I need a wiring diagram for a 1998 mitsubishi lancer for the instrument cluster
  • 48 Answers
SOURCE: 1995 Neon Instrument Cluster Wiring Diagram
are you talking about the wires that connect the car harness to the gauge cluster with the 2 big plugs?
Posted on Jul 17, 2008
ilragatzzo78
  • 241 Answers
SOURCE: want engine / wiring diagram for Mitsubishi Lancer Ralliart Sport
i need your email so i can send you the images i cannot load them here for some reason
Posted on Jan 08, 2009
Molson02536
  • 3854 Answers
SOURCE: I hae a 2002 mitsubishi lancer I need wiring
Here is a link that should help you get the wiring colors you asked for. Good luck and hope this helps. http://www.installdr.com/Harnesses/Mitsubishi-Wiring.pdf
Posted on Oct 28, 2009
  • 96 Answers
SOURCE: I hae a 2002 mitsubishi lancer I need wiring radio
i dont have a pic but it goes like this..
(color1/color2 usually means the wire has a stripe or dots on it)
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Blue
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Black/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Yellow/Blue
Left Rear Speaker Negative Wire (-): Gray/Blue
Right Rear Speaker Positive Wire (+): Yellow/Red
Right Rear Speaker Negative Wire (-): Gray/Red
SOURCE: 4g15 mitsubishi lancer wiring diagram for
Pliz try: www.haynes.com
Posted on Jun 22, 2011
Wiring diagram of mitsubishi lancer 4G18 2003
Wiring diagrams are broken down into systems like lighting, engine etc. What system do you need a diagram for??
Mar 11, 2016 | 2003 Mitsubishi Lancer
Mitsubishi challenger pinout diagram for instrument cluster
No chance the manfacturers do not release this sort of information or the ECU pins only to the dealers .
Feb 11, 2012 | 1996 Mitsubishi Montero Sport
WHERE IS THE BULB MR 444536 LOCATED INT HE DASH CLUSTER OF 2003 MITSUBISHI LANCER
the bulb MR444536 is located at the back of the instrument panel, they luminate the 4X4 lights on the dash and are used for other ilumination on the pannel as well.
Aug 04, 2011 | 2003 Mitsubishi Lancer
Mitsubishi Lancer Need fuse box diagram, which fuse is what. My son bought this car and the owners manual was missing and he is having trouble figuring out which fuse works what. Thank you for the...
The Mitsubishi Mirage is a subcompact car produced by Mitsubishi Motors from 1978 to 2002. It was also sold as the Mitsubishi Colt or Lancer.
The following wiring diagram and electrical circuit/schematics manual provide detail information about the electrical system description, illustration and troubleshooting of Mitsubishi Mirage 1999 models: Mitsubishi Wiring Diagram
Hope helped.
Oct 16, 2009 | 2002 Mitsubishi Lancer
Instrument failure lancer 2001mitsubishi coupe
On my Bitsasushi Lancer CE 2000 i found a Hairline crack on Vinyl PCP about 6 o'clock when viewing Cluster right way up at rear where Vinyl circuit folds over under plastic Tabs, looks like power supply to Warning Lights, i just Spent 5 mins scraping Blue Vinyl to reveal Crack a Dab of Solder a Dollop of clear Laquer(Naily-Polish) inserted Cluster
Oct 26, 2008 | 2002 Mitsubishi Lancer
DASHBOARD INSTRUMENTS STOP FUNCTIONING IN MILD TO WARM WEATHER. LANCER MR COUPE 1998 MODEL
I HAD THE EXACT SAME PROBLEM WITH MY 2000 LANCER MY DASH WOULD WORK THEN ALL INSTRUMENTS WOULD NOT WORK INDICATORS LIGHTS WORKED IT WAS WEIRD AFTER 3 MONTHS GOING TO AUTO ELECTRICIANS MECHANIC ANYONE REALLY IT WAS FIXED ON FRIDAY 11TH DEC 2009 !!!!
I TOOK IT TO A PLACE CALLED ADVANCED AUTO INSTRUMENTS IN REVESBY SYDNEY PH9792 7399
WHEN I CALLED THEY NEW EXACTLY WHAT WAS WRONG WITH MY CAR BEFORE I TOLD HIM.
HE SAID IT IS A FAULT WITH THE LANCERS AND THEY ALL SHOULD HAVE BEEN RECALLED BUT OF COURSE THEY DID NOT BASTARDS
ON MY RECEIPT IT SAYS REMOVE AND REFIT CLUSTER FROM MITSUBISHI LANCER REPAIRED SPEEDO CIRCUIT BOARD AS REQUIRED CAUSING ALL GAUGES TO STOP WORKING $135.OO ONLY I AM OVER THE MOON
HOPE THIS HELPS SOMEONE
Oct 17, 2008 | Mitsubishi Lancer Cars & Trucks
Speed sensor a
if the problem was the speed sensor then the problem is fixed. But if it was something wrong with the instrument cluster then that needs to be taken apart or replaced. The cluster could have loose or broken wires in them.
Sep 19, 2008 | 1998 Mitsubishi Eclipse
1997 CE Lancer speedometer
i had the same problem on my g/f's 2000 lancer GLXi, (with tacho),
i fixed the problem by putting a jump wire on the back of the instrument cluster,
the fault was in the wiring to the tacho part & i drew up my own wiring diagrams for the cluster unit,
then traced the fault,
looking @ the back of the cluster unit, the top right hand screw for the speedometer,,, follow the track on the circuit-board, there is a link wire UNDER the board (there is a dotted line on top where it goes, i think its the left 1,,, there is 2) this track then goes to the bottom left screw on the tacho,,,
i soldered a small gauge wire from the bottom of the link solder joint (MAKE SURE ITS THE CORRECT LINK, THERE IS 2 SIDE BY SIDE) to the bottom right track on the vertical plug socket (its common pos for the warning lights) this is where the "MIRAGE" & other "CE LANCER" (without tacho) gets its speedometer & gauges power from,
kind regards waz
if anyone needs a photo i will pull out the dash again lol its only 6 screws
Jul 17, 2008 | 2003 Mitsubishi Lancer
jasbo
jasbo
