Question about JVC GR-D30U Camcorder
Error codes E04 and E06 on my JVC GR-D30U camcorder, what can I do to get my tape out.
    President:
  • 1,932 Answers
Please go to below website.These website gives you clear information how the error caused and what are the error corected
http://www.thedvshow.com/faq-pro/index.php?action=article&cat_id=002&id=310
Thank you
Posted on Mar 25, 2011
My JVC GR-D30U will not close when I put in a new cassette tape. It makes a sound like it wants to but open right back up.
Condensation message appear? Leave it on for sometime eventually it will disappear, if not visit your nearest JVC Service Center.
Jan 28, 2010 | JVC GR-D30U Camcorder
I'm getting an E04 ( error) when I try to record or play
Here is some information regarding the E04 error message from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
This doesn't seem uncommon, and indicates a bad tape is loaded, or unfortunately, that the camcorder requires servicing.
May 22, 2009 | JVC GR-DVM50 Camcorder
Tape stuck in cam corder
take a screw driver and open it up.
Dec 04, 2008 | JVC GR-D30U Camcorder
Jvc camcorder
E01 means Mechanism has not fully loaded up to the stop position
E06 meansTape drive motor is not rotating or stalled.
Thses two faults indicate a tape jam. please remove the cassette and insert a new cassette.
Nov 02, 2008 | JVC GR-AXM17U Camcorder
JVC GR-D30U Digital Video Camera error E04
there was a hole under the tape deck.. u can try to force;y open it right there
Sep 01, 2008 | Cameras
E04 Error
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
Jun 26, 2008 | JVC GR-DVF21 Mini DV Digital Camcorder
E04 Error
i had the same problem with my cam JVC GR-DVL309 and i solve it.
HOW!
Eject the tape, reinsert it BUT while the tape is going down to read, push the door with your hand just a little bit to right side just a few seconds while is reading the tape and close the door, (i had done this 2 or 3 times) this way i have solve the E04 Error, now i can record and play with my cam.
Apr 10, 2008 | JVC GR-DVL300 Mini DV Digital Camcorder
Not ejecting
DRUM FG
In the case there is no DRUM FG input in the
drum rotation mode for 4 seconds or more. This
error is defined as [E04], and the mechanism
mode is shifted to STOP with the pinch roller
set off.
1. The drum cannot be started or drum rotation is stopped
because tape transport load is too high.
1) Tape tension is extremely high.
2) The tape is damaged or soiled with grease, etc.
2. The DRUM FG signal is not received by the syscon
CPU.
1) Disconnection in the middle of the signal line.
2) Failure of the DRUM FG pulse generator (hall element).
3. No drum control voltage is supplied to the MDA.
4. No power is supplied to the DRUM MDA
Dec 23, 2007 | JVC GR-AXM17U Camcorder
E01-E06 Unit in safeguard mode
I had this same problem, and indeed it was from leaving a tape in the camcorder while in storage. All I did was remove the tape and put a new one it. Solved my problem! Thank you!
Dec 03, 2007 | Video Cameras
E04 message
Lisa, E04 is an error code which shows that one or both of the reels has stopped during play or record operation. We find that tapes with liquid contamination can stick to internal parts in the mechanism causing this error. Try another tape, if this does not resolve the problem something is defective in the tape transport. Good Luck to you! Joe Weibel customelectronics.org
Feb 09, 2007 | JVC GR-DVM70 Mini DV Digital Camcorder
JVC GR-D30U Camcorder Logo
124 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
