Question about Whirlpool Dryers
The heating element does not work. I replaced the thermostst part #3390291 and cleaned everything and still no heat.
  • jerry earick Mar 24, 2011
    Did you use an ohm meter to check the continuity on all the thermostats and thermal fuses?
    And element
  • 822 Answers
You have 3 stats on these machines.........
dont just change 1.......the 2 on the back must be replaced as a pair
and fitted to the correct wires....................
check for continuity on the element.....................
cheers
Posted on Mar 24, 2011
Managemylife
I don't know much about this but I sugest if it doesn't get better soon you may need to get a new one hope I was at least a little bit of help :}
Sep 13, 2013 | Washing Machines
LGQ2152ES0 does not heat
MAY BE THAT THE HEATING ELEMENT OR THE THERMOSTST IS BAD.
UNPLUG DRIER REMOVE BACK REMOVE ELEMENT AND VISUAL CHECK
COILS. CHECK THERMOSTAT WITH A OHM METER. IF READING IS "0"
PART IS BAD.
Oct 02, 2011 | Dryers
Our dishwasher is about 3 years old. Our only problem is that when it is finished washing everything is clean but very wet. We always have to dry everything. Is there an easy solution to this problem? ...
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Apr 14, 2011 | Bosch Dishwashers
Heating element stays on, even at fluff air no heat setting. Replaced high limit thermostst and thermistor Air flow good
If your heating element is grounded (wire burnt in half and is touching metal) the heat will stay on forever, even in air fluff. This is your most likely problem.
Feb 18, 2011 | Dryers
I cleaned out the dryer vent, heat still not working. i see the thermostat, part#3390291 is corroded, could that cause the heat to not work or could it be the fuse?
Disconnect wires from thermal sensors, Test with a meter.
There should be one or two sensors.
If the vent was built up with lint, you may have blown them.
Always replace all together
Mar 01, 2010 | Washing Machines
MODEL# LER4624BQ1- STOPPED HEATING, CHECKED HEATING ELEMENT-OK/ PART# 3390291 TESTS 120 OHMS / PART# 3396671 TESTS OPEN
i am always suspicious of the timer when an electric dryer loses heat. pull it and check it. or just open it up. look for blackened or melted contacts. good luck
Nov 10, 2009 | Dryers
Kenmore Dryer 60982 Runs but No Heat
you can check them all with an ohms meter but i think it is the thermal fuse at the top of the heater box that is bad-mike
Jun 04, 2009 | Kenmore Dryers
WhirlpoolAWZ7303, the drum spins but their is no heat
heating element is probably open or the over temp thermostst is open. should be easy to fix, just look at the heating element to see if it's broken.
Sep 20, 2008 | Whirlpool Dryers
Replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Jun 18, 2008 | Dryers
Dryers Logo
136 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
