SOURCE: canon ip4300 service error b200 green and
Try this:
Pull the power cord out of the back of the printer.
Then move the printhead to the center and pull out the ink and the printhead. Clean the printhead and examine the bottom for burned areas.
With the printhead still out, close the cover and plug the power in and turn the power on. If your printer isn't damaged, it should go through all diagnostics and give you a solic green light. This means you probably need a new printhead.
SOURCE: orange flashing light
check if the printer caterage is in the printer, if their check if their is any paper jam on the printer or top cover door sensor could be damaged.
that is the problem of your printer
SOURCE: hp deskjet 5652 not printing, orange light flashing continuously
1. Check to insure the cover is shut down completely.
2. If the "Ink Drop" Icon is blinking you are either out of ink, or there is a problem with the cartridge carrier. So open the cover - the carriage should move to the middle, if not it is bound up somewhere. Check the guides and around the carriage area for gummy labels etc..
3. If the carriage moves to the middle, release the ink cartridges and replace.
4. If the "Arrow" Icon is blinking, this could be a result of a paper feed error. Remove the paper from the tray, open the cover and insure no jams are in the rollers. Shuffle the paper lightly and place back in tray. Check to make sure the tray is pushed completely forward and then press the "Arrow" Icon button until a sheet is fed into the printer.
* * Note: When you are replacing the Ink cartridges and before you remove the tape from the bottom heads, give them a shake to lossen up the ink before installing.
This link will take route you to HP's support and more troubleshooting techniques for your printer.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00013363&lc=en&dlc=en&cc=us&product=304442&rule=35720&lang=en
Hope this helps..
God Bless.......
SOURCE: hpd4160 printer yellow light keeps flashing, status, "off line"
See this notice about the flashing light. Then see this article, particularly step 4. You may need to clear the print queue & restart the print spooler. Make sure you reboot your system. If that doesn't correct the issue, try a power reset as described here before uninstalling or reinstalling the printer software.
The printer uses your system memory to print from, and communication glitches do occur.
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
How many times does the light flash? It can be from 2 to 8 times. The number of flashes can designate the problem.
