Question about SoftMath Algebrator - Algebra Homework Solver (689076614429)
When the new root button is pushed it automatically puts a multiple cation sign before the root and it will not allow me to erase it and if you try it locks the program up. for instance 14*the square root of 27 and it won't let you remove the *
  • SoftMath Master
  • 8,073 Answers
Learn to live with the particularities of the software you are using. If you do not like what it does, use another one more likable to you, or better still create your own.
As to mathematics, the best way to learn it is with pen and pencil, leaving the pain of repetitive tasks to the electronic brain of a calculator.
The question is why do you persist in trying to remove the multiplication symbol after you found out that the software requires it.? It is perfectly correct to have it there if you mean to multiply. Yes!! It is not absolutely necessary, but if the software wants it leave it, and spare yourself some grief.
Posted on Jan 22, 2012
2 Suggested Answers
aranhadesign
  • 54 Answers
SOURCE: Pythagorean theorem to find the width along the horizonal
You should checkout Bitesize revision:
http://www.bbc.co.uk/scotland/education/bitesize/standard/mathsI/pythagoras/pythagoras_rev1.shtml
To summarise - Pythagoras works with right angled triangles only (with one 90 degree angle). One side is always bigger than the other two - it's always the one opposite the 90 degrees.
The long side (hypotenuse) times by itself is the same as if you times-ed the other sides by themselves and added them together.
In your question, you're trying to find the across (which you guess as 12?).
The diagonal (14) is opposite the right angle so it's the biggest (and equal to the other two). We'll call across a, we don't know what it is.
14 * 14 = (7.5 * 7.5) + (a * a)
Rearrange:
(14 * 14) - (7.5 * 7.5) = (a * a)
Type that bit on the left into a calculator (you might need to do it in parts - work out 14 * 14 and write it down...). Once you've got the answer you need to use the square root button to find out what a is.
Posted on May 06, 2009
How do i erase all messages when there is no erase button on my phone
Long press on a message... you'll either have to delete one by one, or the long press will allow you to select multiple messages to delete.
Nov 05, 2017 | Lands Phones
Code de formatage de iphone 3
Erase and restore If you can't remember your passcode, you'll need to erase your device, then use a backup to put your data and settings back on your device.
ht1212-ios8-itunes_store_icon-en.png ht1212-ios8-icloud-en.png Recovery
Mode Use these steps if you've synced your device with iTunes.
Use these steps if you have an iCloud account and have Find My iPhone turned on. Use recovery mode if you can't sync or connect with iTunes and don't have an iCloud account. use recovery mode. (Click the link to be taken to the steps.)
  • iTunes will automatically sync your device and create a backup. If it doesn't, sync the device with iTunes.
  • After the sync is complete, restore your device.ht1212_06-yosemite-itunes_12-iphone-summary-001-en.png
  • When iOS Setup Assistant asks to set up your device, choose "Restore from iTunes backup."
  • Select your device in iTunes and choose the most recent backup.
  • icloud.com/#find.
  • If prompted, sign in with your iCloud Apple ID.
  • Click All Devices at the top of your browser window.
  • Select the device you want to erase.
  • Click "Erase [device]" to erase your device and its passcode.
  • Use the Setup Assistant on your device to restore the most recent backup.
  • restore your device as new or from a backup.
    This will erase the device and its passcode.
    1. Disconnect all cables from your device.
    2. Hold down the Sleep/Wake button, then "slide to power off" to turn off your device.
    3. Press and hold the Home button and plug the device into your computer. If your device doesn't turn on automatically, turn it on. Don't release the Home button.
    4. Continue holding the Home button until you see the Connect to iTunes screen.ht1212-ios8-connect_to_itunes-001-en.png
    5. If iTunes doesn't open automatically, open it. iTunes will alert you that it has detected a device in recovery mode.
    6. Click OK. Then restore the device.
    If your device doesn't go into recovery mode, try steps 1-4 again.
    Oct 25, 2014 | Apple iPhone 3G
    How to reset DTC GT5S
    try this one About SRSRoot SRS-Root is an easy to use solution for rooting your android device, the software contains multiple exploits to gain root access on your device.
  • SRSRoot Supports Android versions 1.5, 2.1, 2.2, 2.3, 3.1, 3.2, 4.0, 4.1, 4.2
  • We can Root latest models like Samsung Galaxy S2 / S3, Note / Note2 etc
  • We have an Option to remove root from your device by one-click.
  • Powered by SRS Server *Safe Rooting without flashing your device*
  • Why Root
    Let's start with why you would want to root your Android smartphone. Sometimes apps require special permission that the Android OS, which is based on Linux doesn't allow. These could be simple as taking a screenshot to higher level permissions to the core Android files. Rooting makes your phone faster, increases battery life, allows it to run more apps, custom software and ROMs which allow complete control over every aspect of your device by allowing superuser and admin level permission. Removing carrier bloatware is a particularly enticing application.
