Question about Uniden DECT 6.0 Cordless Phone ID
I have a unden dcx150 and i tried to register a handset accssory but keeps coming uoregistration failed
  • 1,940 Answers
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Mar 24, 2011
DS6321 out of range, no power at base
This sounds like a registration problem, the handset(s)
and the base have lost identification with each other.
I. To address this, first de-register the handset(s) ---
do this procedure for each handset:
0. Start by taking off the battery compartment cover....
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??", press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY (why the cover was off)
9. Wait ~30 seconds, re-connect the battery & replace the cover
10. display reads "Not Registered" ===============================
II. To register the handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #1" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a few
hours and try the registration ( II ) again.
NOTE: the base can only handle 5 handsets and will
increment the number of each handset registered
until "Handset #5" has appeared, even if some of
the handsets are lost/not in use. Trying to register
more than 5 handsets will result in "Registration Failed."
III. To clear the base of all handset registrations and
be able to start registering again at Handset #1:
1. press [Find Handset] on the base and hold past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink.
2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration
3. for multiple handsets, return to II. above and
register each handset in turn.
Good luck !!
May 02, 2016 | Vtech Lands Phones
I attempted to register several new TCX 905s to my TRU 8866 base without success. I followed instructions from the owner's manual, from Uniden customer support, and from suggestions from this web site. ...
October 10th, 2013 at 9:19 amPROBLEM:
After de-registering handset, handset displays [REGISTRATION FAILED; UNAVAILABLE] when trying to register handset.
This worked for my UNIDEN TRU-9480-2
SOLUTION:
1) Remove handset from base
2) Remove power cord from back of base
3) Press and hold the [find hs] button on base as you plug the power supply back in; the charge light should then be blinking.
4) Return handset to base and it should register
GOOD LUCK!! HOPE THIS HELPS!!
Oct 04, 2013 | Uniden Lands Phones
I can register the handset d1660 in base dect1580?
No. The DECT1580 works with the DCX150, DCX200, and DCX300 handsets.
Apr 15, 2013 | Lands Phones
My Uniden 1560-3 has out of range on all handsets but one. I only have a dial tone on one handset. Please advise how I can correct this problem
Reset the hand sets that are out of range by doing the following:
1) Press and hold END and # for at least five seconds.
2) Move the cursor to select Base Unavailable and then press Menu/Select.
3) Select the base which you want to de-register from, and then press Menu/Select. Base Unavailable appears.
4) Move the cursor to select Yes, and then press Menu/Select. You hear a confirmation tone,
(For DCX150 handsets)
5) Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
6) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
If the display shows Registration failed, repeat the process again.
(For DCX200 or DCX300 handsets)
5)Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding
find until the charge LED starts to blink.
6)When charged, registered handsets display a handset ID number. Handsets that have not been registered display:
7) On the handset, press and hold # until the handset beeps and displays Handset Registering.
8) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
User Manual Available Here
Jun 16, 2011 | Uniden Cordless Phone
I just bought another handset (DCX150) to use with my Uniden DECT1580 phone and cannot get it registered for use. The phone is completely charged but after holding down the # key for 30 seconds (as...
I had the same problem with the same equipment and I found this on the web. It worked well for me.
* Remove the base unit's phone from its cradle.
* Unplug the power from the base unit.
* press and hold the FIND button on the base unit, then, while continuing to hold down the FIND button, plug in power again. The CHARGE light should then be flashing. You can release the FIND button.
* press and hold the # (pound) key on the accessory phone you are attempting to register to the base unit and hold this phone OVER and NEAR the cradle/charging prongs until the phone goes through the registration process. (again, don't set the accessory phone in the unit, but just hold it near the unit).
Sep 11, 2010 | Uniden DCX150 1.9 GHz 1-Line Cordless...
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
Jul 21, 2010 | Uniden Cordless Phone
Purchased addt'l handset to work with my CEZAI2998. It has a corded handset in the base and an accessory handset with charger. Needed another accessory handset; purchased EZX290 but can't get it to...
The CEZAI2998 does allow up to a total of 6 handsets, but your issue is that the EZX290 handset is not one that will function with that system. I have listed below the compatible handset models for that Uniden unit and as you can see the EZX290 is not supported. Sorry to be the bearer of bad news, hopefully you can exchange it for a compatible handset. Good luck!!
EJ
Compatible with select Uniden handsets
Including models DCX150, DCX200, DCX210, DCX290, DCX300 and DWX207 for wide-ranging compatibility.
Apr 10, 2010 | Uniden DECT 6.0 Cordless Telephone...
My idect D1i phone keeps asking me to register
Hi , The phones which keep saying Register mean that they have lost the coding for the Base. To re-code them all you do is
press the menu button,
Press down Button 3 times until Setting comes on the screen,
Press the Button Phone/Ok,
The Display should display HANDSET SETTING,
Press the Button Phone/Ok ,
Then Press the Down button about 4 times until Register Comes on the screen,
Enter Base pin ( 0000 )
The Display will show REGISTER IN PROGRESS,
then immediatly press the Handset Locator Button on the Base and hold it in until you hear a tone.
Thats it , the screen should display Register Done.
Mar 06, 2010 | Lands Phones
GE 5.8 GHz Model No: 25825GE3-A
Try this.. press the prog/mute button. It will ask you to press the page button on the base Press the page button and the handset will say it has to have a name - press the prog.mute button and it will name the handset - not sure if you need to press it 2x for the 2nd handset you have
Nov 08, 2007 | Uniden Cordless Phone
Uniden DECT 6.0 Cordless Phone ID Logo
90 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
