Question about Apple Iphone 2g 3g 3gs 8gb 16gb S
My iPhone 2g is heating up..and if i charge it its so hot and i will take me 1 day to fully charged it and if not fully charged i can used it up to 20-30 munites if fully charged 2-3 hours and the hot portion is on the top of the apple logo and its getting hot and if starts getting hot the full body gets hot..even though i close all the apps the fetch new data the bluetooth wifi all even i left it sleep if not fully charged it eats battery too much..wat will i do..
  • 31 Answers
You either have a bad battery or you have a bad charger. If the phone heats up when you plug it into the USB port on a computer then you know that the battery is bad and needs to be replaced. If the phone does not heat up and you get a normal charge from the USB connection then you know that the battery is good and the charger is bad.
Posted on Mar 24, 2011
Had this tablet for one day, its showing 50% .. battery, when should I recharge..
There's no harm in keeping it on charge all the time. Unlike older rechargeables, newer Li-ion batteries don't need to be broken in by running them down and then recharging.
Feb 12, 2015 | Tablets & eReaders
My iphone 2g wont charge at all
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 05, 2012 | Apple iPhone Smartphone
Iphone 3g proper charging
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the fully charged state for two hours. (You may use your iPhone during this time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone:
#1 - Charge your iPhone throughout the day when available. Charge EVERY night, regardless of charge level. This will keep your battery active, which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect the iPhone from the charger after it's done charging. Once fully charged, the iPhone will run strictly off of AC power and will not damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the battery, in one cycle. This calibrates your battery indicator. If you fail to do this, your indicator will become inaccurate. Calibrating your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily remove the case). Charging your iPhone inside your case will make the iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a cool environment has a tremendous impact on your battery's lifespan. The colder the location you use to charge, the more charging cycles you can complete without your battery deteriorating. Avoid charging in direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly rated will have a huge impact on your battery's lifespan. Make sure your car charger has the same rating as the official Apple charger.
The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A
Thanks!
Apr 15, 2011 | Cell Phones
My iPhone 2g is heating up and losing battery even though i am not using it its hotter when i am charging it but if not is not that hot but it lose battery so pass if i fully charger it it will last for...
It's possible that there is a short in the battery cell and/or that you got water in the divice. My experience with Apple is that their customers are #1. Give them a call and they should at least get you to a point of if they will fix it for free or how much it will cost you.
Mar 24, 2011 | Apple Iphone 2g 3g 3gs 8gb 16gb S
IPhone charging problem
If you are using a genuine apple usb lead, replace the charge port in the phone.
Sep 26, 2017 | Apple iPhone (16 GB) Smartphone
Iphone won't charge past 70%
the problems is the the phone, replace the battery, with lithium battery charge better when the battery is almost completely dead. try not to over charged the battery.
Jul 25, 2009 | Apple iPhone Smartphone
My iphone 2g wont charge & wont turn on
Try using another cable or charger. A damaged charger or cable could cause it not to charge.
Otherwise, contact apple or apple store for repair.
May 06, 2009 | Apple iPhone Smartphone
AFTER A FULL NITES CHARGE, AND USING MY IPHONE FOR ABOUT8 MINUTES OF CALL IN A DAY, MY IPHONE BATTERY IS DOWN TO ABOUT 1/2 CHARGE, AND SOON IT WILL NOT LET ME CALL OR RECEIVE ANYMORE. WOULD APPRECIATE...
first get a new battery and make sure you charge it fully and drain it completly 4 to 5 times befor you can charge it at any battery level.