    However, rooting isn't for everyone. If you don't know what a command prompt is or you have trouble handling .zip files, please don't root. The risk of bricking your expensive device to get speed gains and improvements only Android enthusiasts can appreciate is not worth it. Lastly, rooting can void your phone's warranty so please make sure you follow instructions to the letter. Also, back up your data before you root android!
    http://www.srsroot.com/ download <<<<<
    May 25, 2014 | Samsung Galaxy Y Gt-s5360 - White unlocked...
    I have tried to sign in but it keeps getting kicked back and won't allow me on the site. I have recieved the email with login verification info and still can't sign in. What do I do?
    Sometimes if you are logging in with the same id on multiple devices or on the same browser with two different accounts on the same site it will log the other one out automatically.
    Aug 13, 2013 | datehookup.com
    My chamberlaain security + garage door openers
    well your main PC board inside of the opener head could have lost the frequency, or the unit memory has been erased, try to reprogram the remotes by going to the back of the opener head and locating the "learn" button which is either red, green, or purple in color. press the learn button then ONE button on ONE remote, pressing multiple buttons or pressing both remote buttons at the same time will not allow them to be programed successfully. after programing test by pushing the same button you just programmed, repeat for other remotes, and if this process did not work than you will need to contact chamberlain
    Jan 17, 2010 | Chamberlain 950CB Remote Control
    Everytime i turn on my pc the mail is my home page. I never sign out and the button is pushed to remember me, yet i have to sign in everytime.
    Make sure your computer's not deleting the browser history and catch doing so erases the password from the computer's memory therefore you'd have to RE type it instead of the computer keeping you login or automatically logging you in
    My solution to this problem would be to manually clear the catch/cookies and browser history so the computer doesn't keep trying to do that then RE type your password and username tell the computer to remember you then close the browser and restart your computer then try logging in again the computer should automatically log you in or have kept you login hope this helps
    Aug 04, 2009 | Yahoo Mail
    I have a dictaphone Smart 7120 and I can't get it
    I've never encountered that problem, but the manual says: Make sure remote Transcribe indicator is extinguished. Move the Transcribe switch to Local position. Locate letter to erase with either [Prev. Ltr] or [Next Ltr]. Simultaneously press [Currnet Ltr] and [Erase] buttons to erase letter appearing in Item Status display. A tone plays and Erase LED lights briefly. Letter is automatically deleted.
    To erase all Transcribed Letters: Make sure "In Use" Transcribe indicator is extinguished. Move Transcribe switch to Local position. Simultaneously press the [Finished Ltrs] and [Erase] buttons. Tone plays and Erase LED lights briefly. Good luck!
    Do you know how to determine the total minutes on the machine? I have 2 that I want to sell, one of which is on eBay. Thanks.
    Jul 09, 2009 | Dictaphone Office Equipment & Supplies
    Door key pad, won't unlock door
    1. Enter the permanent factory remote keyless entry (RKE) keypad code.
    1. Press the 1/2 button within 5 seconds to activate the programming mode associated with the memory position 1 settings. Holding the 1/2 button for more than 2 seconds after activation erases the stored personal code.
    1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 1 settings. Entering any new personal code automatically erases the old personal code.
    1. Press the 3/4 button within 5 seconds to activate the programming mode associated with the memory position 2 settings. Holding the 3/4 button for more than 2 seconds after activation erases the stored personal code.
    1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 2 settings. Entering any new personal code automatically erases the old personal code.
    1. Press the 5/6, 7/8, 9/0, 7/8 and 9/0 button within 5 seconds to activate the programming mode or allow the system to timeout.
    1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed. Entering any new personal code automatically erases the old personal code.
    Jan 23, 2009 | 2005 Ford Freestyle
    HOW TO FIND CUBE ROOT
    There is a way to do it. I believe you go into "complex" or "math" buttons. These buttons are yellow on the calculator. Therefore, to access them you must hit "2nd" then the button.
    Better yet, you can also get around this dilemma another way. You can enter "the cubed root of x" by raising x to 1/3.
    For example the cubed root of x = x^(1/3). It is best to place parentheses around 1/3 so the calculator knows exactly what you mean.
    Another example, the "cubed root of (x + 1)" can be entered by:
    (x+1)^(1/3) Note the parenteses around both (x+1) and (1/3). This applies if the radical cover both "x" and "1".
    Hope this helps.
    Oct 03, 2007 | Texas Instruments TI-86 Calculator
    Computers & Internet Logo
    55 people viewed this question
    Top SoftMath Computers & Internet Experts
    k24674
    ali_zulfikar
    ali_zulfikar
    Starnley Johnwells
    Starnley Johnwells
    Are you a SoftMath Computer and Internet Expert? Answer questions, earn points and help others
