls all of the features.
I hope this helps.
Mar 04, 2013 | Sanyo DS27930 27" TV
Where can i buy a new remote mine got water damaged
It depends on the TV (make/model). Do you have an Input or Source button on the TV? Then you can use that button to change your input. A few models will offer an alternative option to change the source from the menu and have a Menu button on the TV. (Some TVs only let you change the source from the remote.)
Some remotes are available from the manufacturer's parts store (Sony, for example). remotes.com has the exact original or a replacement remote for many brands. For other TVs, a universal remote may work. Look for a higher end universal remote with a Source or Input button. Then test all of the codes for your TV brand. (Some codes may only enable parts of the remote functions; make sure you find a code that lets this button work.) The remotes that can be programmed with a USB connection to a computer are the easiest to set up for this situation.
Please add a comment with the specific make and model of your TV; I'll try to find a source for an exact replacement remote.
(some really old TVs let you swap from AV1 to AV2 to channels by going up or down through all channels to reach a point where you could swap the inputs.)
Feb 03, 2012 | byD sign Televison & Video
My p.s3 will not work on my 42 inch plasma t.v.i used to use an hdmi cable to watch it now im using a.v cords how do i reset or fix the settings it was on before?
Go to the main menu of your tv then try to select for the video input, you will see there the inputs tv or av1,av2, hdmi1,hdmi2 etc. try to choose the av1 or av2.
May 14, 2011 | Televison & Video
How do i change from av1 to av2 . . .av3 ? have remote . .
I think you can do channel down, or up, 'til you go below channel 2, or above channel 125. Then it toggles through external inputs.
Apr 18, 2010 | Philips 27PT6441 27" TV
AV1 AV2 hook up
you should find them by seeing if you can find ports that are colored yellow, red and white
Apr 01, 2010 | LG 42LC2D 42 in. LCD HDTV
Sanyo 68cm. AV1 is Black and White. AV2 and normal Tv is OK
the two AV1 and AV2 have different inputs on the IC,
the first port has a disconnection,
take your tv for a check up
Mar 20, 2009 | Sanyo DS13204 TV
Can't switch from AV2 to AV1 with Samsung DVD-VR375 DVD Recorder / VCR Combo
To be able to select AV1, you have to first go into the setup menu and set the control set top box setting to OFF. I think you go to the menu >> setup >> features >> set top box control >> select OFF. Note that this has the side effect of erasing any previously stored timer settings.
Sep 05, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
