My kenmore elite he3t front load washer door will not unlock
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
If there is water in the tub, it will not unlock. There is a pump filter that becomes plugged that you can access from the front by removing the lower panel. It unscrews and allows to be cleaned out. If still no luck, there is a release at the bottom of the door lock to open the door manually.
Kelly
Posted on Mar 24, 2011
  • 1314 Answers
SOURCE: Need to purchase CCU for Kenmore Elite 45966 Front Load Washer
try here http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Posted on Jan 11, 2008
SOURCE: Kenmore elite HE3t auiet pak 4 front load washer
I had the same exact problem. I was getting a F-02 code. After alot of headache and searching I found out I had 3 baby socks stuck in the drain. Which explained why the water would not drain. There was atleast a gallon of water in the pipes so when I opened the cleanout.... WATER EVERYWHERE!!! make sure you have atleast 5 towels readyto go when you do this
Posted on May 23, 2008
SOURCE: kenmore front load he3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Posted on Mar 02, 2009
SOURCE: need a manual for my kenmore elite he3t front load washer
My Kenmore Elite HE3 has been great for many years, and now I have a little problem for the first time.
I can usually press cancel to change the program. This morning, after I selected one program and press cancel, it won't cancel. Lights just blinked. So, I press Start to wash with selected program, but it won't start. It won't start nor cancel no matter what I do.
Should I unplug the unit?
Thank you so much!
Posted on Mar 11, 2010
SOURCE: Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Posted on Jul 13, 2010
Elite HE3t washer, in the middle of a load, it stopped. it flashes dL, F
door lock error...door lock mechanism broken,,,replace door switch,,,if your lock out remove toe panel and reach up and pull tab,,always unplug first...good luck
Sep 03, 2011 | Kenmore Elite 45986 Front Load Washer
Hi! We have Kenmore Elite he3t. We noticed water in the washer today after a complete cycle so we ran the rinse and drain command on it. I tried to begin a new load on a normal wash cycle and it will...
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Kevin
Aug 30, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore elite front load washer overloaded with clothes and door won't open
Here is some information on how to run the diagnostic test and open the door if need be.
Dec 27, 2010 | Kenmore HE3T Washer
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
WHAT IS DU?
DU is door unlock error - A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
Solutions -
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
  • May 19, 2009 | Kenmore Elite 45986 Front Load Washer
    HE3T washer
    You disconnect the power ,take the top cover off, then you see the door lock assembly so take the screws from the front door ,you hold the door lock assembly and install the new one
    Nov 03, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite washer Locked
    remove bottom panel reach up from bottom to lock area pull the small tear shaped release to open door if water still in tub pump may be plugged to clean turn handle on pump to left and pull out trap and clean ..after dipping as much water out as possible
    Jun 26, 2008 | Kenmore Elite 45986 Front Load Washer
    Unlock the control panel to a kenmore elite front loader
    to unlock the controls
    select and hold drain/spin for 3 seconds until the control locked status lights turn off.
    Nov 22, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
    Washing Machines Logo
    269 people viewed this question
    Top Washing Machines Experts
