I have the canon w8200, and am getting the waste tank full message. Where is the waste tank? How do I change it out? How do i reset it ( the instructions you posted do not match the menu options)
  • 10 more comments
  • ronjamesfilm Mar 25, 2011
    Hey, this is the same solution that is already on the web site and as I SAID... The instructions do not match the interface. Also, I asked WHERE IS THE INK WASTE TANK AND HOW DO YOU GET TO IT TO CHANGE IT. I cannot find any documentation anywhere that shows where it is located inside the printer.
    Please get me on the right track. Thanks, ron
    Okay this is ridiculous.
    FOR THE THIRD TIME, I ASK YOU, WEHRE IS THE WASTE TANK AND HOW DO I CHANGE IT OUT.
  • ronjamesfilm Mar 28, 2011
    Okay this is getting stupid. The waste tank info you sent me is for consumer printers, the w8200 is a large format printer. the info does me no good. There is a canon guy on fixya, get him to help me please. I am only going to say this ONE MORE TIME> I need to know where the waste tank is on the CANON W8200 and how to change it.
    You're kidding me, right? This is the same canned answer that is on the site and its wrong.
    okay one more time: WHERE IS THE INK WAST TANK ON THE CANON WS8200 AND HOW DO I CHANGE IT OUT.
  • ronjamesfilm Mar 30, 2011
    Dude, it doesn't work. . Now I have been going back and forth for days. ONE MORE TIME:
    come on, man. I need this answer:
    Your instructions:
    "Now under Service Mode select Counter, and select Printer and W-INK to reset it, and under initialize selectW-INK."
    THERE IS NO INITIALIZE OPTION ON THE WASTE INK COUNTER, NOR CAN I SEE HOW TO RESET IT
    WOULD YOU PLESE READ MY QUESTION CAREFULLY AND ANSWER IT PROPERLY? THIS IS STUPID
    Well it would help if you would read the question and answer it. whats wrong with you?
  • ste_polecat
    ste_polecat Dec 19, 2012
    The waste ink container is on the right side of the printer but you have to take the panel off the side and the control panel(power switch) etc.Then you have to remove the strange shaped metal panel under the side panel which covers part of the head cleaner.
  • ste_polecat
    I should add that you also have to remove the filter on the back on the right hand side of the printer so you can pull the ink waste cartridge out
  • ste_polecat
    It is a pain to do but once you have done it it is easy to do again.
  • 2,632 Answers
Welcome to Fixya. You can try the steps below and see if it will be fixed. You need to enter the service mode for this one to reset it.
How to enter Service Mode
1. Turn off the printer.
2. Turn on the printer while holding down the [Paper Source] button and [Online] button.
3. Check that "Canon W8200" is shown on the display, and then release the buttons.
4. Next, "SERVICE MODE" is shown on the display. (If sheets are inserted, this will be displayed after the sheets are loaded.)
5. Use the [Lower arrow] button to make a selection. Service mode is added to the options in the Main menu.
Service mode can be entered even during error status (when Exxxx and Wxxxx are shown on the display) by turning the power off and then using the above key operation.
How to exit Service mode
To exit Service mode, turn off the printer
Buttons used in Service mode
- Selecting menus and parameters: [Left arrow] button or [right arrow] button
- Entering a lower-level menu: [Lower arrow] button
- Entering a higher-level menu: [Upper arrow] button
- Setting menus and parameters: [Enter] button
Now under Service Mode select Counter, and select Printer and W-INK to reset it, and under initialize select W-INK.
If you have questions please let me know. Thanks for using Fixya
Posted on Mar 28, 2011
  • 2 more comments
  • Rofel Lantican
    Rofel Lantican Mar 28, 2011
    Hi - The error can be fixed by just resetting the printer
  • Rofel Lantican
    Rofel Lantican Mar 30, 2011
    the post was the answer on how to reset it
  • Rofel Lantican
    We are trying to help you here sir if your not satisfied with my answer you can always consult our other expert.
  • Rofel Lantican
    the one that you need to replace is the waste ink absorber on the system
  • 1,679 Answers
A) How to enter Service mode
Follow the procedure below to enter Service mode.
1) Turn off the printer.
2) Turn on the printer while holding down the [Paper Source] button and [Online]
button.
3) Check that "Canon W8200" is shown on the display, and then release the buttons.
4) Next, "SERVICE MODE" is shown on the display. (If sheets are inserted, this will
5) Use the [Lower arrow] button to make a selection.
operation.
b) How to exit Service mode
To exit Service mode, turn off the printer.
c) Buttons used in Service mode
• Selecting menus and parameters: [Left arrow] button or [right arrow] button
• Entering a lower-level menu: [Lower arrow] button
• Entering a higher-level menu: [Upper arrow] button
• Setting menus and parameters: [Enter] button
Now under service mode select counter, and select printer and W-INK to reset it, and under initialize select W-INK.
