Question about Gladiator 19 cu. ft. Chillerator Garage Refrigerator
Temperature is to worm in Freezer - Gladiator 19 cu. ft. Chillerator Garage Refrigerator
  • 132 Answers
Could be any one of these problems
\ evaporator fan not working
\ ice blocking air flow
\ thermostat worn out
\ low refrigerant charge
\ blocked or dirty condenser
\ poor air flow over the condenser
\ compressor valves burnt
Posted on Mar 25, 2011
The freezer is set at -4. How do I adjust it? Everything is freezing too much.
Hi Marisa:
Following is the instruction for adjusting the freeser temperature for your Samsung refrigerator:
You press the freezer temperature button repeatedly till you see your desired temperature. If you want to set it to -2F, stop when the display shows -2F and don't press the freezer button again. After 5 seconds this new temperature will be set.
The instructions from the Samsung manual is shown below:
Controlling the Freezer temperature:
The Freezer temperature can be set between 8°F and -14°F to suit your particular needs. Press the Freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at 4°F. The temperature display will move sequentially from -14°F to 8°F. When the display reaches 8°F, it will begin again at -14°F. Five seconds after the new temperature is set, the display will again show the actual current freezer temperature. However, this value will be changed to the new temperature.
Feb 15, 2016 | Samsung RF265AA Bottom Freezer French Door...
Miele KFN8993SDN Freezer temperature to high
Temperature displays
During normal operation, the temperature display shows the temperature in the middle of the refrigerator section and the temperature in the warmest part of the freezer section.
Aug 20, 2015 | Miele KFN12923 SD-2 Stainless Steel 369 l...
The temp says 14 and 8 but should be -21 and 3? Can anyone help
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
When motor gets worm it won't get over 2 grand rpm
Too many possibilities. Best to get it scanned for error codes. Most probably the ECU gets wrong reading from temperature sensors, such as Coolant Temperature Sensor or Intake Air Temperature sensor but it's not limited to that.
Jul 20, 2014 | Cars & Trucks
Freezer temperature light indicator blinking and freezer worm
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 04, 2010 | Samsung RS2630SH Side by Side Refrigerator
The refrrigerator and freezer not holding tempreture it started with the freezer - how can i fix - i have defrosted the freezer and removed all food?
hi there,
have you check the temperature?
The temperature controls are preset in the factory at 37°F for the refrigerator compartment and 0°F for the freezer compartment. Allow 24 hours for the temperature to stabilize to the preset recommended
settings.
The temperature controls can display both the SET temperature
as well as the actual temperature in the refrigerator and freezer.
The actual temperature may vary slightly from the SET temperature based on usage and operating environment.
Setting either or both controls to OFF stops cooling in both the freezer and refrigerator compartments, but does not shut off electrical power to the refrigerator.
Jun 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice jams up the worm at the bottom of the icecube dispenser and the worm does not move the ice and ice jams in the crusher part.
Try turning the temperature down on your freezer one number. Sometimes if it is not cold enough, the cubes can stick together and cause a clog.
Sep 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Freezer
the alarm light is conected threw to the thermostat and is disighned to worn you if the freezer has wormed up obove freezing tepteratures. it is on and the freezer is still working ok then there is a fault in the control. Please check the temperature using ice creem as you gage if the freezer holds icecream to a hard consistancy then the freezer is working good . ice cream hardens at around -10 f anything wormer and its soft . you could have the control replased but the standard replacement controls dont have the temp alarm options. hope this helped. p/s if you are living in a worm climate enshure the freezer has adiquit air cerculation oround the cabinet.
Oct 20, 2008 | Freezers
Gladiator 19 cu. ft. Chillerator Garage Refrigerator Logo
113 people viewed this question
Top Gladiator Refrigerators Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Gladiator Refrigerator Expert? Answer questions, earn points and help others
