Question about Akai PT46DL10 46" HDTV-Ready Television
I just replace the lamp, now it will not powered on. No lights
I just replaced the lamp. The TV will not power on. I used the original wires like the instructions said. I do notice there is a wire that is not connected to anything at the buttom of the house. Does that mean anything?
  • Nicole_p_d Aug 03, 2008
    I have tried to get a tech out here. The lowest I got i s 150.00 just for the trip. Should the be an unconnected wire?
  • mslopez1263 Aug 16, 2008
    replaced lamp then to power &lamp lights then timer constant nothing happens
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Call repair tech to inspect....careful..
Posted on Aug 03, 2008
  • John Upchurch Aug 03, 2008
    can you send pix of wire? .
    maybe i can help.
My HL-P5063W won't power on. I replaced the Digital Video Board and the lamp. When I power up the the TV, there are several clicks and never a picture. The lamp does not appear to getting any...
Did u ever replace the Ballast board for this tv?No?,that ur tv problems.The Ballast board only job are to ignite the tv projection lamp to make it work.U hearing multiple clicks,lamp never ignite up the Ballast board.
Jul 29, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
No power to tv. When i press the power button i only get a blinking green light then it stops and the blinking red light for lamp flashes and keeps flashing
You need to replace your lamp. Also check power supply and ballast board. Most of the time if you replace the lamp it will come back up. After replacing the lamp you will need original remote to reset lamp hours.
Jan 24, 2011 | Sony KDS55A2000 55" HDTV
I just replaced the lamp on my Samsung HLS5087 and now the TV won't power up. The 3 LEDs are lighting which indicates that the lamp needs to be replaced. I put the old lamp back in to make sure there is...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help to solve the problem,,,,
Dec 06, 2010 | Televison & Video
TV is blank and powers off... lamp light is flashing
Replace lamp in tv as existing lamp is dead/ broken so tv shows lamp light flashing.
Buy Sony original replacement lamp for good picture in tv.
Aug 26, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony, KDFE50A10, Heard a pop and the picture went black. Now have a flashing red light.
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 27, 2010 | Sony Televison & Video
I turned the tv on. The green power/stand by
Question shows its Sony KDF-50WE655 dlp tv that has lamp inside and it seems its time to replace lamp.
Did you replaced lamp in tv recently?
If not, replace it. Lamp replacement procedure would be written in user manual and please buy Sony original lamp for better result.
Thanks.
Mar 04, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
TV stopped working. Power light is blue, temp and
How long has it been sense you changed the lamp? This type of symptom seem as if it could be the lamp needs replaced. Check the manual for the lamp number. Make sure you buy an original hitachi lamp. I assume this is the brand. Hope this is helpful.
Oct 28, 2009 | Hitachi Televison & Video
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
LAMP
Replace the lamp. In rare cases, the lamp power supply or lamp ballast may also need replacing. But, replace the lamp first, and use an original Sony lamp not a cheap aftermarket replacement. If this helps, please be sure to rate the fix! Thanks!
Oct 21, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Akai PT46DL10 46" HDTV-Ready Television Logo
62 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
