Question about Maytag EPIC MFW9700S Front Load Washer
I would like to know how many gallons of water this machine uses per washload. Maytag Epic Front load Washing Machine Model # MFW9800TQO
    Sergeant:
  • 170 Answers
Around 5 gallons per FiLL more then 1 fill per cycle add up all the fills for the cycle that you use..that will give you the total water used...hope I helped thanks for voting...
Posted on Mar 25, 2011
Washer capacity of kenmore 4906 4907 ie 5.0 cu feet
The Kenmore 592-4907 residential clothes washer is a front load washing machine. It has 3.69 cubic feet of volume, an expected energy use of 149 kilowatt hours (kWh) per year and an expected water use of 4773.384 gallons per year.
The Kenmore 592-4906 residential clothes washer is a front load washing machine. It has 3.69 cubic feet of volume, an expected energy use of 149 kilowatt hours (kWh) per year and an expected water use of 4773.384 gallons per year.
This is the Specs website despite the title :>)
teachmefinance com
Mar 24, 2017 | Kenmore Washing Machines
Maytag Epic Z won't Drain after rinse cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
Wter usage per load/cycle
When set on large load, it will use close to 30 gallons of water. On the smallest load setting, it will use right around 20 gallons. This is what makes the new front load washers look so good. They average around 4 - 6 gallons per load. Have a great day.
Oct 18, 2009 | Kenmore Washing Machines
Odors on the clothes after washing in Maytag front loader
The brand of your front loader is not that material on this issue. What is happening is that your old top load washer may have used as much as 45 gallons of water per cycle, while some front loaders use as little as 12. Because of the low water use, you must cut back on the additives you are using. Use only 1 tablespoon of HE detergent (even less if 2x or 3x detergent) per load. If you use fabric softener, use only 1 teaspoon per load. Odor on clothes after wash is indicating that the detergent and or softener has not been fully rinsed out. If you throw a load of washed towels into your machine and start a cycle without any soap, then stop the cycle, you should not see any suds. If you do, there is obviously soap left in the clothes. With bath towels, the towels are used to absorb clean water off a clean body. They do not need soap when you wash them, and never use fabric softener on towels.
Oct 23, 2008 | Maytag EPIC MFW9700S Front Load Washer
Reset childlock model mah2400aww
did you try to unplug the unit for 30 minutes
Oct 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Should I see water in my machine when it is washing?
may see some but not much..front loads only use 4-6 gallons and is adj as water is absorbed by clothes ..a typical top load will use 25 gallons or more per fill thats 50-55 gallons per wash verses 25-30 for front loads also you should see very few suds ..be sure to use HE detergents to prevent oversudsing
Aug 20, 2008 | Kenmore Elite 45986 Front Load Washer
Code error f07 indesit washihg machine
Per Maytag, they suggest you unplug the washer for 20 minutes and see if that resets the circuit board.
Jan 14, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
228 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
