Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
Last year I had to throttle it to keep the RPM's where it would run good enough to get the job done. As of 3/24 it won't even start. The gas is spot -on for the mix. Now, the primer bulb won't come back when I prime it. I pretty well figure it needs a carb. kit. Know where I can find one? But, I think the carb. needs adjustment, too. If it was a Rochester, not a problem. But, these little ***** dude's are a headache. Thanks in Advance
    Genius:
  • 1,267 Answers
You are right that you probably need a carb kit to rebuild the carburetor. It is not much of a carburetor as it has a idle adjustment screw and a high speed adjustment screw that meters through a very small orifice drilled into an aluminum block. It has a small fuel pump and a thin flapper valve arrangement. The problem with these small carburetors is that the gasoline oil mixture if left in the tank over winter solidifies on the tank filter and the internal parts of the carburetor. The flapper valve in particular is only a thin plastic type covering of an air channel that gets solidified over the inlet orifice and blocks the flow of fuel to the machine. The carburetor is more likely a Walbro which is used on many of the garden tools. See: http://www.buycheapr.com/us/result.jsp?ga=us11&q=poulan+carburetors
You may be able to just take the existing carburetor apart and clean it both the orifices and the gaskets and flapper valve. Don't forget the tank pick up filter as well. The alcohol laced fuels that we have to use now, increases the problem of blocked carburetor parts. When storing the machine for longer than a month, remove all of the fuel and put some sea foam or other gasoline additive in the tank, and when activating, use fresh gasoline with a small amount of additive to help clean the carburetor. I have had some success with removing the old fuel and adding fresh fuel mixed a little heavier with oil and a little seafoam, cranking the machine about ten times to get some fuel into the carburetor, then let the machine sit overnight to help dissolve the built up gunk. After you get it running then remove the fuel and add correct mixed fuel.
Posted on Mar 25, 2011
Ok I got saw running good fast but won’t idle?
the sequence to throttle adjustment is to adjust to high speed first ( screw closest to the air filter) turn in in or out until it fires evenly at rpm and picks up rpm easily
now hold the throttle at full throttle and slowly idle down while adjusting the idle screw ( closest to the butterfly) to maintain engine running
the screw should have been turned all the way in then back out 1 1/2 turns before starting the engine
keep slowing the engine while making very small adjustment until it idles at rpm slow enough that the chain is not driving
If you get it low but it stalls out , then adjust the throttle stop screw to maintain idle rpm
Correct adjustment is from this point the rpm increases rapidly with out falter ( fine tune high speed screw to achieve that)
and when left to idle will do so evenly without driving the chain
all of this working is depending on the carby having new diaphragms , needle height adjustment correct and the system cleaned out
Apr 11, 2018 | Fast Garden
I have a Craftsman Snow Thrower model # 247.881731. At the end of last year I drained the gas as recommended in the manual, this year I filled it with fresh gas and it now has a problem starting. I pu
Draining the gas from the tank doesn't drain the float bowl in the carburetor. It still had last year's gas in it. Gas will start to turn to varnish if left sitting 6 to 12 months. You'll probably have to remove the carburetor, disassemble it and clean it out with Gumout carb cleaner or some similar product.
When you get it running and the snow's over and done with, put some Stabil in the gas tank to prevent the gas from converting to varnish and then start it up and run it until that stabilized gas is through the carburetor and into the engine. You can leave it with the treated gas in the tank.
Feb 01, 2015 | Craftsman Snow Blower 26 In. 208CC...
How do i get it to idle at a smooth pace and go over 1500 rpm
car ran good last month or 3 years ago?
timing ?
CAM?
or SPARK?
or both?
my guess cam, so did you check compression last?
to make sure its all over 150PSI on all cyl. , warm to hot engine. done wide open throttle with spark plugs removed.?
this is the validation step that, you did it right.
there is no other ways.
Oct 17, 2014 | 2006 Saturn Vue
2000 gsxr600y Flat spots and rough running at 8 and 11 thousand rpm, won't pull passed 11000 from 4th gear up as running so rough
Full disassemble of carbs is needed. Thorough cleaning on jets and airways, vacuum and pilot screw adjustment must be done too.
Check the spark plugs for lean mixture indication and replace them if necessary.
Oct 20, 2012 | 2000 Suzuki GSX-R 600
Car won't keepidel1989 300e Car won't keep idel, starts up runs for a while but cutsoff
first ensure your spark plugs, wires, cap and rotor/coil packs are in good shape. once thats done check for a check engine light, sometimes they come on then go off but a code will be stored regardless. once you have made sure your getting good spark and there are no trouble codes the issue is most likely a dirty throttle body or fault IAC (idle air control) valve or throttle positioning sensor. hope this helps, good luck
Mar 15, 2012 | 1989 Mercedes-Benz 300-Class
1995 SC1 280K oil burner. Kept full. Previously 41 mpg, now 27 mpg over 1 year span. Oil smells like gas and so does the exhaust. Extreme loss of power. Will not idle. Runs rough at lower rpm, but...
If you are keeping the car forever, swap the engine with a rebuilt one. there are many for sale out there.
about $2k for a rebuilt with core credit. if you are really just keeping it for a year or two until the front "frame" collapses, buy a used engine out of a junkyard, look until you find one with less than 100k on it. there are many for sale on eBay but the shipping will kill you and you most likely have junkyards closer to home.
note if you have an SC1 means SOHC so you have to have a SOHC donor vehicle. SC1,SL1, or SW1
the engines were the same 96, 97,98 i believe. but do not get an older engine.
Aug 31, 2011 | 1996 Saturn SC
93 chevy suburban v-8 tbi hard to start, but starts, will run but will not idle, can keep it running or driving as long as you rev engine constantly. Holding engine at half throttle it will slow and die. ...
Assuming your engine is in good mechanical condition, there are only a few options.
1. You may have a vacuum leak.
2. The pickup in the distributor may be worn to the point that it is sloppy at idle but normal at higher rpm.
3. Idle control valve/motor may not be working properly.
It probably isn't an ignition related problem as the problem would normally get worse as RPM increases. I've seen #2 about 5 times in the past year or 2 so it's not uncommon and would recommend replacing the entire distributor if you come to that conclusion, but would definitely check all vacuum hoses first.
Jun 24, 2011 | 1993 Chevrolet Suburban
I HAVE BEEN HAVING PROBLEMS WITH THE TRANSMISSION CHANGING GEARS AND SHAKING. I WAS TOLD THAT I NEEDED A NEW TORQUE CONVERTER. I HAVEN'T USED THE CAR IN OVER A YEAR AND A HALF AND I WANT TO FIX IT. THE...
improper maintenance--throttle body needs cleanin etc with tuneup-new plug wires etc----get a repair book at parts place--------tranny is old so it cud be many things-maybe the tv valve that aids in shiftin needs ajust--there are test for the torque convert--a pressure test is done on the fluid-if it is normal then look at other things also like a solenoid, a governor, an accumulator--------scan car and maybe do a fluid and filter change
May 07, 2011 | 1998 Plymouth Neon
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
283 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
