Question about Kenmore Side by Side Refrigerator
We have side by side Kenmore and on freezer side we are getting prozen water under the slide out drawers on the bottom on interior. We have cleaned it out and it refreezes and when we turned off water to ice maker we still found small amount of water frozen on bottom. Took silver cover off and fan is turning and see small drops of water falling off very bottom bar below coils. Looks like bottom half coils show more frosty look but water is still off ice maker. Could water in bottom come from time frame after we cleaned but before we shut off ice maker water supply? Any ideas. About 10 years old. Thanks
    Champion:
  • 239 Answers
Your drain line is frozen and not allowing the defrost water to drain to the pan below. The drain hole is at the bottom of the evaporator coil in the freezer behind the metal rear panel. You may need to remove the panel to access it. You can use hot water to thaw it out and you should be in good shape.
Kelly
Posted on Mar 24, 2011
How do i manually defrost my freezer
hot water, outside of that the inside of the freezer will have to come out and the defrost switch and ,or element will have to be replaced
Aug 20, 2012 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I just bought a house with a Kenmore stainless steel bottom drawer freezer. The freezer drawer does not close completely and large amounts of snow and ice accumulate inside. I have taken the drawer out,...
Check top see if the arms of the drawer are fully seated into the rails which support it and extend from inside the freezer when the drawer is opened. On most french door refrig's, there are hooks on the back side and tabs on the front side which are sometimes hard to get back in. Then the door is locked into the rail with a screw at the point where the rail meets the freezer door.
Aug 21, 2010 | Kenmore 73503 Stainless Steel Bottom...
Water collecting under the freezer drawer, then freezing
We just had a similar problem with our Maytag side-by-side in the bottom of the freezer. Just as you described...sort of a glacier on the floor of the freezer that slowly melts toward the door. After several attempts to remove the ice, only to have it form again, my husband spoke with a helpful sales person in an appliance center. He said there's a drainage plug/line on the back that's supposed to funnel condensation to the evaporation tray underneath. It gets clogged and frozen. Sure enough...my husband pulled out the freezer, opened the visible line and it was all frozen and full of gunk. He had to use a hair dryer to thaw it out, then flushed it. It was amazing how much stuff came out of there. We've had no more problem since.
Apr 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have water under the crisper drawers in my fridge. The water at the bottom on the ?condenser does not seem to be draining what can I do? Thanks Mary
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clear the bottom of the refrigerator so you can get at the drain. Then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the freezer side as well.
Good Luck,
Gilshultz
Dec 01, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Freezer is leeking water into the bottom of it ,
I had the same problem.
This is how I solved it.
Remove the bottom drawer of the freezer. There was a lot of ice built up.
I chiseled it out, and then looked in the back.
There is a drain hole that was blocked by a fallen popsicle that melted, and then the plastic wrapper plugged the hole.
Check that the hole is not blocked.
Also, it is always a good idea to remove the bottom black vent cover under the fridge and clean out any dust build up with a vacuum.
Good luck.
Oct 24, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite bottom freezer drawer won't shut
Has something fallen behind the drawer, and is preventing it from sliding back all the way? Remove the drawer by pulling it all the way out and lift it up and out. Look for anything that has fallen back there.
Dec 31, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore bottom freezer 795.75092402 freezer doesn't open
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
Jun 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
