Question about Roper RS22AQXKQ Side by Side Refrigerator
My roper refr is not runing, it trows the breaker, if you turn the breaker on it makes no noise just trows it out in 2 sec.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
It is likely that the compressor windings are shorted and when plugged in, throws the breaker. Check to be sure the cord is in good shape, too. Remove the connections from the compressor (mark them so you can replace) and tape them off. Plug it in and see if it still trips the breaker. If it does not, the compressor is shorted.
Kelly
Posted on Mar 24, 2011
My Kipor KDE16STA3 shows p03 error after 15 min runing and shuts down after 3 sec.The voltage drops to 30,40 whta's happening?
[PDF]DIESEL GENERATING SET
www.kipor.com/upload/spec2011053011590766.pdf
3/KDE16STA3/ ..... P-03 Undervoltage: Indicating voltage higher (lower), the generator will self- braking. P-04 Generator ... KDE16STA3 KDE19STA KDE19STA3.
[PDF]2
www.kipor.com/upload/spec2011061109073968.pdf
P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
Oct 31, 2015 | Kipor Electrical Supplies
Why the circuit breaker keep trowing off ?
Could be a short in the cord somewhere. This will keep tripping the breaker. If you can check the socket and plug for loose wires or check for damage along the cord.
Jul 25, 2014 | Rule 1800 H53SP-24 Swimming Pool Cover...
Have Roper RES7646KQ0 Electric dryer and the lkight comes on , it makes a humming noise when you turn the dial, but does nothing when you hit the start button. help!
What has occurred, before your problem, voltage problem, lightning strike, possible heating problem ?
Check your breaker, turn off then on to make sure there is complete circuit. If not that, bad timer possible or open thermal fuse. Would be my thought.
Dec 28, 2011 | Roper RES7646KQ Electric Dryer
Roper elec dryer starts and runs for 10 sec then stops runnning
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 14, 2010 | Roper RES7646KQ Electric Dryer
My roper electric dryer heats when running for 5 mins. then trips circuit breaker
May not be your dryer. Many times a loose wire at the circuit breaker panel will cause the breaker to get hot and then thermal trip the breaker. It may be worth a look. Remove circuit breaker panel. Turn dryer breaker off. Check wire lug screws for being loose. Make sure screws or snug but do not tighten and strip the threads. Be especially careful if the wire/cable is silvery aluminum colored. If that is the case make sure there are not any broken strands at the breaker lugs. If possible use a clamp on amp meter to check the operating current. The current should not exceed 80 percent of your breaker rating. It is most likely a 30 Amp 2 pole. You may also have a bad breaker. If a breaker has a weak spring or bad contacts it will easily get hot under load and trip. My best guess other than a dryer motor locking up or dragging. New breakers are inexpensive at HD or Lowes etc. Be sure to get the exact brand and model if replacing.
Feb 27, 2010 | Roper REX3614KW Electric Dryer
Haywood Max-Flo Pump (self priming)for indoor inground pool 3/4 HP ... model C48J2N131A -- yesterday turned off master breaker switch to everything in the pool area (including power to pump) so that I...
The motor may have blown the start capacitor. It is the black cylinder about 1-1/2" dia x 2-1/2" long. Look at the end with the wires for a small hole. Is it blackened or have a hole blown thru? If so replace it. Otherwise have a local electric motor repair shop look at it for possible repair or replacement.
Sep 06, 2009 | Hayward Pool Products Hayward Max-Flo 1...
I have a roper REX5634KQ1 won't turn on!
Thermal fuse is the problem , located on the blower housing . (small white thin piece with 2 wires attached ) Pt# 3392519 . You will have to remove the front panel to get to it .
Jul 13, 2009 | Dryers
Loud noise when running
Roper RGV4634KQ1 gas Dryer Starts to dry, turns 2-3 seconds, stops turning and makes loud screeching sound. Turn off to stop noise. Retry same situation.
Apr 16, 2009 | Roper RGX4634KQ Gas Dryer
Composser makes clicking sounds evey 5 sec.
if the unit is making this noise get the modelk number and go to the paarts house and et a start relay for the unit, that should repair the problem
Jan 10, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Roper RS22AQXKQ Side by Side Refrigerator Logo
64 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
