Why my computer is not turning on my monitor but the cpu is running
    Problem Solver:
  • 12 Answers
Need more information:
1. Are you sure the monitor is plugged into power?
2. Are you sure the monitor VGA cable is connected to the computer completely?
3. Is there an indicator on the monitor (a light).
4. When did it stop working? What changed?
Sometimes the power cord in the back or bottom of the monitor comes loose. Ensure all wires are securely connected.
BobB
Posted on Mar 24, 2011
How to turn on sound for Flatron IPS235
flatron functions only as video monitor, audio is run or provided through a separate device connected to CPU computer or other sources connected to video player.
Feb 21, 2014 | LG Computers & Internet
Monitor says no signal
Fix the power cord firmly! hold it and fix it such that you wont get a shock! also fix the cord from monitor to CPU firmly! I prefer you to turn off you computer..clean the power cord by blowing the dust on sockets and pins and then fix it firmly and turn on computer again! Make sure power is not running in the cord while you clean it!
Oct 17, 2010 | ASUS VW193T Monitor
My lg monitor always turns off and says "ANALOG SAVING MODE" and my cpu turns off too i dont know if the problem is on the cpu or monitor
The CPU should not turn itself off, it should run without the monitor attached, you can try reseating all the cards and memories, blow out the dust built up inside the box and the power supply. Please post back what you find.
Aug 31, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
My monitor wont turn on but the cpu is running
Please check with another monitor and make sure computer is working fine. Since CPU is running it may not be the issue with computer. After check with another monitor please contact your technician.
Jun 15, 2010 | AOC 7 F-SLK 17" CRT Monitor
Monitor cuts off
This could be the result of a few different things. If you haven't checked, click start, control panel, performance and maintenance, and power options. In this box, there should be numerous setting possibly pertaining to your specific problem. Also, ensure your cpu fan is running. A failed cpu fan will make your monitor turn off. Additionally you will have to make sure your power supply isn't bad. The easy fix is the first of the issues though.
May 26, 2010 | E-Machines eMachines Monitor E15T4
Cpu no up, monitor shows
could be the whole pc is fried :(
Jul 10, 2009 | Computers & Internet
Sleeping Monitor
check your video card remove from the system then clean up the gold tip second remove the memory then clean up the gold tip then put it back to the board then restart your CPU
Apr 16, 2008 | HP f2105 21" LCD Monitor
LG 194wt
This is most likely not a problem with the monitor but rather a problem with the computer. do you hear the fans running in the computer? If so then the Power Supply seems to be working which would leave the most likely things are CPU or motherboard and the only way to determine which one it is would be to try the CPU on a different motherboard or try a different CPU in that motherboard.
If the fans do not run then the problem is most likely the Power Supply. The biggest problem here is that although what I have outlined is the most likely problems there are other things that could cause this and whether the fans are running or not it could still be the CPU motherboard or Power Supply. If you can I would check the voltages from the Power Supply or at least get a power supply tester to see what that shows and work from there.
Nov 13, 2007 | LG L1915S 19" LCD Monitor
Pc automatic turn off
see the system temprature is cool it happen normally bcoz ho heat see your graphic card fan is working fine and it is not generating more heat. bye
Sep 12, 2007 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