Jul 29, 2008 | Cell Phones
Open Questions:
I live in Montreal, Canada. I received an old iphone to use basically for music. There was no SIM card. I wanted to erase songs so I chose to reset by deleting all content and settings. Now I cannot a ActivationInfo: ActivationInfoComplete = false ActivationInfo: ActivationInfoXML = 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 ActivationInfo: FairPlayCertChain = MIICxDCCAi2gAwIBAgINMzOvBwQCrwACrwAABzANBgkqhkiG9w0BAQUFADB7MQswCQYDVQQGEwJVUzETMBEGA1UEChMKQXBwbGUgSW5jLjEmMCQGA1UECxMdQXBwbGUgQ2VydGlmaWNhdGlvbiBBdXRob3JpdHkxLzAtBgNVBAMTJkFwcGxlIEZhaXJQbGF5IENlcnRpZmljYXRpb24gQXV0aG9yaXR5MB4XDTA3MDQwMjE1MTcyOVoXDTEyMDMzMTE1MTcyOVowZzELMAkGA1UEBhMCVVMxEzARBgNVBAoTCkFwcGxlIEluYy4xFzAVBgNVBAsTDkFwcGxlIEZhaXJQbGF5MSowKAYDVQQDEyFpUGhvbmUuMzMzM0FGMDcwNDAyQUYwMDAyQUYwMDAwMDcwgZ8wDQYJKoZIhvcNAQEBBQADgY0AMIGJAoGBAN5I77j+YtnyYHY13oHbvensf2GTqZJJgDxY6eZSPCsrbFWnBZZjaGDwDvAneVlmW4ar3ayEXTLdRJapmOu534I2G8tnt0dehMci4DyoIImeh++g9EdrtXZ+9rM9kk+VtHqi/Il83m4vOOUKuBFjOMM76QnB/xE6570zJ8QNeVNdAgMBAAGjYDBeMA4GA1UdDwEB/wQEAwIDuDAMBgNVHRMBAf8EAjAAMB0GA1UdDgQWBBR6U0BQMeWj7Zi12PKN3wtbvbxZ5DAfBgNVHSMEGDAWgBT6DdQRkRvmsk4eBkmUEd1jYgdZZDANBgkqhkiG9w0BAQUFAAOBgQB7jW47rw9CAtopKrrOZdtw1FT0WR19tYjxFN4+14uXg3BHZKeXggRDU9xMsJafAMqq4zlNRNJ8ad7bn8EozR0gJniBVzA96LWVyR7OvxIq1DW+8rz8t80ggh9uNrVX/duRNgg3m/BkMP9K87d3SRPQHdNgfYvggmBnUH0QSyQbhzCCA3EwggJZoAMCAQICAREwDQYJKoZIhvcNAQEFBQAwYjELMAkGA1UEBhMCVVMxEzARBgNVBAoTCkFwcGxlIEluYy4xJjAkBgNVBAsTHUFwcGxlIENlcnRpZmljYXRpb24gQXV0aG9yaXR5MRYwFAYDVQQDEw1BcHBsZSBSb290IENBMB4XDTA3MDIxNDE5MjA0MVoXDTEyMDIxNDE5MjA0MVowezELMAkGA1UEBhMCVVMxEzARBgNVBAoTCkFwcGxlIEluYy4xJjAkBgNVBAsTHUFwcGxlIENlcnRpZmljYXRpb24gQXV0aG9yaXR5MS8wLQYDVQQDEyZBcHBsZSBGYWlyUGxheSBDZXJ0aWZpY2F0aW9uIEF1dGhvcml0eTCBnzANBgkqhkiG9w0BAQEFAAOBjQAwgYkCgYEAsmc8XSrnj/J3z+8xvNEE/eqf0IYpkAqj/2RK72n0CrnvxMRjyjotIT1SjCOJKarbF9zLKMRpzXIkwhDB9HgdMRbF5uoZHSozvoCr3BFIBiofDmGBzXmaXRL0hJDIfPZ4m1L4+vGIbhBy+F3LiOy2VRSXpE0LwU8nZ5mmpLPX2q0CAwEAAaOBnDCBmTAOBgNVHQ8BAf8EBAMCAYYwDwYDVR0TAQH/BAUwAwEB/zAdBgNVHQ4EFgQU+g3UEZEb5rJOHgZJlBHdY2IHWWQwHwYDVR0jBBgwFoAUK9BpR5R2Cf70a40uQKb3R01/CF4wNgYDVR0fBC8wLTAroCmgJ4YlaHR0cDovL3d3dy5hcHBsZS5jb20vYXBwbGVjYS9yb290LmNybDANBgkqhkiG9w0BAQUFAAOCAQEAwKBz+B3qHNHNxYZ1pLvrQMVqLQz+W/xuwVvXSH1AqWEtSzdwOO8GkUuvEcIfle6IM29fcur21Xa1V1hx8D4Qw9Uuuy+mOnPCMmUKVgQWGZhNC3ht0KN0ZJhU9KfXHaL/KsN5ALKZ5+e71Qai60kzaWdBAZmtaLDTevSV4P0kiCoQ56No/617+tm68aV/ypOizgM3A2aFkwUbMfZ1gpMv0/DaOTc9X/66zZpwwAaLIu6pzgRuJGk7FlKlwPLArkNwhLshkUPLu7fqW7qT4Ld3ie9NVgQzXc5cWTGn1ztFVhHNrsubDqDP3JOoysVYeAAF2Zmr1l6H6pJzNFSjkxikgzCCBLswggOjoAMCAQICAQIwDQYJKoZIhvcNAQEFBQAwYjELMAkGA1UEBhMCVVMxEzARBgNVBAoTCkFwcGxlIEluYy4xJjAkBgNVBAsTHUFwcGxlIENlcnRpZmljYXRpb24gQXV0aG9yaXR5MRYwFAYDVQQDEw1BcHBsZSBSb290IENBMB4XDTA2MDQyNTIxNDAzNloXDTM1MDIwOTIxNDAzNlowYjELMAkGA1UEBhMCVVMxEzARBgNVBAoTCkFwcGxlIEluYy4xJjAkBgNVBAsTHUFwcGxlIENlcnRpZmljYXRpb24gQXV0aG9yaXR5MRYwFAYDVQQDEw1BcHBsZSBSb290IENBMIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEA5JGpCR+R2x5HUOsF7V55hC3rNqJXTFXsixmJ3vlLbPUHqyIwAugYPvhQCdN/QaiY+dHKZpwkaxHQo7vkGyrDH5WeegykR4tb1BY3M8vED03OFGnRyRly9V0O1X9fm/IlA7pVj01dDfFkNSMVSxVZHbOU9/acns9QusFYUGePCLQg98usLCBvcLY/ATCMt0PPD5098ytJKBrI/s61uQ7ZXhzWyz21Oq30Dw4AkguxIRYudNU8DdtiFqujcZJHU1XBry9Bs/j743DN5qNMRX4fTGtQlkGJxHRiCxCDQYczioGxMFjsWgQyjGizjx3eZXP/Z15lvEnYdp8zFGWhd5TJLQIDAQABo4IBejCCAXYwDgYDVR0PAQH/BAQDAgEGMA8GA1UdEwEB/wQFMAMBAf8wHQYDVR0OBBYEFCvQaUeUdgn+9GuNLkCm90dNfwheMB8GA1UdIwQYMBaAFCvQaUeUdgn+9GuNLkCm90dNfwheMIIBEQYDVR0gBIIBCDCCAQQwggEABgkqhkiG92NkBQEwgfIwKgYIKwYBBQUHAgEWHmh0dHBzOi8vd3d3LmFwcGxlLmNvbS9hcHBsZWNhLzCBwwYIKwYBBQUHAgIwgbYagbNSZWxpYW5jZSBvbiB0aGlzIGNlcnRpZmljYXRlIGJ5IGFueSBwYXJ0eSBhc3N1bWVzIGFjY2VwdGFuY2Ugb2YgdGhlIHRoZW4gYXBwbGljYWJsZSBzdGFuZGFyZCB0ZXJtcyBhbmQgY29uZGl0aW9ucyBvZiB1c2UsIGNlcnRpZmljYXRlIHBvbGljeSBhbmQgY2VydGlmaWNhdGlvbiBwcmFjdGljZSBzdGF0ZW1lbnRzLjANBgkqhkiG9w0BAQUFAAOCAQEAXDaZTC14t+2Mm9zzd5vydtJ3ME/BH4WDhRuZPUc38qmbQI4s1LGQEti+9HOb7tJkD8t5TzTYoj75eP9ryAfsfTmDi1Mg0zjEsb+aTwpr/yv8WacFCXwXQFYRHnTTt4sjO0ej1W8k4uvRt3DfD0XhJ8rxbXjt57UXF6jcfiI1yiXV2Q/Wa9SiJCMR96Gsj3OBYMYbWwkvkrL4REjwYDieFfU9JmcgijNq9w2Cz97roy/5U2pbZMBjM3f3OgcsVuvaDyEO2rpzGU+12TZ/wYdV2aeZuTJC+9jVcZ5+oVK3G72TQiQSKscPHbZNnF5jyEuAF1CqitXa5PzQCQc3sHV1IQ== ActivationInfo: FairPlaySignature = Yps0DSJc5zSVv6piCeS5JEKG91vipQIyTFZ1iQDFeZ19WqaeqWxjmIze9aD2Q7EV//2gf9nB65XTY3Vzl24SKEZ1jikO+YXLQ68UfPFEFvBGh8f66tzUJjuUg8aEYaHyPZY154vz0Y9e1iZMJBlZAnlWWLg477mj6ZP+i7PUOko= ActivationPublicKey: LS0tLS1CRUdJTiBSU0EgUFVCTElDIEtFWS0tLS0tCk1JR0pBb0dCQUwxbFRMTU1CQzFQakphMkhmUmhid0RIRGxHYmdtMWRJeHAxSWxzSzlLNDBuYUcrUENzRXVHb3cKTG50SXJPZEZXaE5PWG1yTmhaKzJBc3NUUlBXQk8xMCtSeVd3YVBkZ2txUEhUSjUyMTJma1Njc29WL2hFeU1BZgpTc1YyUWZnditiR3V2bXhRR1lrc1dJMFBCSnhFL1UyeEhhZGhzWFA4bnpHY1pCMVNrSjdyQWdNQkFBRT0KLS0tLS1FTkQgUlNBIFBVQkxJQyBLRVktLS0tLQo= ActivationState: Unactivated ActiveWirelessTechnology: kCTWirelessTechnologyUnknown AirplaneMode: false ApNonce: 203d8ff9e72b588bb690f5c7116c3647fe77932c BasebandBootloaderVersion: 6.4_M3S2 BasebandMasterKeyHash: E93B43F3EF6DAED516A2D4B9BAD5494DC81E92D3 BasebandStatus: SIMNotInserted BasebandThumbprint: 9FE3C110C2BAAA793FA9E0E5D0E3E8A651D6E1FD BasebandVersion: 05.16.07 BluetoothAddress: 04:0c:ce:51:ed:f8 BoardId: 0 BuildVersion: 10A523 CPUArchitecture: armv7 ChipID: 0x8920 DeviceClass: iPhone DeviceColor: unknown DeviceEnclosureColor: unknown DeviceName: iPhone DevicePublicKey: LS0tLS1CRUdJTiBSU0EgUFVCTElDIEtFWS0tLS0tCk1JR0pBb0dCQU9EaEU0aXhYOVg1RzJMb3ExdHl1NmZ3TmdRbnd3Q3p4SVZOUkJXellZQjlzd3ptRHpRRXdsbEQKUFBjSFZaKzdoN2Vuendqd1p1MlU2QzNxeDlBcldjY1Z5c0FGVjY1TG1hS1ZrZGtJU29ieUFrV1lrOWMwNFE1VAorTGp0RUc5Nm1pdERBb0IvMTlnMytGZkttZyttQ01RbHgxY0dhcWVQNUlzZjVweUpQVzlEQWdNQkFBRT0KLS0tLS1FTkQgUlNBIFBVQkxJQyBLRVktLS0tLQo= DeviceSupportsFaceTime: false DeviceVariant: B DieID: 3111481795008480456 EscrowBag: 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 FirmwareVersion: iBoot-1537.4.21 HardwareModel: N88AP HardwarePlatform: s5l8920x HostAttached: true IMEI: 012762003411981 MLBSerialNumber: J512319D1F9RC MNC: 00 ModelNumber: MC555 NonVolatileRAM: auto-boot = 74727565 NonVolatileRAM: backlight-level = 313935 NonVolatileRAM: bootdelay = 30 NonVolatileRAM: oblit-begins = MjAxMy0wMi0xNCAxNDoxNzo0NSBHTVQtMDU6MDA6IE9ibGl0VHlwZTogT2JsaXRlcmF0ZURhdGFQYXJ0aXRpb24uIFJlYXNvbjogU0JSZXNldE1vZGU9Mw== NonVolatileRAM: obliteration = MjAxMy0wMi0xNCAxNDoxNzo1OSBHTVQtMDU6MDA6IGhhbmRsZV9tZXNzYWdlOiBBbmQgeW91IHdpbGwga25vdyBteSBuYW1lIGlzIHRoZSBMb3JkIHdoZW4gSSBsYXkgbXkgdmVuZ2VhbmNlIHVwb24gdGhlZS4= NonVolatileRAM: platform-uuid = 00000000000010008000040cce51edf9 PasswordProtected: false ProductType: iPhone2,1 ProductVersion: 6.0.1 ProductionSOC: true ProtocolVersion: 2 ProximitySensorCalibration: Q00BAAwACgMAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA= RegionInfo: LL/A SDIOManufacturerTuple: IOSDIOManufacturerID = 720 SDIOManufacturerTuple: IOSDIOProductID = 17189 SDIOProductInfo: P=N88 m=3.2 SIMStatus: kCTSIMSupportSIMStatusNotInserted SIMTrayStatus: kCTSIMSupportSIMTrayStatusUnknown SerialNumber: 85123Y41EDG SoftwareBehavior: 11000000000000000000000000000000 TelephonyCapability: true TimeZone: America/New_York TimeZoneOffsetFromUTC: 18446744073709533616 TrustedHostAttached: true UniqueChipID: 2648267033869 UniqueDeviceID: 7a7053c21c82181559b34b363c30d9cf024a7153 UseRaptorCerts: false Uses24HourClock: false WiFiAddress: 04:0c:ce:51:ed:f9
Feb 15, 2013 | Apple Iphone 2g 3g 3gs 8gb 16gb S
Apple Iphone 2g 3g 3gs 8gb 16gb S Logo
328 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
