Question about Microwave Ovens
I am upset that I did an etching project and I accidently got some etching cream on my black granite counter tops. It looks like it is just discolored. But it sticks out like a sore thumb because it is "cloudy" white on my black counter. Is this fixable?
  • 591 Answers
Is it a genuine GRANITE counter top??? I'm surprised an etching solution damaged it... what was the etching solution for, glass, metal??? to be honest I would try to find a spot of the counter top somewhere that is not showing and do some testing before addressing the visible spot, first replicate the issue with the etching solution at the hidden spot (or on some left over peace of counter), than try different cleaning solutions (ask an expert on granite counter tops) if it does not work try a polishing solution or even some acids could bring back the colour...
Posted on Mar 24, 2011
  • Cherie Kirk Apr 23, 2013
    I tried this on a couple of etched spots on my Siletone countertop and it worked - Thanks! We suspect some crazy glue or acetone vapors went through the paper towels that were laid on the counter for protection, and these substances are the only things we have ever seen that affect Silestone.
HELLO,I have a sharp microwave R314FS every thing works just fine but it appears that my light bulb has blown out is it possible that i can change it myself,if so it look like i would have to remove the...
Looks like you just have to take off the outer cover. From the parts diagram I looked at this looks like a counter top unit. If so, unplug the unit and then remove the outer cover and then locate the lamp and replace it. Looks pretty easy to get to.
Oct 04, 2017 | Sharp R-314FS Microwave Oven
I got a faber 4 burner hob for my under constuction apartment. my technician told me that he will cut out a rectangle(of required dimension) from the granite counter top .my worry is that when this piece...
You will be fine. No heat will be generated under the unit. The units are designed to be supported around the rim, usually only about 1/4" is required.
Oct 16, 2010 | Microwave Ovens
Wife smoked up the microwave now it has no power to it
If your M/W is a counter top model and you feel comfortable about removing the outer case the power supply should be fuse protected,open it up and search and check all fuses that you can find for any fuses that may have popped to protect that circuit when your wife accidently smoked whatever it was.Good luck and don't worry about radiation contamination inside the M/W just abide by the warning labels on internal parts!
Nov 22, 2009 | Kenmore Microwave Ovens
I have a GE Profile JVM1790 microwave that needs to be installed. However, it will sit in front of a 3/4" thick granite backsplash that I would rather not drill holes through. Would it be safe to mount...
The front weight hangs from the cabinet above the microwave, the rear weight needs support also. It is intended to be fastened to two studs. If the granite does not go all the way up to the cabinet above, install a wood spacer, the same thickness as the granite, then extend the wall plate, at the corners, with some flat stock aluminum strips, available at most hardware stores. Fasten the aluminum strips to to wall plate with short machine screws. - If the granite goes up to the cabinet bottom, shim out the bottom frame of the cabinet to the face of the granite and use the same aluminum flat stock to extend the wall plate up to the necessary location.
Jul 06, 2009 | Microwave Ovens
I accidentally covered a plate with foil in the microwave. there was Arcing (no fire) and now there is black marks etched where the foil touched the sides. The cavity seems unharmed though, it seems if I...
Sometimes the arcing itself will cause black marks inside the oven. The places where the foil was melted, (touching), likely left small metal deposits, possibly now, impregnated in the surface. It is important to remove these if possible to avoid further arcing. Remove these then test to make sure the oven is functioning properly. If so, continue to use.
Jun 22, 2009 | LG LRM1260SW Microwave Oven
Hi, I have a GE counter top microwave (JES1651). It is just over two years old. It has worked flawlessly until two days age when my wife put in her tea cup to reheat it and shut the door. When the timer...
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can find helpful exploded view diagrams here and order parts for less by entering the part number here.
Aug 19, 2008 | Microwave Ovens
Door is not open
removed.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Many Emerson microwave manuals are available for free download here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | Emerson Black Microwave Oven
Kenmore microwave removal
the top vent exhaust grill has two screws facing down-remove these. remove plastic vent. inside you will see a solid wire tringle assy. turn and pull this release.
warning if you have granite counters or tile, place plenty of material under it to stop the impact if oven gets away from you
Jul 11, 2008 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
100 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
