Question about GE Microwave Ovens
Have an over the range microwave over (GE) and the fan came on this morning and had to unplug the microwave. Can't get the fan to turn off when plugged back in
  • 591 Answers
The fan switch is probably fused (shorted) you need to replace it...
Cheers!
Posted on Mar 24, 2011
How can I get the fan to turn off when the microwave is turned off?
Most GE over the range microwave ovens have a cavity heat thermostat. if the exhaust fan cut on due to external heat generated to oven, the fan will run until unit totally cools down. in this case unplug unit. Also fan can run if you have a broken door paw or if one of the door secondary switches is bad.
Aug 09, 2014 | GE SpaceMaker Microwave Ovens
My ge profile microwave model pvm1870sm133 is not working properly. when you open the door the cooling fan turns on
Unplug and cease using this as you are exposing yourself to electro magnetic radiation. The door switch may have failed, you will need to disassemble the front panel to access the switch which is located within one of the holes that he door's hooks insert into and depresses to inform the control board the door is closed and is safe to operate.
Dec 22, 2013 | GE Profile Spacemaker 1.8 Cu. Ft....
I have a ge spacemaker over the range microwave oven model number jvm1631bj02 and it blows fuse after fuse and seems to blow right before the fan would engage within the first couple of seconds
Sounds like you have a shorted fan motor. Disconnect the power going to the fan and then try turning the microwave on again. Do not run the microwave for more than 5 or 6 seconds without the fan operating. If this does not cure your problem then the next most likely problem is either the AC Capacitor (silver can), or the Magnatron (4 inch square silver unit with cooling fins and thick wires. The voltage present on these two units can hold a charge in excess of 5000 volts, even after a time it is unpluged. Don't go near these unless you know what you are doing.
Best of luck.
Jan 20, 2010 | GE Microwave Ovens
Model is GE JVM1430BD002. Microwave works but range fan and lights do not. Unit "popped" when fan was turned on one time and hasn't worked since. Is there a fuse or breaker for the range hood functions?
Yes - there is an internal "special" in-line fuse. Most likely it is the fan that has caused it. Clean the fan with switch-cleaner spray and make sure it is smooth running. Replace special fuse with identical version.
Check lights before operation.
Replace all covers before test.
Oct 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
GE Microwave Profile Spacemaker Runs on its own
Your microwave turning on by itself is a "self preservation feature" of the GE Profile Advantium and maybe some other models. Read the manual, When your over the range oven gets warm enough, for whatever reason the venting fan comes on until a satisfactory oven temperature is reached. You are not permitted to shut the vent fan off. Also it seems a temperature near room temp must be achieved before it shuts the fan motor off, it is very annoying. We had to return our Advantium because of fan noise. I configured the ovens vent fan to the recirculate direction because we do not have a vent duct that exits the house over our range. When the vent fan acting as the ovens cooling fan automatically turned on we would have to leave the house to hear each other talk. Too bad we really liked the oven other than that major problem. G-Man
Apr 19, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave Vent Fan
The only thing I did was to unplugged; turn off all the burners; and let everything cool off. I guess I can't have all the burners on at one time since the microwave is 13" from the burners......and from what I read "microwaves placed over the range" should be at least 30" from the burners...thank you, Rose66
Feb 20, 2008 | GE Microwave Ovens
Microwave Ovens Logo
23 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
