Question about Toshiba Computers & Internet
Having trouble going wireless as soon as i unplug i lose the web
    Master:
  • 325 Answers
Hi There,
With the limited information I don't think a complete diagnosis and resolution would be possible as there are so many factors involved however I will give you some advice to try.
Because the wireless and cabled connections operate as completely independent entities you shouldn't expect a continuation of service from one to the other, in fact operating in this way causes greater issues than not connecting by cable at all
assuming once connected by cable you have a good internet connection the the problem lies completely with your wireless connectivity between you router and your laptop.
what you should do to diagnose the fail point
1. connect by your cable as you have been doing press start press run type CMD into the box pres [enter] to bring you a DOS screen (black white writing)
in this screen type IPCONFIG press [enter]
the writing that passes by are your IP settings one will be called Ethernet and under which it will have an IP address for your router called DEFAULT GATEWAY make a note of this number. it will probably (though not exclusively) something like 192.168.x.x depends on the make of the router
type IPCONFIG /RELEASE disconnect your cable and reboot your laptop
if your laptop has a switch or button to turn on wireless turn it on once widows has loaded
in your systray (the row on little icons near your clock) you should have something that represents your wireless connectivity, either a strength meter or a computer screen with a plug at the top left corner, click on this and you should see the list of wireless networks available in your area in theory the one closest the top and strongest signal should be your router
if you do not have this then the drivers which make windows recognize your wireless adapter is missing, connect again via wired, search out your laptop, download and install drivers.
if its there click on it and click connect. you should then be prompted for your password (either set by you or written on the bottom of the router "SSID", "WEP" or "WPK" the prompt will tell you which one (of the security measures) and the router will have the password written next to this title.
wait a minute and it should connect and work
if you do not know this and have not set it
connect again using cable after a reboot
launch internet explorer
in the URL bar where it currently says" www.fixya.com/blah blah" type in HTTP://and the number with dots you wrote down earlier so http://192.168.2.1 or whatever it is (probably ending in .1)
this will take you to your routers config screen again it may require a DIFFERENT password if you do not know this check your routers manual, or Google search default passwords for your model of router.
select wireless, select security options, select WPA protection and give it a password that you can easily remember, any device you wish to connect in the future will prompt you for this.
find your rooters save option and also reboot the router, when its back up and running reboot your laptop and repeat the process from switching on your laptop above.
anyway.
hope this helps, took me a while to write it so if it did please give me a good review on www.2pages.freeindex.co.uk
Posted on Mar 24, 2011
    Scholar:
  • 115 Answers
Update the wireless driver. I assume you have a realtek driver for the wireless. Go to start;type device manager on the search box;look for the name of the driver. Usual format is RTL 81**CE. Then, go to www.realtek.com, search for the for the updated driver and download it. You must restart the NB, once installed, for the changes to take effect.
Hope this helps.
    Problem Solver:
  • 13 Answers
If you are using WIndows it is best that you disable the wire adapter. Then restart you laptop see if it connects. Do you have any other compters on this wireless? Are you installing a new router?
WEB ALERT "you have
Maybe you've been logging out or try to check your internet cable is been unplug. Or else the site having a system trouble so far.
May 04, 2011 | Computers & Internet
Signal problem
Step 1: Connect Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer (You can use any Web browser )
Step 3:On the left, under wireless click on channel and SSID (leave the password Blank and click submit )
Step 4: Change the Wireless Channel to 6 ( If its already 6 change it to 11)
Step 5: Click apply changes
Step 6: unplug the Router
Step 7: Restart the Computer
Step 8: Plug the power Cable back to the Belkin
Step 9: Connect to your wireless network
Jul 31, 2010 | Belkin N1 Vision Wireless Router
I have a Model F6D4230-4 V3 Belkin wireless router. I have done the installation but as soon as I unplug the ethernet cable from the computer I lose the internet. The wireless light does not come on on the...
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
May 28, 2010 | Belkin (F5D8231-4) Wireless Router...
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
Losing wireless connection
Your phone frequency must be the same with frequency of your wireless router. To avoid this you access the web GUI of your router page..http://192.168.1.1..( in most cases)...and go to the wireless settings...look for the frequency tab and change the settings ( you can try 1-10). DO trial and error...
Jul 11, 2009 | Computers & Internet
Lose router signal everytime i restart my laptop
This seems to be an issue with the router itself. As the laptop is able to connect to other networks easily, the trouble seems to be with the router.
Try updating the firmware on the router. Also, change the wireless channel on the router and check if that helps. If the issue persists then I believe you will have to get the router replaced.
Jun 21, 2009 | Zyxel (91-004-361002) Wireless Router
DI-524 Router
1. Log into the web-based configuration by opening up a web browser and typing in the IP address of the router (192.168.0.1).
2. The default username is admin (all lower case) and the password is blank (nothing). Click OK.
3. Click on the Home tab and then click Wireless on the left hand side.
4. Select WPA-PSK using the radio buttons.
5. Choose a key (password). The key is an alpha-numeric password between 8 and 63 characters long. The password can include symbols (!?*&_) and spaces. Make sure you enter this key exactly the same on all other wireless clients.
6. Click on the Apply button then click on the Continue button to save your settings.
Note: If you are configuring your router from a wireless adapter, you will lose connectivity as soon as you click Apply. You must enable WPA-PSK on your adapter and enter the same exact passphrase as you entered on your router.
Jun 10, 2008 | D-Link AirPlus DI-524 Wireless Router
Enable WPA-PSK
Step 1 Log into the web-based configuration by opening up a web browser and typing in the IP address of the router (192.168.0.1). Step 2 The default username is admin (all lower case) and the password is blank (nothing). Click OK. Step 3 Click on the Home tab and then click Wireless on the left hand side. Step 4 Select WPA-PSK using the radio buttons. Step 5 Enter a key (passphrase). The key is an alpha-numeric password between 8 and 63 characters long. The password can include symbols (!?*&_) and spaces. Make sure you enter this key exactly the same on all other wireless clients. Step 6 Click on the Apply button then click on the Continue button to save your settings. Note: If you are configuring your router from a wireless adapter, you will lose connectivity as soon as you click Apply. You must enable WPA-PSK on your adapter and enter the same exact passphrase as you entered on your router.
Feb 16, 2006 | D-Link Air Xpert DI-774 Wireless Router
Enable WPA-PSK
Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
174 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
