Question about Activision Fighter Squadron for Windows
Fighter Squadron the screamin' Demons over Europe will not start any instalation and says it is uncompatable with my windows 7 64 bit laptop. Any suggestions? This game is windows 95/98
3 Suggested Answers
nikeananth
  • 267 Answers
SOURCE: copy of instuctions for fighter squadron
Flight and Weapons
Joystick
Button 1 fire main weapon Button 2 fire guns Keyboard
E engine on/off Ctrl P props feather on/off P toggle autopilot + increase throttle - decrease throttle F flaps down Shift F flaps up G landing gear up/down B toggle wheel brakes Ctrl E eject T target Space fire guns 1 select main weapon M.G. 2 select main weapon cannon 3 select main weapon all guns 4 select rockets 5 select bombs 6 select bomb bays A arm master weapon Enter weapons release D toggle bomb bay door Wingman Commands
J as you were K form up on my wing L attack my target ; disengage ' return to base Rudder/Trim
< rudder left > rudder right / rudder center Left Arrow trim left Right Arrow trim right Up Arrow trim up Down Arrow trim down Ctrl Left Arrow rudder trim left Ctrl Right Arrow rudder trim right View Selections
F1 set designation padlock F2 external F3 chase F4 weapon F5 next vehicle Shift F5 previous vehicle F6 command vehicle Shift F6 A.I.-controlled vehicle F7 next crew Shift F7 previous crew F8 tower view F9 quick view 1 F10 quick view 2 F11 quick view 3 F12 quick view 4 M in mission map Shift M in mission map close-up Overlays
H toggle HUD Shift H HUD mode Ctrl H HUD color Shift I HUD intensity up Ctrl I HUD intensity down Alt M target state R target map range Alt W weapons state Alt V vehicle I.D. state Alt I I.D. state Inside Plane Views
Numpad 8 foward Numpad 2 aft(behind) Numpad 4 left Numpad 6 right Numpad 5 up Numpad 0 down Shift Numpad 8 pan up(digital) Shift Numpad 2 pan down(digital) Shift Numpad 4 pan left(digital) Shift Numpad 6 pan right(digital) Ctrl Numpad 7 shift up Ctrl Numpad 1 shift down Ctrl Numpad 4 shift left Ctrl Numpad 6 shift right Ctrl Numpad 8 shift aft Ctrl Numpad 2 shift fore [ zoom in ] zoom out Shift Numpad 5 center your view System
Z screenshot Esc end mission Shift Esc pause game Ctrl Esc end program Ctrl - reduce window Ctrl Equal Sign enlarge window Shift - reduce gamma Shift + increase gamma Network
~ radio chat
Posted on Sep 22, 2009
SOURCE: I have the original airport
Hi,I uploaded the Airport Tycoon 3 PC Game ...
Check this Link
Download the game..extract it ..enjoy!
I tested the game on my Windows 7 64bit based system and it worked .
Good Luck!
Posted on Jan 21, 2011
I have sony vaio laptop window 7,64 bit with 500 gb harddrive having only one partition = c i want to make 4 partitions how can i make it without losing my recovery data default from manufacturer
Type Computer Management into the search box above the start icon. Select Disc Management, select the drive name you wish to adjust and right click on it. Select Shrink Size and select whatever size you require. When complete format the new partition.
Dec 24, 2014 | Sony VAIO Computers & Internet
Logithec attack3 devices not detected
Disconnect the divice uninstall the driver restart the laptop and then reinstall the driver again restart the laptop then connect the device it works.
Apr 03, 2014 | Video Game Consoles & Games
Usb port on presario F500 quit working, they are seen by device manager but will not reconize a flashdrive when incerted, a mouse or any thing else. Using win 7,64 bit t3500 cpu.
This should be pretty easy to fix. I have seen this many times before. Here's what to do:
Go into device manager and expand 'universal serial bus controllers'.
Start at the very bottom, and start deleting the usb root hubs one by one. You will lose your touchpad control at some point, as the touchpad is actually a usb device. One of thwo things will happen.
1. The usb hubs will automatically be re-detected and re-installed.
2. You will just lose touchpad control after deleting one of the root hubs. If this happens, then shut down using the power button, and restart. Th usb hubs will be reinstalled once you log back into windows. Please let me know if this doesn't fix it.
Joe
Apr 07, 2012 | Compaq Computers & Internet
Under Windows XP, Directx 9, system asks for cd to be inserted, though it is already there. Mike. (Central Victoria, Australia)
Did you install the game from your first cd/dvd drive? If you have more than one that is. Some of the older games put the path of the cd as an actual location, so if you installed this from your G: drive cd/dvd and then added another bit of hardware like a harddrive, then the drive letters might have got changed. You could look at the games .ini file and see if there is any reference to cd paths and change it to reflect where you have it inserted. Just make sure you make a backup of the file before you make any changes just in case something goes wrong.
Star Wars Rogue Squadron had the same limitation where it would keep asking for the disc, so I had to just keep trying my other drives till I hit the right one.
Hope that helps.
Cheers from NZ, neighbour :)
May 24, 2011 | Activision Fighter Squadron for Windows
I am trying to install an expansion to Hidden and Dangerous 2, it is called Sabre squadron. I have had this installed on this system before, and I never had this problem. When I try to install it; It...
Possibly the uninstall has not been complete last time you uninstalled Hidden & Dangerous 2 Sabre Squadron.
Try to run uninstall again and then install. Also delete everything you can inside C:\WINDOWS\Temp and use EasyCleaner...
http://personal.inet.fi/business/toniarts/ecleane.htm
...to clean the registry.
If still fails, try uninstall and install in safe mode.
As a final solution. Just do a clean reinstall for whole Windows. For such a great game it is worth it.
May 04, 2010 | Take 2 Interactive Hidden And Dangerous :...
I am trying to re-install Jane's Attack squadron onto my PC from the original disk because I had some issues on my computer. It is failing after about 68% through the CD. Is there anything I can do?
U can you MAgicISO to app wich can recover the cd to an ISO file ,and Mount the Iso in a virtuel Drive and Install it,Hope it works;)
Download Here MagicISO + MAgicDisc (to mount the ISO file)
Feb 07, 2010 | Xicat Interactive Jane's Attack Squadron...
I need install canon LBP1210 printer driver on the windows7 x64bit sytem
1. Disable the driver signing for Windows 7.
http://www.killertechtips.com/2009/05/05/disable-driver-signing-windows-7/
2. Install the windows 7 32 bit driver from the canon website.
http://software.canon-europe.com/software/0037177.asp
Jan 21, 2010 | Computers & Internet
Copy of instuctions for fighter squadron
Flight and Weapons
Joystick
~ radio chat
Sep 22, 2009 | Activision Fighter Squadron for Windows
Sir I was using F22 Air Dominance Fighter game in my pc from a long time, but when i am using the same game on my laptop its creating problem. My pic has windowns Me, & my laptop is Windowx XP Media Center...
in this dominance fighter in your pc is installed well but at the same time using in laptop is not working because the installed program is not proper in your laptop may be some support of files may be missed in the installation
Apr 17, 2009 | Graphic Simulations F-22 Air Dominance...
Activision Fighter Squadron for Windows Logo
216 people viewed this question
Top Activision Video Game Consoles & Games Experts
Zhenya Ogorodnikov
James Wishart
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
