Question about Papermate Paper Mate® Sharpwriter® Mechanical Pencils
How do you put in the lead in the paper mate sharpwriter after you've run out??
I have a code P0355 Coil E I believe it is #5 But not sure which is #5
Mate your car runs rough ok, To find the faulty coil just pull a spark plug lead off and start your car, If it runs (ROUGHER) than before then that coil is ok. Turn the car off and replace that spark plug lead on the spark plug. Repeat with the next spark plug lead and so on until you start your car and it runs the same as if THAT spark plug lead is on or off, THAT'S THE FAULTY COIL.... I hope I haven't wasted your time.....
Mar 08, 2016 | Cars & Trucks
Battery terminal corrosion
Make sure you have radio security code before removing battery leads. Remove battery leads, -ve lead first.
Clean grey oxide coating from battery terminal posts and inside battery lead terminals with abrasive pad (eg. Scotchbrite coarse) or abrasive paper and wipe clean with cloth. Liberally coat battery terminal posts and inside of lead terminals with general purpose grease or petroleum jelly. Install battery leads to battery, +ve first then -ve, and tighten securely. Do not over tighten. Spread excess grease over top of battery post and lead terminal to ensure all moisture is excluded. Replace terminal covers. Should be good for a long time.
Dec 03, 2012 | Chrysler Town and Country Cars & Trucks
Insert lead into Paper Mate Logo 4 0.5mm mechanical pencil
Simply grab the top rotating section, and the lower barrel, and pull apart. This will expose a clear tube in the lower section, where the new lead may be inserted, up to 6 pieces max. Then gently push the top back into the lower section.
Sep 24, 2012 | Papermate Paper Mate® Logo 4 Mechanical...
Paper jam in exit area
Hi
Disconnect it completely from power and re-connect again.
Sep 16, 2012 | Samsung SCX-4300 Monochrome Laser...
I have a Canon MP210 scanner/ printer that is telling me I have a paper jam but there is no paper in the machine. I've turned off the power and turned it back on, I've looked for a small piece of...
Your printer might be out of paper.. so try this..... press Black/Color button... if it doesn't work turn off your printer and press paper feeder on the back side and press the power button with holding the paper feeder. Don release it until the process of printer is complete... thanks
Aug 26, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Cant change ink settings ie puts too much ink on
Don't use glossy paper. I use Mate 10 lbs.
Try that.
Good Luck.
If that works, pls rate me.
Jan 13, 2010 | Epson Stylus R265 InkJet Photo Printer
Paper shredder motor doesn't run.
Are you sure that there's no paper jam in the shredder?
May 01, 2017 | Fellowes Office Equipment & Supplies
Password problem
You have to hard reset your kjam , and after it will work , but you will loose all your programs and data , if you have backup in your mem stick simply you can restore every thing
Apr 15, 2008 | i-mate K-jam Smartphone
Papermate Paper Mate® Sharpwriter® Mechanical Pencils Logo
78 people viewed this question
Top Papermate Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Papermate Office Equipment and Supply Expert? Answer questions, earn points and help others
