Question about Dell 4210X DLP Projector
I have had my dell 4210X ceiling mounted projector / smartboard in my classroom for a few months. In the beginning I could turn everything on and use the blank screen option throughtout the day. Recently, the projector powers down/turns off without notice and in different scenarios. Did I change a setting that is powering it down or is a projector malfuction?
  • 442 Answers
Have you checked the air filter for dust etc
what leds come on as it shuts down.
I suggest that you take it down and run it on the bench normal way up and see what leds come on etc
Posted on Mar 26, 2011
What is the cause of Dell 4210X projector temp and lamp flashing amber?
This is going to be the lamp itself. Once you replace it will have to be reset back to zero hours to work properly
Sep 07, 2015 | Dell Office Equipment & Supplies
Dell 4210x projector temp.,power and lamp flashing red when you plug it in
Internal short switch was tripped, just do a factory reset.
Jun 07, 2015 | Dell 4210X DLP Projector
Anyone know where i can get a color wheel for a Dell 4210X projector
you can contact me for original DELL 4210X projector color wheel. i know the source, it is very cheap.
Jan 12, 2012 | Dell 4210X DLP Projector
My office has a Dell 4210X projector. When we turn the projector on, a message appears that says it cannot display the current resolution. If we re-start the Dell Desktop computer that is hooked up to...
The PC interigates the projector when it is booted, that is why it works when connected for the second time. If you connected it up and after waiting for the projector to boot, then boot the PC, it may well save you the trouble of resetting the resolution to match the projector.
Hope that helps.
Mar 03, 2011 | Dell 4210X DLP Projector
The projector turns on but there is no output and the projector has a red flashing light.
hi,
check ur projector lamp, is it faulty or is there is any problem with its connections. also check the lamp cooling fan is it is faulty or not.
ok
Dec 23, 2010 | Dell 4210X DLP Projector
LCD Ceiling-mounted projector keeps overheating.
canned air from the outside is good, but a lot of the dust collects on surfaces and bakes on. for best results, remove the top cover and blothe dust out of every nook and cranny, wipe it off of the fan blades, and make sure all of the fans spin well. you may need to replace the temp sensors if it happens too frequently. also, during the winter when the heat is on full blast, it tends to get very hot on the ceilings. is there enough air flow in the room? lastly, make sure they turn them off at the end of the school day. this will lenghten the life of the power supply and the lamp.
Jan 25, 2010 | InFocus IN24 Multimedia Projector
Casting image lower on wall
I don't know the model number for your projector, but most projectors are designed to place the image level with the bottom of the projector, which works great for tabletop mounting but not so great for ceiling mounts.
If you're mounted at ceiling height, try turning the projector upside down to see if it places the image in the right place on your screen. If that fixes it, then use the on-screen menus for your projector to flip the image and you should be all set.
Dec 09, 2009 | Dell Office Equipment & Supplies
EIKI EIP 5200 won't display anything
it's overheating. clean it out with canned air. dust keeps in the heat that the projector is trying to expell. it also decreases the air flow.
Apr 28, 2009 | Eiki EIP-10V Multimedia Projector
Nec projector
go into menu, under image, and chose ceiling.
Apr 08, 2008 | NEC VT37 Multimedia Projector
Dell 4210X DLP Projector Logo
345 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