But also change the waste ink absorber so that you do not get waterfalls of ink from your plotter :-)
Hope that helps
Posted on Mar 24, 2011
  • ONE-Touch-Solution
    ONE-Touch-Solution Mar 25, 2011
    You can try these steps below, could be the model is different.
    1. Power Off Printer
    2. Hold RESUME button then press and hold Power ( the beeper may sound once or may not )
    3. Hold Power and Release RESUME
    4. Press Resume twice then release both POWER and RESUME buttons
    5. When the Indicator lights steady, press RESUME 3 Times
    6. Press Power to set Data
    This should fix it
    ONE-Touch-Solution Mar 26, 2011
    This link below will give you the details where you locate the waste tank in your printer. You can follow the instructions on it
    Waste Tank
    Also, if you want you can refer the link below.
    Waste Tank Link 2
Waste ink is full how to clear this message
a) How to enter Service mode
button.
operation.
Hope that helps
Jul 30, 2010 | Canon imagePROGRAF W8200 InkJet Printer
I own a canon w8200 pigment large format printer. I replaced two cartridges, Magenta and Yellow. The printer did a nozzle check that seemed to take too long. I then received a 'waste ink tank full'...
<Remedy>
1.Waste ink absorber
Use SERVICE MODE>COUNTER>PRINTER>W-INK to check the waste ink
absorber. Replace if the waste ink level is near the limit (14400).
After replacing the tank, perform SERVICE MODE>INITIALIZE>W-INK.
Apr 04, 2010 | Canon IMAGEPROGRAF IPF8000 InkJet Plotter...
Canon I965 waste tank almost full - how do I clean/empty or clear
You will have to get it replaced by a Canon agent.
Phone Canon for nearest agent
Just had mine done cost £50.00 +VAT
The codes on line to reset counters will not solve the problem and eventualy ink will leak from the printer.
Feb 24, 2010 | Canon BubleJet i965 InkJet Printer
A message saying waste tank nearly full comes up and i need directions to fix it?
Hello. this message indicates that the computer merely has to be reset [canon is hoping you will take your printer to them for a costly tuneup] here are the steps to reset your counter:
Manual Reset procedure for waste ink tank full error in Canon Smartbase MP730 printers:
  • Hit the “menu”: Key
  • Hit “Copy” Key
  • Hit “#” Key
  • Scroll thru the menu headings until you come to “Test Mode” - 12th heading
  • Hit the “3′ button- this will bring up Eeprom Clear
  • Hit “0′ button
  • Hit the “Stop” button
Here is a link where you can download the entire service manual for $4.00. http://www.tradebit.com/filedetail.php/4546475-canon-smartbase-mp360-mp370-mp-360-370
Oct 13, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Waste ink tank nearly - message
it won't stop until the ink absorbers are replaced and the error reset in canon diagnostics. A shop repair, around $100.00
Jul 15, 2009 | Canon SmartBase MP390 All-In-One InkJet...
Error Message
Contact Canon support ot refer to
www.fixyourownprinter,com
type your printer make model in the field.
Jan 16, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Waste ink tank full..error 5B00
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Waste PAD ink Reseterfor Canon Pixma iP6320D
You need to Remove the ink Cartridge first in order for the code to take effect.
1) Closethe print head cover.
2) While pressing the Stop/Reset button, press the Power button. (Do not release the buttons. TheLED lights in green to indicate that a function is selectable.)
4) While holding the Power button, release the Stop/Reset button. (Do notrelease the Power button.)
5) While holding the Power button, press the Stop/Reset button 2 times,(Canon idle will appear)and then release the Power and Stop/Reset buttons.(Each time the Stop/Reset button is pressed, the LED lights alternately ineither orange or green, starting with 0.
6) When the LED stops blinking and lights in green, press the Stop/Resetbutton 4 times. (Each time the Stop/Reset button is pressed, the LEDlights alternately in either orange or green, starting with orange.)
7) Press the Power button 2 times. ( the '' Canon" appear twice).The LED lights in green, and the selectedfunction is performed. (When the operation completes, the printer returns tothe menu selection mode automatically.)
8) Power off then back on and test.
9) Congrats!!
Prepared By Jeffrey Vicada (EDS- Technical Engineer) Philippines
Dec 03, 2007 | Canon Pixma iP6210D InkJet Photo Printer
Canon muti-pass MP360 INK TANK FULL
I believe what you are seeing is "WASTE INK TANK FULL"? This means that the tank that collects the waste ink from cleaning the head is full. You can read more than you ever want to know on this subject on the following link: http://www.fixyourownprinter.com/forums/printer/38697#1 These are the steps to clear the message by reseting the counter: 1)Printer on, press Additional Functions, Scan, Copy, Scan Now you should be in service mode from there for waste ink tank reset 2)Select Test mode which is like the last available selection 3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other options this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button The menu will now say EEPROM Clear Select Ink count which is option (0) and press set Your done!
Aug 03, 2007 | Cannon MULTIPASS C530 Printer
341 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
