Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Starting the machine it buzzes and it read F1 what does this mean?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
F1 is a fatal error within the main control. You will need to replace the control. It is accessed by loosening the screws from the rear control panel.
Kelly
Posted on Mar 24, 2011
What foes Error code f1 mean?
Error Code Definition
  • According to Appliance Parts Quick, the error code is defined as a "Primary Control Failure." This means that the small computer installed in the washer has failed to send, receive or communicate with any other part of the washer.
Reset the Code
  • To stop the flashing and beeps on the washer, hold down the "Start" and " Stop" buttons for 60 seconds. If this does not work, unplug the washer for 30 seconds and plug it back it or leave it unplugged since it is inoperable.
Parts
  • The main problem is with the machine control assembly. This whole part needs to be replaced. Depending on your model, prices range from $150 to $260, as of 2011.
Process
  • The installation of the new machine control assembly, requires manual installation and opening the washer itself. If you have never taken apart or repaired a washer, a professional should provide the service and care. Contact Whirlpool support for more information on repairs and warranty.
Read more : http://www.ehow.com/info_7936847_whirlpool-washers-error-code-f1.html
F1 means the central electrical control unit, i.e. the onboard computer, has fatally failed. Unless you have both the skill and tools to test the guts of this computer, you're stuck replacing it. Good news, three screws at the rear to expose the control panel, then unplug one unit; plug in the new one. Just to be on the safe side, color code all the plugs and receptacles. At wholesale, the part is $175.00. CODE 083009 part W10189966 CNTRL-ELEC
Read more: http://forum.appliancepartspros.com/washer-repair/10337-whirlpool-f1-code.html#ixzz3dvEIxJdx
http://forum.appliancepartspros.com http://forum.appliancepartspros.com/washer-repair/10337-whirlpool-f1-code.html#ixzz3dvEIxJdx
Jun 19, 2015 | Kenmore Washing Machines
Fisher Paykel D603 f1 code top drawer only, bottom one has no power and locked
Check out www.ApplianceRepairLesson.com. I hope this is what you needed, and it works for you. Good luck!
Nov 07, 2014 | Dishwashers
Stuck in wash cycle
More than likely the control panel is the problem, about $200 for the part on average. For more help and parts contact this website. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 29, 2017 | KitchenAid Washing Machines
Keeps giving me the F1 signal. Whats the deal?
Fellow, Academy of Sublime Masters of Appliantology
Joined: Sun Oct 7th, 2007 Location: South Carolina USA Posts: 6784 Flavorite Brew: waffle house coffee Status: Offlinespacer.gif F1 usually means a communication or an electrical error.
Unpgug the machine for 1 minute and then power back up. If fault reoccurrs check all connectors.
How long have you had this machine? Has it always been plugged into the same outlet? Is is sharing an outlets with another device?
Read more: Whirlpool Cabrio F1 code - The Laundry Appliance Repair Forum - Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai Appliance Repair Forums http://applianceguru.com/forum2/15527.html#ixzz1BPYo9agm
Get appliance parts at http://parts.fixitnow.com
Jan 18, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I get an error F1 on this washing machine. What does this mean??
f1 means your rotor or main pc.b bord has a fault i would start by having the p.c.b control bord replaced there $ 120 in australia
Jun 21, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
The oven beeps and has a error F1
Hello,F1 means Stuck touch pad.
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled,replace the oven control(also called clock or ERC),touch pad,or both.
Thanks
Jun 01, 2010 | GE JTP20 Electric Single Oven
F1 appears on my machine within a few minutes when the machine is started. I have to stand there for a few minutes & push pause/start again. What does F1 means
I actually had the same problem and read some other blogs and found that this is a control board issue. Whirlpool actually had a recall on these boards and should cover the part and labor to fix. I called them today at 1-800-253-1301 and they are coming out to fix my washer this week. When you call they just need the model number and the serial number. Both can be found just inside the lid on your washer. Good luck!
Dec 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
