Question about Amana Refrigerators
I have a Amana ssd21sl, the evaporator coil freezes up, The fan motor above does not come on, but have 115v to it, Is fan motor bad.
  • 132 Answers
You really need to measure the Ohms resistance for the motor.
OL means the motor is dead
0.000 means the motor is short circuited and is dead
160 to 300 ohms the motor is good
Posted on Mar 25, 2011
Amana Ptac 2012 R410A runs compressor 5-10 min then will not run only fan. Freon level is good. Reset and compressor will run again then only fan again..cleaned
You said in another post that the error was c7. That means evaporator freeze. Too cold. That could be lack of air flow, bad sensor, ice on the coils.
Sep 11, 2016 | Amana Heating & Cooling
Freezer not freezing
Possible failed evaporator fan motor (cooling coil fan) or failure in the defrost system resulting in the cooling coil being blocked with ice.
Jul 25, 2014 | Amana Refrigerators
Lower shelves of the refrigerator freeze foods
Can you hear the inside fan motor? If not this isn't the problem but its a symptom of a bad defrost terminator. It is located on the freezer side attached to the evaporator coil. Amana shuts off the fan in the defrost cycle, when this part fails the fan will not come back on after the defrost cycle. Is relatively easy to replace.
Oct 24, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Why does my kenmore cool on he bottom on both
replace evaporator fan motor.it is the fan above the evaporator coil's.
Nov 18, 2009 | Dishwashers
Ammana Fridge-Evaporator Fan not working
Replace the defrost bimetal . On older Amanas' , the coil has to be cold , before the evaporator fan starts ( bimetal closes ) . This way , heat from the defrost cycle , will not be blown into the refrig section .
Oct 07, 2009 | Amana 22.6 cu. ft. Side-By-Side...
My Amana Side-by_Side SXD26VL is not cooling. The
clean cond coil at back of unit.
check amp draw on the compressor wires.
Sep 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Fridge problem
Hi. The most common failure for this make refrigerator is a bad evaporator fan motor. You should feel air coming out of the diffuser in your freezer. If not, either the fan motor is bad or you have alot of frost build up on the evaporator. You would see alot of frost on the back wall of the freezer where the evaporator coil is located. If this is the case, most likely the defrost bimetal thermostat. But if no frost, the evaporator fan motor is most common and likely to be your problem. Visit me on Ebay username: themackshack. Good luck! Mack
Mar 23, 2008 | Amana ABB1921DE Bottom Freezer...
Amana refrigarator
Hi. The most common failure for this make refrigerator is a bad evaporator fan motor. You should feel air coming out of the diffuser in your freezer. If not, either the fan motor is bad or you have alot of frost build up on the evaporator. You would see alot of frost on the back wall of the freezer where the evaporator coil is located. If this is the case, most likely the defrost bimetal thermostat. But if no frost, the evaporator fan motor is most common and likely to be your problem. Also check and make sure your compressor is running. Compressor failure is common on this make refrigerator. Visit me on Ebay username: themackshack. Good luck! Mack
Dec 15, 2007 | Amana ABB1921DE Bottom Freezer...
Refrigerators Logo
81 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
