Hi I have a sony NWZ-B135F that is completely dead. It does not respond when I plug it into my USB port. IS there anything I can do to recover it. Regards, Ron
  • 2,574 Answers
If the portable player is not responding, reset it by pressing the RESET button with a small pin or similar object.
Please check the following link:
http://www.kb.sony.com/...
Posted on Mar 25, 2011
How to free download driver for sony mp3 walkman nwz-b135f
Hello
Try this link.
esupport.sony.com/US/perl/model-find.pl?mdl=NWZ-B135F...
Feb 16, 2012 | Audio Players & Recorders
Sony walman sok-nwz-b135f(b)
firmware is corrupted reinstall firmware from sony site
May 24, 2010 | Sony Walkman NWZ-B135 MP3 Player
My daughter's Sony MP3 NWZ-B135F does not charge
the battery is down u must replace it.it ain't easy for u to do it,because a mistake can destroy her player
contact customer service
Mar 18, 2010 | Sony Walkman NWZ-B135 MP3 Player
Sir, My nwz-b135f has frozen up, it want move at all and cant' be switched off, how can I fix it. Ib
Hi ikjensen,
You can try forcibly resetting it. Don't worry, you'll not lose any data. There should be a pin sized hole somewhere on the back.( To find out where, please visit this site for the manual for your model.
http://www.sony.co.in/support/product/nwz-b135f/modelfirst). Push a pin into the hole, and the player should be resetted. Common hang ups can be solved this way, but if the problem persists, try formatting the player.
Nov 27, 2009 | Sony NWZB135F MP3 Player
Non-responsive Sony Walkman Digital Music Player NWZ-B135F
try reseting the device its usualy a small pinhole on the back or side of the device try holding that in for about 10 seconds
try reflashing the firmware for your device you can find the latest firmware and flashing utilitys from the manufacturers website
also try and go download the drivers for it so that you can try and detect the player. If that does not work try plugging it into someone elses computer and see if it works. That way yo can figure out if it is your computer or the player. Sorry I could not be of more help.
Sep 29, 2009 | Sony Walkman Video NWZ-A815 Digital Media...
Sony NWZ B135F Walkman won't disconnect
  • In mac open Disk Utility
  • Select the volume named WALKMAN
  • Hit UNMOUNT
  • Disconnect the player
The trouble is that the player doesn't respond to the comand EJECT in this process a loop started unmounting and seconds later mounting the volume again.
Hope this helps
Jan 06, 2009 | Sony Walkman Video NWZ-A815 Digital Media...
Malfunction
I had the same problem... did you realize which the solution was?
Dec 25, 2008 | Sony NWZB135F MP3 Player
My computer no longer see's my MP3 player and will not charge.
unplug the device and press the RESET button at the back of device, and try reconnect again
if it not work, try to do again.
Dec 15, 2008 | Sony NWZB135F MP3 Player
Device unable to start on computer- Sony walkman NWZ-B135F
hello everyone. i encountered the same problem. after i unplugged themp3 player the screen hung/froze showing only the sony walkman logo. iused the reset feature numerous times, but no luck (initially.)
ima linux user (ubuntu 8.10) and the sony mp3 player NWZ-B135F is in factCOMPATITIBLE with the Ubuntu Linux operating system. i triedlinux suggested solution mentioned in another thread.i let the power drain completely. however after the whole "ithung/froze" incident, even linux was not able to read the usb device.it wouldn't turn on and it wouldn't charge at all. so to troubleshootthis issue i used the Windows XP prof. OS which was able to detect thethe sony mp3 player when plugged into a usb port. but mind you, the mp3player device was not appearing under "my computer"
i downloaded the FIRMWARE for NWZ-B135F found on this page below:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=NWZB135F&SelectOS=7#div_pos_30
afterrunning this program, the Windows XP prof. OS clearly detected the mp3player device and it now appeared under "my computer" as a removabledisk. (at this point, the sony mp3 player lit up and it started tocharge again) i reformatted the sony mp3 player memory to FAT and ranthe NWZ-B130_V1_01.exe (firmware) again. the system reset and itworked! i only had 20 songs so losing the files was no big deal. i wasjust glad it started to work again.
anyway, hope this helps someone. if you have questions, just message me. have a good day.
Nov 17, 2008 | Jwin MP3 Player
Sony nwz-b135f problem
MTP problem SOLVED!!!!! Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} I have a Sony MP3 Player(NWZ-B135F). when i inserted it to my pc's USB port(which is working fine), win XP (SP 3) prompted "Found New hardware" wizard. I followed the steps and finally I reached to a step where it shows “MTP device Problem......” I tried many times with different USB ports, but the same problem happened.
Fully frustrated, I finally did what the whole world does, GOOGLE my problem. Google showed me a lot of posts but nothing could solve my problem. Microsoft was providing the MTP driver, but only after a lot of authentication and procedure, which I was not going to follow….
After repeatedly experimenting by inserting my MP3 player, I got the solution!! It is as follows:
1) Insert your music player in the USB port. You will get a Hardware Installation wizard by XP.
2) Select, “No, Not this time” and click next.
3) Select “Install from a list or specific location (Advanced)”.
4) Select “Don’t search. I will search the driver to install”.
5) Select “USB Mass Storage Device” and then click "Next"
7) Wow!! Now you are done!!!
Enjoy and listen to your favorite music!!
Nov 11, 2008 | Sony NWZB135F MP3 Player
204 people viewed this question
 Grubhead
Grubhead
