Question about Frigidaire ATF6000ES Front Load Washer
Error code DR
Have a code of dr and do not know what to do
  • Anonymous Aug 03, 2008
    code dr problem and not sure how to handle
  • 876 Answers
DR means there is a door problem.
Go to this site and download tech info and any other manuals you need to help you.
http://www.frigidaire.com/support/ResultsPage.asp?strModel=ATF6000ES&User=&Search=Search
The manuals are all in PDF format, so you need acrobat reader to read them. If you do not have it it is a free download at www.adobe.com/acrobat.
Posted on Aug 13, 2008
  • 725 Answers
Dr is a door error your door is not closing or your door lock is faulty
hope it helps
4 Suggested Answers
SOURCE: AFFINITY ERROR CODE
door not close
Posted on Sep 09, 2007
the dr
  • 447 Answers
SOURCE: error code
what is the code???
Posted on Jan 05, 2008
TheMobilian
  • 8205 Answers
SOURCE: Error Code "dr"
Dr means door problem, either some clothes is keeping it from shutting or the door switch is bad 1ff09a4.png
Posted on Mar 05, 2010
Testimonial: "Thank you so much. I will pass this information along to the technician and hopefully the problem will be solved!"
Wtat is the dr code error?
Hello Aung, I appreciate your post!
Based off what you have described your Electrolux washer is displaying an error code of "DR". The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. You should perform a reset on your washer and you can do that by disconnecting the power cord for at least ten minutes. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
Dec 30, 2015 | Electrolux Washing Machines
I have a Frigidaire front loader washer model number LTF7000EGO and it was washing fine then started a beeping noise with dr flashing. What does that mean?
Hello friend, thank you for your post!
I understand that your Frigidaire washer, LTF7000EG0, is displaying a "DR" error code. "DR" stands for door which means a problem with your door it could be an issue with the door latch assembly or door strike. I would suggest resetting your washer and you can do that by unplugging the power cord or flipping the household circuit breaker for ten minutes.
If you continue to experience an issue with the error code "DR" I would recommend reaching out to a professional technician for proper diagnosis and repair. I hope this information has been helpful. -Matt
Oct 09, 2014 | Washing Machines
Frigidaire Affinity ATF7000E DR error code
Good Morning Friend,
I understand you are receiving a "DR" error code on your Frigidaire Affinity washer, model ATF7000E. The "DR" error code is stating that there is a possible problem with the door. This could also be a possible false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Affinity ATF7000E Front Load...
I'm getting a door error "dr" on my ATF6700SF0 washer. How can I determine whether to replace the door lock assembly or the control board?
Hi Curt, this is AP
I understand you are having trouble with an error code on your Frigidaire front load washer. On your particular model, ATF6700FS, the error code "DR" indicates that the door is open or there is a problem with the door. If you know the door is not open you should check the door switch and wiring. If you need assistance with replacing the door switch I would recommend contacting an authorized technician in your area. I hope this information proves helpful to you, thank you for the post.
Thanks,
Mar 29, 2014 | Frigidaire ATF6700FS Front Load Washer
Frigidaire leq2152eeo error code dr
Hi - Typically DR is a generic door error code. Possibly the door is not shutting properly, either it is sagging and not latching properly or the door sensor and the main control board are not communicating correctly. You would need this to be diagnosed by a professional technician in order to properly repair the machine.
Oct 06, 2012 | Washing Machines
Have Neptune FAV6800AWW top load, washes when it gets to the rinse cycle it stops with water in. If we remove the clothes and wait a while we can get it to complete. The code we are getting is DR which...
Are you sure the error code is DR? Could it be DC an unbalance error code. Google ""16022808.pdf"" to find. Is the washer banging around in Spin Cycle? If so this is a Clutch Pulley issue.
Google this ""Neptune TL Washer FAV6800AWW"" a forum where I help owners of the FAV6800A and FAV9800A machines.
DR is not a listed error code in the FAV6800A/FAV9800A Service Manual.
Aug 27, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Washer will not start. Getting "dr" message . Door lock light is not lit. Tried cancel and restart tried unplug and restart still getting dr message
The 'dr' error code stands for 'door switch is not closed'. If the door is closed properly, then you will have to replace the door switch assebly.
Hope this helps!
Jun 25, 2010 | Washing Machines
Error Code "dr"
Mar 05, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Error code
'dr' is an error code that indicates the door is not closed. If closing properly the door lock may have to be replaced.
Jun 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Dryer door problem
Most likely the door lock is bad, check the wire connections to make sure thay are connected. If so replace the door lock assembly.
Jan 07, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
393 people viewed this question
Top Frigidaire Washing Machines Experts
Electrolux
Electrolux
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
