Question about Kitchen Ranges
Would You please show to me catalog of Bi metal temp.gauge with range minus 30C to plus 30C
  • 436 Answers
2005 chevy malibu has a slight jerk feeling when it is in 4th gear going at a constant speed and I can notice a slight bounce on the rpm gauge. Also if in low range using plus and minus buttons, when...
Sounds like a tooth missing of the fourth gear, check trans sump for metal filings or pieces. if auto, adjust bands and check/change fluid and filters. as well.
Aug 03, 2014 | Cars & Trucks
My friend has a set of infinity il 40 The speakers have 4 terminals on back hf top 2 and lf bottom 2 why 4 terminals if they are full range speakers and which do you hook them up to
They're supposed to be jumpered together (plus-to-plus; minus-to-minus) and you can run speaker wires to either pair.
Do some web research on BI-WIRING to see why the speakers within each cabinet have the ability to be run separately. Hold on to your wallet if you buy into the hype.
Read....
http://en.wikipedia.org/wiki/Bi-wiring
http://www.theaudiocritic.com/downloads/article_1.pdf
Sep 20, 2011 | Audio Players & Recorders
Ok. I inherited my rangemaster 110 when I moved house. I've no manual but a digital clock with a bell, 2 strange looking things that I presume mean ho and oven, then a hand and a plus and minus button. ...
Most of these timers have 3 buttons, the hand and the plus and minus buttons. Try pressing the minus and plus buttons at the same time. The display should flash. Then adjust the time with the plus and minus buttons. If this doesn't work just try different combinations of pressing 2 buttons. If the timer is not faulty on of these combinations will work.
Feb 18, 2011 | Rangemaster Classic 110 Kitchen Range
I'm having a problem hooking up these speakers... It has 4 hookups in the back of it which ones do I use? I just have a standard reciever to hook them up to...
look at this picture...
http://www.helpus2move.com/sold-items/b-w-dm602-s3-stereo-speakers-bowers-wilkins/
The vertical jumpers are removable if one wishes to BI-amp them. If not, leave them in place and connect your speaker wire conventionally - plus to plus, minus to minus.
The picture here...
http://community.whathifi.com/forums/post/265617.aspx
shows what to do if the jumpers are missing. Just fashion a short jumper for each to connect the top woth the bottom on each side.
Google bi amplification speakers if you're bi-curious. ;-)
Feb 02, 2011 | B&W DM602 S3 Speaker
What type of oil for a 1993 toyota landcruiser
petrol or diesel require different oils.and ambient temperatures come into play.for average temps of say minus 5C to plus 30C use 20/50 (the best you can afford)it dont matter if its synthetic or normal cos it should be changed every 3000 miles wih a new filter.this is from toyota WORLDWIDE.(NATO/WHO use them all over africa/middle/far east/Russia.who is going to argue....
Nov 08, 2010 | 1993 Toyota Land Cruiser
Hotpoint rgb745bea2ct oven doesnt keep temp. can i ohm it out sensor?
At room temperature the temp sensor should be 1100 ohms plus or minus 50.
Dec 03, 2009 | Hotpoint RGB745 Gas Kitchen Range
Oven does not reach set temp
What are using to measure temp ? Are you using a grocery store bi-metal or professional thermal probe ? and further to that, how long are you waiting to check temp. after range "beeps" or announces preheat complete ? The bi-metal type thermometers do take several minutes longer to reach actual temp as opposed to the ranges temp. probe. Does this unit have the "hidden" bake element ? That sounds like a huge temp difference. These units do require an additional 10mins of wait time after announcing ("BEEP") the preheat is complete (check your manual, it should confirm this) Elements don't go "bad" it either comes on (amp draw) or it doesn't.
hope this helps.
good luck
Sep 26, 2009 | Frigidaire Ovens
Erratic oven temperatures adjusted the thermoatat as per instructions in manual no change
if adjustment of the screw behind the oven knob did not help:
replace the oven thermostat the part can be found at: searspartsdirect.com
Sep 05, 2009 | Kenmore Kitchen Ranges
My Thermostat shows that the teperature is hotter than it is in the evening, thus the furnace is off and the whole house is cold all night.
If you have a bi-metal t-stat it will be plus or minus 10 degrees. If you have a digital t-stat it is accurate plus or minus 1 degree. You can adjust a bi-metal t-stat but not a digital. If it is the t-stat not keeping the right temp. then you will need to change it.
Oct 14, 2008 | Heating & Cooling
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
